Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 11-25-2013, 10:47 AM   #81
daniel_f.
My Ride: 330iC
I can compare with winols or else i have a obd interface which can calculate the checksum.
i have several ms4300** files, but some are from german tuners.
im asking Rene to chime in, as i think he found the checksums at ms43 already.
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-25-2013, 11:22 AM   #82
p0lar
My Ride: E46 ///M3
I have reason to believe that there is only ONE checksum, despite what was previously posted.
When I create a file full of FF's and send it out to have it corrected by WinOLS, it returns with a 2-byte change at exactly 0x3FE0.
p0lar is offline   Reply With Quote
Old 11-25-2013, 02:24 PM   #83
p0lar
My Ride: E46 ///M3
One more bit I discovered, that the 30-byte region after the checksum, but before the first 16kb boundary (from 0x3FE2 -> 0x3FFF), seems not to be factored into the checksum calculation.
I filled the entire region from 0x3FE2 -> 0x3FFF with '00' and had the checksum recalculated. It remained unchanged.
I know that many people don't feel the checksum is of great importance, but it really is a fundamental pillar that supports open development of the platform. Without an understanding of the calculation procedure and a free, or minimal-cost tool to validate changes to the DME parameters, we are institutionally locked to commercial software that is both expensive and (relatively) proprietary. Many people are comfortable pirating this software, but this only serves to degenerate a legitimate effort to produce software that everyone can use without legal ramification.
I tried automating a routine that modified how the checksum is mathematically calculated - a complete and total brute-force approach - but that hasn't yielded success yet, and it's horribly slow. Perhaps I've missed information that someone else has posted?
Old 11-25-2013, 08:35 PM   #84
HakenTT
My Ride: 323i with S54
Polar, here is what I can say about MS43 partial read (64kb)
It appears that checksum is only calculated for partial read file (64kb)
Checksum algorithm is located starting at hex address 0008 and ends at 004F
The checksum is located at 3FE0 and the string that follows has something to do with how the checksum is calculated
Checksum is very important for MS42/MS43/MS45 because the DME will not even boot without proper checksum
HakenTT is offline   Reply With Quote
Old 11-26-2013, 12:12 AM   #85
p0lar
My Ride: E46 ///M3
Affirmative.
Confirmed.
The algorithm is the following? How does the following data constitute a checksum algorithm?
Code:
34 33 30 30 36 36 30 31 31 31 31 34 33 30 30 30
36 36 30 31 30 30 30 30 31 31 31 34 33 30 30 30
36 36 30 31 30 30 30 30 63 61 34 33 30 30 36 36
2E 44 41 54 FF FF FF FF
This seems more like versioning information, as follows by a basic breakout according to what seems like more common convention:
Code:
c566750k
430066
01
1114300066010000
1114300066010000
1114300066010000
ca430066.DAT
Didn't you just state that this was from 0x8 -> 0x4F? Now the part that isn't factored into the checksum calculation is now relevant as to how it's permuted? Ok, let's see from the original binary what's there...
Code:
      02 00 00 00 07 00 FF 2F 07 00 00 40 07 00
17 EE 07 00 FF FF FF FF FF FF FF FF FF FF 00 00
How does this bit correlate to what was previously posted from the start of the binary?
Pretty much like almost every other DME, correct.
Old 11-26-2013, 03:56 AM   #86
HakenTT
[/QUOTE]
The first one is algorithm if you change one byte the winols would not be able to make checksum correction. MS41 and MSS52/54 do not need proper checksum to run the engine.
Old 11-26-2013, 05:29 AM   #87
GrafSpee
My Ride: e46 330xi
WinOLS shows the change in checksum not.
You have to use an external editor to see the change.
The Checksumm would also be equal to the same operating system.
The checksum is present twice.
Once in the boot sector and once Eprom of the maps.
These are matched at the start.
It is important that both checksums are equal.
GrafSpee is offline   Reply With Quote
Old 11-26-2013, 07:04 PM   #88
p0lar
My Ride: E46 ///M3
The first one, meaning the first string of bytes at the beginning of the file that looks like versioning information?
So how was WinOLS able to make a checksum correction with a file full of 'FF's? It didn't cough or sputter on that at all.
My MSS52 and MSS54HP will NOT run with incorrect checksums - I tried both.
Old 11-26-2013, 07:07 PM   #89
p0lar
My Ride: E46 ///M3
I'm aware of this, I use a separate binary editor to see what the differences are. WinOLS is vastly inferior software in regards to raw binary editing.
What does this mean? It equals the operating system?
