///M3 Forum
Old 10-11-2013, 04:39 PM   #1
M3Froi
My Ride: 2005 M3 ZCP
Vibration at Lower RPM
Hi all, I noticed the other day that my car has been experiencing some vibration which feels like it's coming from the driveshaft at lower rpm's (<2k). I notice it the most when I accelerate from a dead stop, then it goes away afterwards. I suspect it could be my guibo/center support bearing based off some research. I'm planning to have both replaced by the end of the year, I was just wondering if anyone else has experienced this. Any feedback would be appreciated, thanks!
M3Froi is offline   Reply With Quote
Old 10-11-2013, 06:44 PM   #2
cosmos m
My Ride: m3's(cosmos, TiAg)
I have a vibration <1500rpm, and I feel it when I first rev the car up with clutch in. I'll have to inspect the guibo, although I thought guibo vibrations are felt at higher speeds. Anyone have any ideas about this?
cosmos m is offline   Reply With Quote
Old 10-12-2013, 01:40 PM   #3
M3Froi
I'm hoping it's just my guibo/CSB, it could be the case for you too. I'd replace both while you're at it. Anyone know how much a job like this at a shop usually runs?
Old 10-13-2013, 03:42 AM   #4
Ballstowalls
My Ride: 05 e46 m3 vert
I'm having a vibration when slowing down for any gear between 2rpm to 1.5 rpm...
Ballstowalls is offline   Reply With Quote
Old 10-14-2013, 12:35 AM   #5
M3Froi
I also noticed I have a slight kick when I release my gas pedal suddenly (as opposed to gradually lifting off), could that be guibo/CSB related as well?
Old 10-15-2013, 06:33 PM   #6
AlpinTXiX
My Ride: 03 M3
Actually had a similar issue this past weekend. On cold starts, in 1st or 2nd, at 2.5k or less RPM, and when off throttle, car will lurch and shudder. Exacerbated by going downhill. Feels like a rubbery binding and unbinding movement of the drivetrain. Whole car shakes.
Had a long drive to make the next day, so I took it into the shop where they checked the guibo and underside. Guibo was in great condition and they did not think it was the center driveshaft bearing as it would make a thunking noise increasing with speed. If it was the center bearing, you'd feel it increasing with speed, so I'd rule that out for you. That left the culprits for me as potentially motor or transmission mounts. The symptoms have yet to reappear after the intial two incidents though, which has led me not to worry about it too too much at the moment (picking up a daily and placing the M on weekend duty so I can bulletproof the VANOS).
Bear in mind that to get to the center bearing (or guibo or clutch), though it's a $100 part, requires dropping the exhaust, heat shields, and whole driveshaft. If you go in to address/diagnose it more, you might want to do everything at once to save time (or $).
AlpinTXiX is offline   Reply With Quote
Old 10-16-2013, 11:50 AM   #7
M3Froi
This is exactly how I would describe my issue as well. I agree, my first thought would be the tranny mounts and possibly the diff bolts/bushings. If you find out anything more about this issue please keep me updated!
As for the guibo replacement, I am aware of the labor involved to get to the part which is why I'm planning to replace the CSB while they're under there. I'm almost certain that's the root issue of my drive-train vibrations. Thanks for the advice tho!
Old 10-18-2013, 03:48 PM   #8
M3Froi
So I narrowed my two issues down to a few parts (hopefully):
Shudder - MAF sensor (needs cleaning), O2 sensor (needs cleaning), diff bolts/bushings
Vibration -guibo, CSB, tranny mounts
Does anyone have any experience with different options?
Old 10-19-2013, 12:35 PM   #9
AlpinTXiX
My Ride: 03 M3
MAF Sensor: haven't had shuddering directly from it. Did have it throw a CEL before and cause a rougher idle; used some CFC cleaner and problem gone. I did clean my MAF after my recent shuddering and my MAF was dirty, as I could tell the idle was smoother. Have not been able to confirm whether the MAF was causing the problem, as when it was bad enough to throw a code there was no shuddering. It is conceivable that the MAF could be SO dirty it is causing the sensor to send inaccurate readings to the ECU to the point of shuddering (or the MAF could be defective) but if it were that bad there would probably be a CEL code.
