Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 10-17-2013, 09:45 AM   #21
daniel_f.
My Ride: 330iC
Originally Posted by new//M3fan View Post
No DTC delete, EWS delete, etc. I want to put all this info in a comprehensive thread.
If thats what you´re after and you´re really getting at it, instead of so many others before, i´m gladly helping as far as i can
I´m currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 10-17-2013, 10:23 AM   #22
smooth1
My Ride: BMW FTW
Also wonder if Smooth's BMWFLASH utility can download a full read....
I have not added MS43 support into BMWFlash at this point. Will consider.
smooth1 is offline   Reply With Quote
Old 10-17-2013, 10:32 AM   #23
new//M3fan
My Ride: 77' 924 87' E30
Originally Posted by daniel_f. View Post
Maybe this could help?
http://forum.e46fanatics.com/showpos...&postcount=439
its a complete disassemble of the ms42, maybe its helpful.
What I really want to know is if the MS43 has a similar pseudo counter flash limit like the MSS54
Thanks, That would surely help.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 10-17-2013, 11:00 AM   #24
daniel_f.
My Ride: 330iC
Well, right now i haven´t found a way to download the whole 512kb without unsoldering the 29F400, so its no problem to flash a virginized file and start by zero. using a tool to read/write the 64kb file is no problem at all, there is no limit, except one from the tool itself if it has a limit. kwp2000+ doesn´t.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 10-17-2013, 11:28 AM   #25
new//M3fan
I think BMW scanner 1.4 can be used to take a full read. Ideally I would like a better solution i.e BMWflash to do this with instead.
http://www.bmw-scanner.com/download/...n_140_demo.zip
IIRC the demo version has this capability.
Old 10-17-2013, 12:54 PM   #26
daniel_f.
My Ride: 330iC
You need a very solid battery charger when using scanner and it will read it in big endian or little endian, can´t remember right now. its twisted to a direct eprom read-out.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 10-17-2013, 03:37 PM   #27
new//M3fan
Same way as in the MSS54 then.
Old 10-17-2013, 07:22 PM   #28
Hornung418
My Ride: '04 MB ZHP
In for results.
If we can get the ZHP to run the MS43 EU2 with headers and CEL to work KO,EO. And then tune it from there, we could have a solution to ZHPs and headers, with out having to pay for a tune.
Hornung418 is offline   Reply With Quote
Old 10-17-2013, 07:35 PM   #29
new//M3fan
Well no dice on triggering the monitors to ready after turning on EOBD.
Will zero out the individual codes on the DME next.
Old 10-17-2013, 11:19 PM   #30
smooth1
My Ride: BMW FTW
Originally Posted by Hornung418 View Post
In for results.
So you're talking about using a different DME on ZHP? Just make a thread for MS45...
Old 10-18-2013, 04:16 AM   #31
Hornung418
My Ride: '04 MB ZHP
Re: Comprehensive MS43 DME Information
No...I'm clearly talking about using swapping the MS45.1 for MS43. My post is relavent to this thread. Thanks for your concerns.
Old 10-18-2013, 09:52 AM   #32
smooth1
My Ride: BMW FTW
There's some work involved in that. Keep us posted when you get started.
Old 10-18-2013, 12:30 PM   #33
Hornung418
My Ride: '04 MB ZHP
Yeah...I've already tried and failed with the MS42 > MS43 swap...hopefully this will be a little easier and more effective.
Old 10-18-2013, 04:41 PM   #34
new//M3fan
Set C_DTC_CAT_DIAG and C_DTC_CAT_EFF located at 0x178 - 0x197 to zero in efforts to set monitors to ready as in MSS54. Will report back
EDIT: also noticed that value C_CONF_CAN_CAL is set to 03 on EU3 Where as in EU2 it is set to 02.
I'll set this to 03 as well.
Both EU3 and EU2 have C_CONF_SAP set to 00. I need to check this address on a US or EU4 tune to confirm if this needs to be zero'd out for the monitor to be ready/unsupported.
Confirmed.
C_CONF_SAP is set to 01 on US tune, 00 on EU3/EU4 and EU2.
C_CONF_CAT is set to 00 on all tunes. which may mean set default to not ready. 01 may set it to ready if it's the address for the catalytic monitors.
Old 10-19-2013, 03:46 AM   #35
bernie21614
My Ride: 01 330i
So anybody in the Phoenix west valley area updating DME's?
bernie21614 is offline   Reply With Quote
Old 10-19-2013, 10:13 AM   #36
daniel_f.
My Ride: 330iC
I believe I also found a way to delete DTC's.
They are stored as 16bit hex values corresponding to it's Pxxxx with the main xxxx i.e 0420 (cat below threshold bnk1) Simply zeroing these out should clear these. Hopefully they will also set applicable monitors to ready as it does on the MSS54...
how to find them? are they located similar to mss54? if so i haven´t found them earlier
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 10-19-2013, 01:16 PM   #37
TerraPhantm
My Ride: M3 & ZHP
Swapping ms45 to ms43 is more difficult than ms42 to ms43. You're better off tuning the ms45.1. Ms45.1 is the better ECU anyway
Old 10-19-2013, 01:35 PM   #38
HakenTT
My Ride: 323i with S54
This is correct. MS45.1 even has a option for SPORT switch like mss54 does. It also has fuel pump module that is stand alone and it gets data from the engine via CAN. I managed to code it for sport switch and code it for regular fuel pump relay for E30 swap. I run it and it is great system.
HakenTT is offline   Reply With Quote
Old 10-19-2013, 04:48 PM   #39
Hornung418
My Ride: '04 MB ZHP
Can you properly disable rear oxygen sensors for headers? That's my biggest goal for this car after it gets all the cosmetic damage repaired. I've been sitting on a pair of headers for almost a year...they were gonna go on the 328i...but that never happened
Still in regarding advancement in self tuning. Jorge is closest to me so it wouldn't be a bad idea to meet up with him and see what we can do.
Just thinking aloud...don't mind me
Old 10-20-2013, 11:47 AM   #40
daniel_f.
My Ride: 330iC
If one is interested in IDA Pro, drop me a PM
Siemens MS42 wiki!
Siemens MS43 wiki!
