Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 10-31-2013, 05:01 PM   #41
new//M3fan
My Ride: 77' 924 87' E30
No dice on the DTC delete setting the monitoring to ready. Could be because the fuse for the 02 sensors in the DME box as explained in my other thread has been left out triggering a change in the way the program section looks at the data section.
Not going to look into it further and moving on unto identifying the tunable maps with it's right corrections.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 11-01-2013, 09:54 AM   #42
Guest021715
Account closed.
I'm curious if the efficiency threshold for post-cat sensors can be modified on an original tune.
The goal would be to eliminate a CEL for those running catless headers, yet maintain sensor readiness for OBD2 emissions testing. Possible, or I've got my head in the clouds?
Old 11-02-2013, 08:28 AM   #43
jdjg
My Ride: e39, m52tub30
Comprehensive MS43 DME Information
I have in my car, the Euro tune for my MS43 with catless headers and NO post O2 sensor, also I have full read of my two headers O2 sensors (Pre cat sensors) and NO CEL light in my cluster
jdjg is offline   Reply With Quote
Old 11-02-2013, 10:11 AM   #44
new//M3fan
I do remember seeing references for min and max values concerning the 02 sensors. But I'm not going to look at into it any further. (fornow) (made other arriangments to pass emmisions)
Moving unto map identifying.
really want to find the throttle maps.
I've been playing with idapro, but not entirely sure what the right RAM and ROM sizes are for the MS43 and don't know how to use IdaPro just yet effectively to trust what I am finding plus also slowly self teaching myself.
Old 11-04-2013, 07:54 PM   #45
jony787
My Ride: 318ti M52tu SWAP
Open the DAMOS With a full 430056 dump......
jony787 is offline   Reply With Quote
Old 11-05-2013, 01:27 AM   #46
daniel_f.
My Ride: 330iC
havenīt the throttle maps been identified by harkantt? i remember modifying them!
Iīm currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-05-2013, 08:51 AM   #47
Guest021715
Account closed.
Re: Comprehensive MS43 DME Information
It would be a godsend if we had a set of modified tunes to use, as a default for each E46 model.
Alternatively, if it could be possible to delete/disable the algorithm which check for a lean condition when coming off the throttle, any cheap O2 simulators would work 100% of the time.
Old 11-05-2013, 03:14 PM   #48
new//M3fan
Not sure where I can find a full 430056 dump. Only been able to find a partial read.
Didn't see them in the xdf.
Any clue on what the mnemonic would be for that function in the DAMOS?
Old 11-07-2013, 07:43 PM   #49
jony787
you can also read full dump with galleto 1260. working now in writing with it....
Old 11-09-2013, 07:35 PM   #50
new//M3fan
What are the steps to getting a full read on the 1260?
Old 11-11-2013, 01:50 AM   #51
daniel_f.
My Ride: 330iC
at the end of the week i can give you the position of the throttle map. currently i donīt have any spare time.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-15-2013, 07:08 AM   #52
kristsm
My Ride: 330D M57N
I am also interested on sharing my knowledge, time and hard work for disassambling MS43/MS45 functions and make this ECU open tuned.
The more people will be involved here, the faster we will make it happen!
Yesterday I reviewed 430056 file and collected some actual maps with clear english meaning.
I have also perhaps found some directions on how to disable IMMO. This is very necessary for me as I am about to install M54 in different chassis.
First of all, HakenTT has placed comment "tuners make the whole map to 00" in his 430055 XDF's "ID VIM PL MAF". I have found this 6x8 map @ 75E0F (430056 software).
Secondly, there was also an information, that some DTC's should be disabled for IMMO-DELETE. I might also found them,too (430056 software ):
705BE (c_dtc_vim_0) value - 5395
705C0 (c_dtc_vim_0) value - 5394
705C2 (c_dtc_vim_0) value - 5394
705C4 (c_dtc_vim_0) value - 5394
There are also other single value maps that contain the word "vim" and should be related to IMMO system. Be we should start with testing zeroing ID VIM PL MAF. Unfortunately, I don't have a running engine so would be great if someone could test it on his car if the software version is the same. If not - then I could try to locate IMMO maps on different software if someone are really ready to test it!
Secondly, I really want to understand the logics of MAF measurements and how the map voltage are scaled in the software.
I found 16X16 map in 7A738 (ip_maf_1_diag_n_tps_av) - it has RPM/TPS axis, so it means it consist of requested load values (in DME the wording "maf" can also mean - "load"). So, if injection/ignition maps have RPM/LOAD axis, then doesn't it make this 16x16 map as Alpha-N map?
There are also 2 16X16 MAF maps @ 70E3A (?) & 7103A (safe mode MAF map)
P.S. Please don't let this post die - MSS54 has been discovered all ready, please share as much information as you can or want to share
kristsm is offline   Reply With Quote
Old 11-15-2013, 07:25 AM   #53
kristsm
My Ride: 330D M57N
It would be great if we could gather all the A2l abbreviations in one post. This could help us to identify maps more easier, starting with these:
N - RPM
MAF - LOAD/FLOW/AIR
IP - 3D MAP
TI - THEORETICAL INJECTION
TCO - THROTTLE CONTROL OPERATION
PL - PART LOAD
IVVT - INTAKE VARIABLE VALVE TIMING
Also, I tried to compare 430056 MAP locations with 430055 locations and there seems to be interesting 14 (in decimal) value offset between each software which only starts in about half of the 64kb read. Also, some of single value maps have different than 14 value offset, must also discover it further.
Old 11-15-2013, 01:23 PM   #54
jony787
VIM means VARIABLE INTAKE MANIFOLD aka DISA.......
Old 11-16-2013, 03:34 PM   #55
new//M3fan
Correct.
Still curios about why Hakken points out that tuners set that VIM_MAF_PL map to 00. What does it do?
I haven't had a chance to look into it much further. Still need to figure out the right way to dissemble the binary and configure IDA before starting.
Still, where are you guys finding a full 430056 dump?
Old 11-17-2013, 02:58 AM   #56
kristsm
My Ride: 330D M57N
I can send you the whole OLS file with 430056 dump&a2l, just let me know your e-mail!
Correct.
Old 11-17-2013, 03:56 AM   #57
jony787
Virginized MS43 with EURO 2 tune no SAP or post CAT o2 check engine light!!!!!!!!! If you installed headers, bad dme or sap delete this is for you!!!!!! PM me for details!!!!!!
Old 11-17-2013, 06:58 AM   #58
daniel_f.
My Ride: 330iC
Appreciate your progress! But i would even more appreciate it if you would unveal it open
sorry for being late, but finally:
TPS position at MS430066:
tuner tuned tps:
i really hope there will be some progress in deleting the EWS and DSC handicap, i would really like to build a E36 330ti
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-17-2013, 11:30 AM   #59
kristsm
My Ride: 330D M57N
There is no big price difference here to buy whole MS43 ECU + wiring + EWS + ignition keys + ignition module or buy just MS43 ECU. Therefore, if the chassis have MS43 ECU + EWS + ignition module + ignition key, what else is needed for starting the car and not having MIL light? What about running MS43 without E46 instrument cluster?
Old 11-18-2013, 02:01 AM   #60
daniel_f.
My Ride: 330iC
Without E46 Cluster, there will be no MIL light as there is no possibility to light it up
Siemens MS42 wiki!
Siemens MS43 wiki!