Bottom line, the MAF is unlikely to be the sole cause of my issues (and likely yours), but could help relieve some symptoms as well as smooth out these cars' notoriously rough idle. A bottle of cleaner is $5 from autozone. A specific tamper resistant torx driver is needed as well to access it; forgot what exactly the name is
Old 10-19-2013, 12:38 PM   #10
AlpinTXiX
My Ride: 03 M3
Guibo: So my local shop said the guibo looked fine with no cracks and chunks missing. So that's not an issue for me, and means it might not necessarily be for you. Though it is still very plausible that it is a guibo issue, as it the shuddering sure sounds like one. Guibo is $79.95 and requires a drive train drop (as well as exhaust and braces), so you may want to do the clutch or other driveshaft components as well if you decide to replace the guibo
Old 11-28-2013, 11:52 AM   #11
pbm7
My Ride: e46
Re: Vibration at Lower RPM
Did you ever figure out wwhat it was?
Sent from my SAMSUNG-SGH-I747 using BimmerApp mobile app
pbm7 is offline   Reply With Quote
Old 12-03-2013, 05:33 PM   #12
M3Froi
Not yet, I'm almost certain it's my guibo/CSB. I just purchased a new guibo/CSB recently, I'm planning to have them installed early next year (busy month for me). I'll definitely update this thread accordingly, but for now I can deal with the vibration until then.
Old 12-05-2013, 12:40 PM   #13
greenhobby
My Ride: 2002 e46 M3
Have you ruled out exhaust hangers? I get a vibration at idle when they need to be replaced. There are 3 on the muffler and 2 half way towards the engine. If you've never replaced them, that is probably your problem. I just changed mine 2 weeks ago.
-gh
greenhobby is offline   Reply With Quote
Old 12-05-2013, 01:21 PM   #14
pbm7
My Ride: e46
Well I replaced my whole driveline the reason for the that vibration I installed my guibo flex disc wrong redid it and vibration was gone when I let off from 2k
Old 12-05-2013, 02:08 PM   #15
M3Froi
Nice, that's reassuring then. I don't think it's my exhaust causing this since I replaced the bolts/hangers when I first purchased my car in May, it's definitely coming from my driveshaft. I feel like I have a loss of low-end power <2k and afterwards it's fine. This thread on M3F describes my issue exactly:
http://www.m3forum.net/m3forum/showthread.php?t=364291
Old 12-06-2013, 02:39 AM   #16
alldayreese
My Ride: Vehical
Loose screw or the exhaust may be hitting the drive shaft if you have a aftermarket exhaust.
Mitsubishi Evo5 rhd full racecar customer built from a mirage. Daily driverE46 325ci.
FFTEC Motorsports
alldayreese is offline   Reply With Quote
Old 12-06-2013, 05:57 PM   #17
M3Froi
FFTEC Motorsports? Would you happen to know Edwin? I went to Cal Poly with that guy haha
Old 12-06-2013, 06:05 PM   #18
alldayreese
My Ride: Vehical
Haha small world. yes I do he has the 1g DSM with like massive turbo. Koo guy to.
FFTEC Motorsports
Old 12-06-2013, 07:25 PM   #19
M3Froi
Do you guys work on M3's? I'd be interested in taking my car in if things work out and I end up working up in the bay. Lmk!
Old 12-13-2013, 04:53 PM   #20
bradferry
My Ride: 03 m3 CSL
whats crazy its a combination between the guibo and tranny mounts under torque throws a clunk noise , ive noticed this on my car also and this is exactly what i think it is...
except everytime i start my car and go ..
please update me with info
bradferry is offline   Reply With Quote
