Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 03-03-2014, 04:31 AM   #121
GrafSpee
My Ride: e46 330xi
I have the problem with the checksum even when the GS20 EGS .
However, I try it another way.
I use a program by which the data for the ECU to be created.
It generates from the *. 'm Oda * and * opa files .
When you create a signature may or must be created.
This signature is read from a file. (*. xml)
In the development phase of the software is running unprotected .
So unsigned or with a free code in the signature.
With a 0000.xml signature , it is possible legwork without checksum .
The checksum is stored in the operating system .
With the same signature code, the files must be created for the customer memory.
There are three sections for storage .
The boot area (BAF , OBA )
The operating system area . (PAF , OPA)
The mapped area . ( DAF, ODA)
I think that the boot area complete the SPI is .
I must explore the area in which takes place the calculation.
I'm sure if you can not write the serial range with WinKFP .
If it is possible , you could try and flash without signature.
GrafSpee is offline   Reply With Quote
Old 04-16-2014, 11:51 AM   #122
daniel_f.
My Ride: 330iC
http://www.madi-auto.ru/company/articles4/6/
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 04-24-2014, 06:14 PM   #123
Thaniel
My Ride: 06 E90, 01 330
Here's an XDF from the A2L
Hello everyone,
Thought I would add some here. Being new to ECU tuning I'm trying to learn what I can. One thing I've done is to take the A2L that was posted on the web and turn it into a XDF. It has been a good learning experience. Actually converting the MS43 was my second conversion. I did the MS42 first. I use excel to more or less convert it in bulk. It does require some hand tweaking but it's manageable. I've posted a copy of the MS43 (and an MS42) XDF on my google drive along with a .bin file that appears to mate fairly well with the data.
Link to my google drive
https://drive.google.com/#folders/0B...Ut1YkJlZUN6cmc
Hope the XDF is useful.
Personally i'm more interested in the MS42 at the moment but would like to help with the MS43 as well. To me, a beginner, it seems there are multiple versions of the MS43 DME. Would it make sense to make a list of all the versions and then create XDF's for each one? We could also include the information mentioned in this thread. Though I'm often unclear what software version it applies to or if it applies to all of them. I'd be happy to consolidate if someone can clear it up for me.
With the data the way I have it I could translate the existing XDF to the other addresses for other MS43 software versions IF someone could supply the addresses for the maps, curves, axis points and scalers in the other DME. (I'm in the process of trying to match up the MS42 for the 323i using a 323i A2L).
I'll also throw this out there, if someone wanted to offer their knowledge on MS42's I'd like to learn some of those things that no one seems to want to post :-)
And I'm still unclear on if or how we can calculate a checksum in TunerPro
Thaniel
My LS1 V8 into E36 and then E46 Blog
www.LS1BMW.blogspot.com
Thaniel is offline   Reply With Quote
Old 04-24-2014, 09:30 PM   #124
HakenTT
My Ride: 323i with S54
ms43 xdf looks good. Problem is that you can't flash the full flash as of now.
HakenTT is offline   Reply With Quote
Old 04-25-2014, 06:56 AM   #125
jolaine
My Ride: E46 330 cabrio
Awesome. Everybody should share openly like this instead of using information only for themselves. It benefits everybody. Id love to do things on my bmw that are everyday possible on my Honda with hondata K-Pro & stock ecu. I'll definitely contribute in any way I can.
What's left? Doing xdf for all the versiona and a free for all checksum calculator?
jolaine is offline   Reply With Quote
Old 04-25-2014, 07:44 AM   #126
Thaniel
Glad they look good. I don't have the experience to know if any of the info looks correct.
I expect most people won't need to do a full flash. I haven't tried it yet but it looks like a partial .bin can be loaded and the XDF still used. Someone with more TunerPro experience might no better. For sure one could extract just the part of the .bin they want and use that.
From my very inexperienced view our needs are:
-A good easy way to calculate checksums.
-Need understand what the maps, curves actually really do. Or at least find the ones that do what it is we want to do. And validate that the addresses we have are correct (test).
-And create the information (XDF) for the versions of software that we want to tune.
As a side note. Seems most everyone is keyed into TunerPro. But there is another free piece of software I came across that can read an A2L file directly. http://jnachbaur.de/ASAP2Demo/ASAP2.html It's another tool to look at. Doesn't solve the above problems but it does make such pretty graphs .
Thaniel
Old 05-05-2014, 11:16 AM   #127
Thaniel
Hello all. Me again.
Seems many things I learn about the MS42 A2L apply to the MS43. In this case it is the way the data is set up in the tables. Row wise or column wise. The A2L clearly states"FNC_VALUES 1 UBYTE COLUMN_DIR DIRECT". But in using the software that uses the A2L and Tunerpro the data does not look right.
Some more detail in my post here:
http://forum.e46fanatics.com/showpos...5&postcount=24
Here are 2 examples from the MS43. Column wise on the left (per the A2L) and row wise on the right. Row wise has to be correct.
I'll be posting updated A2L's and XDF's on my google drive. I've also noticed that none of the MS43 .bin's I have match the A2L exactly. The MS42 ones I'm looking at match much much better. If someone has a selection of different version .bin's from the MS43 take a look and see if one fits better. we could translate one into the others but need a very good matching one to start with.
