Sponsored by BimmerWorld
Old 10-14-2013, 03:56 PM   #1
E46conv325
My Ride: 02 325ci Convertible
Hissing sound from brake
Hello all - I am getting this hissing sound almost like an air leak coming from the brake pedal/brake booster area. When I press the brake pedal it goes away but as soon as I release the pedal it comes back. I visually checked the hose that goes into the booster and it seems ok. Any thoughts on diagnosing the issue? I didn't want to assume the booster was going bad automatically. Thanks!
E46conv325 is offline   Reply With Quote
Old 10-15-2013, 09:26 PM   #2
Importluv
My Ride: BMW
You have a leak in the brake booster. It simply needs to be replaced. I had the same issue as you mentioned, and it only gotten worse. I let it go on for a few months until I got fed up with the car stalling out several times a day. It disappeared as soon as I replaced the booster.
Importluv is offline   Reply With Quote
Old 10-15-2013, 09:30 PM   #3
E46conv325
Importluv - how much was the new booster? Did you buy oem from dealer or aftermarket and is there a difference between the two?
Old 10-15-2013, 09:36 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Did you make sure the hose end is pushed into the booster...it's just a pressure fit...might just be loose...or perhaps you have a leak elsewhere in the vac system.
Brake booster don't fail that often here as far as I know...though I know they've failed.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-15-2013, 11:28 PM   #5
Importluv
My Ride: BMW
My local auto supply chain store (autozon_) priced rebuilt ones, made by Cardone, for $130 with core exchange. I installed a used one, $75, in my car because money was tight for me at the time. OEM has them priced double that. I would buy a rebuilt one if I could do it over again to be honest.
It took me 7 hours to complete the replacement along with bleeding the brakes. Its easy to understand the process, just very time consuming.
Before I executed the booster replacement, I performed the carburetor cleaner test for vacuum leaks on hoses; no success with that.
The only part that's inside the cabin on the booster is the rubber boot and the steel shaft, so a loose hose is not a possible cause since he is hearing the hissing from inside the cabin when brake is not applied.
Old 11-10-2013, 04:42 PM   #6
jmejia4
My Ride: 330i
^ +1. My car was doing the same, removed the booster and being curios I opened up the old one, the rubber seal around the shaft had gone "dry" and pushed out of place so it was leaking when the pedal wasn't pressed.
jmejia4 is offline   Reply With Quote
Old 11-11-2013, 07:35 AM   #7
paraklas
My Ride: ESS TS2 320ci
http://forum.e46fanatics.com/showthr...+brake+booster
