Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 10-12-2013, 03:57 PM   #1
new//M3fan
My Ride: 77' 924 87' E30
Comprehensive MS43 DME Information
The goal of this thread is to finally get organized on identifying maps and other features on the MS43 DME.
Variable name = C_CONF_EOBD Turns on CEL on IGN position 2 on EU2 emmision variant
HW-NR|ZUSB|Platform|Description|Offset|Size|Notes
7545150|7545671|MS43|EOBD on or off|0x0B29|1x1 table|00 = No EOBD 03=EOBD *VERIFIED*
7572342|7575144|MS43|EOBD on or off|?|1x1 table|00 = No EOBD 03=EOBD
Pass: e46
Emission Variant Information
10/16
Made the changes above and corrected check sums. (change .pdf to .rar)
10/25
Added WinOls project file (contains deleted DTC codes address space and rev limiter per gear map set to 6000rpm) Change ext to .ols
11/16/
Originally Posted by kristsm View Post
It would be great if we could gather all the A2l abbreviations in one post. This could help us to identify maps more easier, starting with these:
N - RPM
MAF - LOAD/FLOW/AIR
IP - 3D MAP
TI - THEORETICAL INJECTION
TCO - THROTTLE CONTROL OPERATION
PL - PART LOAD
IVVT - INTAKE VARIABLE VALVE TIMING
VIM - VARIABLE INTAKE MANIFOLD(DISAVALVE)
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 10-12-2013, 09:12 PM   #2
Llink78
My Ride: 2002 330i
After you figure this all out. Need to modify the file and then sell it for your hard work to pay off.
Llink78 is offline   Reply With Quote
Old 10-12-2013, 09:17 PM   #3
new//M3fan
Thanks, no money will be made from this effort. This is to benefit the community. After all I hope it will become a community effort ( I do not know all the ins and outs on this stuff ) I am just providing a stepping stone and doing the best I can at the time. All I want to gain from this is more knowledge.
Old 10-14-2013, 09:42 PM   #4
TerraPhantm
My Ride: M3 & ZHP
Here's another A2L that I have. Not everything lines up properly though
http://www.sendspace.com/file/1lxpc3
Never mind, it is included in your file
TerraPhantm is online now   Reply With Quote
Old 10-16-2013, 12:25 AM   #5
new//M3fan
Yea, I've noticed that as well... Hopefully I'll be able to find one that is as accurate as the one that was used for the MSS54.
Old 10-16-2013, 02:01 AM   #6
HakenTT
My Ride: 323i with S54
I have no information on checksum. But I will add that with wrong checksum ms42/ms43/ms45 will not even boot, it will be in recovery mode. I use winols for checksum correction
HakenTT is offline   Reply With Quote
Old 10-16-2013, 02:05 PM   #7
new//M3fan
Posted up a binary with the change. I haven't tested it personally. but you are always welcome to give it a shot.
Thanks for the feedback. Ended up using winols
Old 10-16-2013, 05:19 PM   #8
new//M3fan
I think I may have found the catalytic efficiency max and min thresholds. I'll give those a shot once I confirm the CEL is now on on position 2 (if a CEL is thrown due to cats)
If not I will use Hakken's XDF and confirm the maps he has identified and try to correlate the correction factors against the ones used in MSS54's.
Old 10-16-2013, 07:02 PM   #9
new//M3fan
C167CR datasheet/instruction set
Looks like the MS43 uses a 16-bit infineon SAK-C167cr-LM processor
Old 10-16-2013, 07:46 PM   #10
TerraPhantm
My Ride: M3 & ZHP
I wonder if the Siemens C166 is close enough to disassemble the binary. That seems the closest in IDA anyway. I believe this CPU has JTAG support too; that might be worth investigating later on.
Edit: Disassemble it as C166 st10
Old 10-16-2013, 09:41 PM   #11
new//M3fan
well good news. I just flashed my modified file and turned on the CEL when IGN position 2!
Old 10-16-2013, 09:43 PM   #12
new//M3fan
Question is, IDA pro is rather expensive for the hobbyist. I haven't been successful in finding a copy with the dissemblers needed. I'm not familiar with JTAG. What exactly does that offer? Also wonder if Smooth's BMWFLASH utility can download a full read....
EDIT:
Missed your edit... thanks for the tip!
Old 10-16-2013, 09:44 PM   #13
Llink78
My Ride: 2002 330i
Man I wish I knew more. But most of this talk is like a foreign language.
234HP/197TQ Just bolt ons :) New Numbers Coming Soon!
Old 10-16-2013, 10:06 PM   #14
TerraPhantm
My Ride: M3 & ZHP
I think infineon has a disassembler, but I've never used it.
Re: IDA -- Like WinOLS, is somewhat difficult to get even if you are willing to pay the price. Given that, and the fact that they don't offer student licensing, I'm guessing that #of sales isn't their priority. I'm not going to advocate piracy, but I will say that probably 99% of the hobbyists online who use IDAPro have not acquired it by legitimate means.
Unnecessary for most hobbyists anyway; disassembly is beyond the skill of most non-CS folks.
Old 10-17-2013, 12:03 AM   #15
HakenTT
Even if you can disassemble the code you still must know how the processor is used, what ports are controlling what
Old 10-17-2013, 12:31 AM   #16
new//M3fan
Re: Comprehensive MS43 DME Information
Any insight on how that mat be done with the posted reference manuals?
Old 10-17-2013, 02:32 AM   #17
new//M3fan
I believe I also found a way to delete DTC's.
They are stored as 16bit hex values corresponding to it's Pxxxx with the main xxxx i.e 0420 (cat below threshold bnk1) Simply zeroing these out should clear these. Hopefully they will also set applicable monitors to ready as it does on the MSS54...
Old 10-17-2013, 03:15 AM   #18
daniel_f.
My Ride: 330iC
Maybe this could help?
http://forum.e46fanatics.com/showpos...&postcount=439
its a complete disassemble of the ms42, maybe its helpful.
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 10-17-2013, 03:42 AM   #19
HakenTT
There are free Damos files for MS42, MS43, MS45 available for free on the internet. With corresponding bin file it will tell you everything and about every map what it is. So what's the big deal? This information was available for the past 5 years. That's what I use to do my coding/tuning so what information am I holding?
Old 10-17-2013, 08:35 AM   #20
new//M3fan
The information is not out there in a good enough format (for me). The damos for the ms43 out there doesn't have any correction factors and not everything is identified. Nonetheless it is still useful. This is a learning effort for me. I'm not sure why the defensive tone all of the sudden...
Anyway for example your XDF doesn't have the right correction factors, and nothing else is there besides the maps (a simple damos to xdf format is what it looks like to me) it may be right but still not good enough for me. No DTC delete, EWS delete, etc. I want to put all this info in a comprehensive thread.
Thanks that's definitely useful!