You mean in the 16kb boot sector, for only the boot sector, and for the 64kb of the parameter space at 0x3FE0?
So if you modify one byte in either the boot sector, OR parameter space, you must correct both?
I was only able to pull the 64kb parameter space using my Galletto 1260 cable, how do you pull and push the full 512kb?
The information [sic] provided in this thread is vague and very poorly worded.
Old 11-26-2013, 07:10 PM   #90
smooth1
My Ride: BMW FTW
You don't need to correct both. Just the parameter space.
smooth1 is offline   Reply With Quote
Old 11-26-2013, 07:28 PM   #91
p0lar
My Ride: E46 ///M3
Good information, thank you. Can you confirm the single 2-byte checksum at 0x3FE0 as well?
I'll continue to test how the checksums are calculated, but it seems not to be something as simple as what the MSS5x DMEs are, or not at first glance.
Old 11-27-2013, 09:31 PM   #92
TerraPhantm
My Ride: M3 & ZHP
Originally Posted by p0lar View Post
Ok, so no matter what changes seem to be made to the MS43 binary, only one location changes otherwise for me, 2 bytes at 0x3FE0. I don't believe the next 30 bytes are factored, but that doesn't help in the way the data is ordered when calculated, nor if there is a prefix much like the MSS52 and MSS54.
So, let's say the parameter space is chunked into exactly 16kb boundaries as follows:
segment 1 = 0x0000 -> 0x3FE0
segment 2 = 0x4000 -> 0x7FFF
segment 3 = 0x8000 -> 0xBFFF
segment 4 = 0xC000 -> 0xFFFF
I've tried running the same CRC16 used on the MSS5x DMEs in the following orders:
2,1,4,3
4,3,2,1
1,2,3,4
1,2,4,3
2,1,3,4
Plus, adding a prefix from 0x0000 -> 0xFFFF in advance of each run.
Thus far, I've hit on one match accidentally, but I believe that was a CRC16 collision as it didn't hold for any other instance. I know this is a brute force approach, but without a hint as to where to start, I'm not sure what else to try just yet.
I think it'd be best to create a program that calculates a checksum with any arbitrary start value. Basically something like
Code:
int findChecksumStart (byte[] ROM, int CSIndex)
    for (int i = 0; i < CSIndex; ++i)
        if (crc16(ROM, i, CSIndex) == ROM[CSIndex-1]*16+ROM[CSIndex])
            return i;
        return -1;
If that doesn't work for any of the possible orders, then either there's a prefix we don't know, it's not a CRC16, or the polynomial is non-standard. Might be worth writing a function that goes in the other direction too (start is always 0, last checked byte is at some point before the checksum)
Old 11-28-2013, 09:44 AM   #93
p0lar
My Ride: E46 ///M3
Code:
            return i;
        return -1;
That's more or less what I tried, albeit when testing with a sea of 'FF's rather than actual data, I could just vary the length of the data rather than concerning over its contents or the segment order therein. I also wrote in a separate layer that would try various CRC polynomials, without success (yet). I'll work on it more after the holidays, but I'm sure it will become apparent with more study.
Old 12-09-2013, 10:07 PM   #94
jony787
My Ride: 318ti M52tu SWAP
Comprehensive MS43 DME Information
EWS DELETE IS POSSIBLE. Im able to delete or virginize any ms42, or MS43. Pm for details.
jony787 is offline   Reply With Quote
Old 12-10-2013, 03:00 AM   #95
krzychulbl
My Ride: e36
hello, I need euro EU2 catless file in normal open *.bin format... Can you help me?
krzychulbl is offline   Reply With Quote
Old 12-10-2013, 07:27 AM   #96
jony787
What version do you have?????
Old 12-10-2013, 09:25 AM   #97
krzychulbl
My Ride: e36
7509942 ms43 m54b30
I need normal bin format for flashing not winkfp
Old 12-10-2013, 03:27 PM   #98
daniel_f.
My Ride: 330iC
i can provide you some files, but just 64kb. the 512kb files include complete VIN and im just to lazy to manually delete them.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 12-11-2013, 03:56 AM   #99
new//M3fan
My Ride: 77' 924 87' E30
7509942 ms43 m54b30
Just update your ecu to the latest, and follow the guide below to run a cat-less tune.
http://forum.e46fanatics.com/showthr...137&highlight=
Then turn on EOBD (address has been identified) and have someone tune it to your motor or I can send you the one I am running.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 12-11-2013, 03:59 AM   #100
krzychulbl
My Ride: e36
64kb is ok
