Sponsored by BimmerWorld
Old 10-11-2013, 12:03 PM   #1
screamotaku
My Ride: 2001 BMW 330ci
Torque specs on these bolts?
I was doing the RTABS with my friend, when my trailing arm wouldnt drop low enough to make the clearance to press them out, I figured out that my aftermarket sway bar was too thick and hitting the axles, no big deal, I just had to remove the sway bar.
But anyways, my friend thought it would be a good idea to remove the bolt for part 8 and 9 on this diagram thinking it would help lower the trailing arm: http://www.realoem.com/bmw/showparts...40&hg=33&fg=30
..... without my supervision or approval. Now, I figure these bolts are for toe adjustment, my question is, what is the torque specs on these things? I just wanna get them back in to the point where it's safe to drive on them without them flying out while on my way to an alignment.
screamotaku is offline   Reply With Quote
Old 10-11-2013, 12:31 PM   #2
ian02
My Ride: 05 325ci
According to the Bentley manual on page 330-6, it says 110NM (81 ft lb)
ian02 is offline   Reply With Quote
Old 10-11-2013, 12:48 PM   #3
screamotaku
Thanks a lot, I appreciate it. I need to get a Bentley manual already.
Old 10-11-2013, 01:31 PM   #4
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
To make torque specs a little easier to find there is this card from Bimmertools ($5 shipped)
http://www.bimmertools.com/Bimmertoo...d-p/e461-1.htm
scottjoh is online now   Reply With Quote
Old 10-11-2013, 01:48 PM   #5
ian02
My Ride: 05 325ci
That's a great idea!
Old 10-11-2013, 03:50 PM   #6
screamotaku
Very nice, Ill have to pick this up! Thanks!
Old 10-17-2013, 02:08 AM   #7
YOnpds
My Ride: E46
Wow, that pretty much pays for itself. Very nice
YOnpds is online now   Reply With Quote
alignment, bolt, rtab
