Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 11-18-2013, 03:27 AM   #61
kristsm
My Ride: 330D M57N
Originally Posted by daniel_f. View Post
Without E46 Cluster, there will be no MIL light as there is no possibility to light it up
Thanks What I really wanted to know is if abscence of instrument cluster, ABS/ESP and other control modules will not make the ECU to go into limp mode?
kristsm is offline   Reply With Quote
Old 11-18-2013, 03:40 AM   #62
daniel_f.
My Ride: 330iC
I guess, and actually i can just guess, without dsc module the ecu will go into limpmode.
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-18-2013, 05:04 PM   #63
new//M3fan
My Ride: 77' 924 87' E30
Originally Posted by jony787 View Post
Virginized MS43 with EURO 2 tune no SAP or post CAT o2 check engine light!!!!!!!!! If you installed headers, bad dme or sap delete this is for you!!!!!! PM me for details!!!!!!
I have included just that in my first post. Minus EWS delete.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 11-19-2013, 02:19 AM   #64
new//M3fan
Appreciate your progress! But i would even more appreciate it if you would unveal it open
sorry for being late, but finally:
TPS position at MS430066:
tuner tuned tps:
i really hope there will be some progress in deleting the EWS and DSC handicap, i would really like to build a E36 330ti
Awesome!
How do you read that graph to make meaningfull adjustments to the throttle pedal to throttle body relationship?
Old 11-19-2013, 10:25 AM   #65
smooth1
My Ride: BMW FTW
Look at the first picture.
smooth1 is offline   Reply With Quote
Old 11-19-2013, 03:02 PM   #66
TerraPhantm
My Ride: M3 & ZHP
Seems odd that it would max out at 81 instead of 90. Is there a separate high load map?
Old 11-20-2013, 01:16 AM   #67
daniel_f.
My Ride: 330iC
it corresponds to the inpa values
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-20-2013, 12:57 PM   #68
new//M3fan
Gotcha,
I missed the pics at first. Attaching to thread. That image hosting you use is a mess... lol
TPS position on MS430066:
ID:	535613   Click image for larger version
Old 11-20-2013, 01:43 PM   #69
new//M3fan
Could be because the M54 TB isn't shut all the way like S54's at rest.
That looks like a 10 angle to me.
Old 11-20-2013, 07:53 PM   #70
TerraPhantm
My Ride: M3 & ZHP
Interesting. That could be the case, though I'd wonder why BMW would make a throttle body that never closes.
Makes me wonder if it'd be possible to just eliminate the idle control valve altogether on DBW cars. Always seemed redundant when the DME should just be able to adjust the main throttle body as necessary.
Old 11-21-2013, 03:17 AM   #71
xHeiKe
My Ride: '02 BMW 325i Sedan
Comprehensive MS43 DME Information
This is an extremely naive question but what are the codes used for? How do you use them?
xHeiKe is offline   Reply With Quote
Old 11-21-2013, 05:22 AM   #72
daniel_f.
My Ride: 330iC
what kind of codes do you refer to?
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-21-2013, 10:24 AM   #73
new//M3fan
Possibly as a fail-safe in the event the TB went bad. IIRC, the ICV in the M54 is used for a percentage of tb opening. At idle it does not use the TB. Which may explain the 0.00 values at low load. Maybe there is a low load ICV map somewhere.
Old 11-24-2013, 12:36 PM   #74
p0lar
My Ride: E46 ///M3
I guess I'm going to get involved here since I now have access to a 430066 in his 325i.
I don't use WinOLS, so might it be feasible to simply update the checksums within the 64kb parameter space without using that?
Does anyone know exactly where the checksums are located and how many of them there are? I think terra mentioned there being ~8, but perhaps that's inclusive of the 512kb complete dump of the 29F400. It's supposed to be more complex than the MSS5x variants of DME, but that can probably be overcome.
If anyone has any files to help me get a jump on this, feel free to send me a PM. The 4Shared sites are taxing to use, so I'd rather use eMail or a privately hosted server.
p0lar is offline   Reply With Quote
Old 11-24-2013, 09:18 PM   #75
new//M3fan
What files are you looking for?
There are 2 checksums on the 64k data portion and 16 across the full dump. You are well versed in assembly and a great asset. Thanks for stopping by!
Old 11-24-2013, 09:45 PM   #76
p0lar
My Ride: E46 ///M3
I'll take whatever I can get my hands on that isn't pirated/copyrighted. More is better, I can sift through the junk, heh.
Thanks for the information on the checksums. Might you know the locations and/or calculation routine? If so, I can produce a TunerPro checksum calculation module in very short order, as well as a checksum correction tool written in Perl (or compiled as a Win32 binary).
Old 11-24-2013, 09:53 PM   #77
new//M3fan
Sure thing. PM me your e-mail address and I'll send the files and info I have. I know the locations but not the calculation routines just yet. Really haven't taken a look that far since I'm not so great at it.
Old 11-24-2013, 10:09 PM   #78
p0lar
My Ride: E46 ///M3
Locations are the start, the rest will come in the form of trial and error. Frankly, I'm surprised this hasn't already been conquered - it's one of the first steps required to break the independence of commercial software.
If someone has WinOLS and can correct checksums, I can create a few files to generate comparisons against to determine what algorithm is being used and we can go from there.
Old 11-24-2013, 10:22 PM   #79
new//M3fan
Just sent you just that. I'd love a primer on how that is done. Through skype or somewhat. I'd like to see in action and get an idea of what is needed if possible.
Old 11-25-2013, 02:42 AM   #80
p0lar
My Ride: E46 ///M3
Ok, so no matter what changes seem to be made to the MS43 binary, only one location changes otherwise for me, 2 bytes at 0x3FE0. I don't believe the next 30 bytes are factored, but that doesn't help in the way the data is ordered when calculated, nor if there is a prefix much like the MSS52 and MSS54.
So, let's say the parameter space is chunked into exactly 16kb boundaries as follows:
segment 1 = 0x0000 -> 0x3FE0
segment 2 = 0x4000 -> 0x7FFF
segment 3 = 0x8000 -> 0xBFFF
segment 4 = 0xC000 -> 0xFFFF
I've tried running the same CRC16 used on the MSS5x DMEs in the following orders:
2,1,4,3
4,3,2,1
1,2,3,4
1,2,4,3
2,1,3,4
Plus, adding a prefix from 0x0000 -> 0xFFFF in advance of each run.
Thus far, I've hit on one match accidentally, but I believe that was a CRC16 collision as it didn't hold for any other instance. I know this is a brute force approach, but without a hint as to where to start, I'm not sure what else to try just yet.