Thaniel
ID:	557098   Click image for larger version
Old 05-06-2014, 11:41 AM   #128
Thaniel
Updated MS42 &MS43 .A2L and .XDF posted https://drive.google.com/#folders/0B...Ut1YkJlZUN6cmc
Old 05-11-2014, 03:02 PM   #129
Codeman
My Ride: 325xi, M Roadster
What ZUSB code would I need for my car? It's a 2001 325xi manual (M54 engine) and I want EU3 emissions. Would it be any of these? The only one with EU3 also says Japan and Automatic...
Codeman is offline   Reply With Quote
Old 05-18-2014, 11:48 AM   #130
randallcr
My Ride: 330ci
Hello
Hello.
Guys, I've been reading a lot about ms43 DME development in this forum and I must say that you guys have done a lot of work , congrats , is good to see dedicated people working on this, Hakken and others, I understand the work finding the maps, I've done it before for other cars and its hard work ...
After reading this and other posts I came up with some questions , hope someone can help me out.
I read that after reflashing DME after 12 times , DME will not let reflash anymore , unless is partial flash ? , I use KWP2000 , I bought a galletto cable also but its on its way . using kwp2000 will make this count go further until it locks ?
I never had problems with checksum cause I never had to recalculate them myself, so , in this case , Using hakken xdf and my downloaded bin file I modified maps and as expected car wont start because checksum was not recalculated , then , I read that you can do that with winols , I tried but not succesful probably because its the free version I believe. I read also that somebody here created a small win32 app to correct the checksum , should I get that ? and that will work for all checksum correction I need in the future ? this app works only with ms43 ?
then I guess the last one is regarding the o2 sensors , there is no oem manifold anymore in my car , I bought the car and it came with headers ... so o2 sensors are getting my check engine light on all the time , what can you do here ?
Thanks in advance for all the help. my car is a 330ci e46 2001.
randallcr is offline   Reply With Quote
Old 06-24-2014, 04:06 PM   #131
phatty123
My Ride: 330ci
Originally Posted by xbyte View Post
DTC removal on ms43 are not more difficult on ms43 than the mssXX, you just have to spend some time to understand how the dtc`s are stored in the file.
You can not expect it to be at the same format as the mssXX, that would be too easy
use 30 minutes (i`m slow ) and you would understand it, there is already posted an ols file with a few dtc`s disabled here on this forum.
Hi a bit of a newb to this side of the world, I have a spare ms43 to play with, I copied the ISN # by copying the 3ED0-3EEF from original into the DME used for experimenting. After I sync ISN with a scantool and car runs, it has the wrong vin but I'm not concerned about that. What I want to experiment with now is DTC removal. I spent some time researching by doing hex compare of different ms43 full dumps from the flash chip.
I dont have winols software so I wasnt able to use the file in the first post to see how its done in winols. Can you share a hint to point me in the right direction?
phatty123 is offline   Reply With Quote
Old 06-24-2014, 09:45 PM   #132
jony787
My Ride: 318ti M52tu SWAP
Finally someone beside me found how to virginize DME, in case you didn't know. Change those 6 bytes to FF and you got a virginize DME ready to align.
jony787 is offline   Reply With Quote
Old 06-25-2014, 08:37 AM   #133
RCase
My Ride: 2001 325i Touring
Are there any learning BMW DME for dummies threads? I would like to learn specifically about the interfaces, the parameters, how the architecture works et al.
I appreciate anyone's advice!
Mobile Post
2001 Touring
2005 M3 Very
2000 E46 323i Touring / JB / "BW"
2001 E46 "M3" Touring / Alpine / "WW1"
2008 E90 M3 / Jerez/ 6 Speed / FBO / "M3"
2015 F31 328d / MSport / Alpine/ "WW2"
RCase is offline   Reply With Quote
Old 06-25-2014, 10:49 AM   #134
Thaniel
Thanks for joining the conversation. Are you able to write 3ED0-3EEF through the OBDII port or does it require removing the Chip from the DME? just FYI incase it means anything. On my 330i only 3ED4 - 3ED9 have data. The rest are FF's (for a considerable distance before and after)
I started to look at the DTC removal on the M DME thread. But I wasn't sure if that portion of the DME could be accessed through the OBDII port. What have you found in regards to equiptment required to change them?
Thaniel
Old 06-25-2014, 10:54 AM   #135
Thaniel
This one for the MS54 is the closest thing I've seen
http://www.mss54.info/scripts/DME%20...o%20v0.0.3.pdf
Old 06-25-2014, 12:19 PM   #136
phatty123
My Ride: 330ci
Thaniel
I use hot air to remove the memory then read it. I still haven't found how the dtc are stored.
Old 06-25-2014, 01:10 PM   #137
HakenTT
Not true. With FF all you do is erase the alignment code. Alignment code must match the EWS3.3 unit.
Yes, that is what you have to do to virgin ecu to make it possible to align.
PS. all DTC codes are inside the partial read flash and they are easy to erase.
Old 06-25-2014, 01:18 PM   #138
phatty123
My Ride: 330ci
Plus that won't fix the vin it's not far from isn but it's encrypted. I don't really care about that I'm using a spare dme to experiment
Old 06-25-2014, 01:36 PM   #139
daniel_f.
My Ride: 330iC
The formula for encrypting the VIN has been revealed some time ago and terraphantm wrote a programm to claculate it.
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 06-26-2014, 04:43 PM   #140
phatty123
My Ride: 330ci
I believe I found it just need to try it out. Girlfriend driving the car now need to get it back to test it out
