The Showroom
Old 10-14-2013, 04:05 PM   #1
mwt330i
My Ride: 2004 330i 6speed
Glamor pics of my Z4 Roadster
My friends tease me because I'm always cleaning the car and never driving it. So here is proof that I actually do drive it. My wife and I took a spin down to the Catskills today and rode over the Rip Van Winkle bridge with the top down. It was 68F and sunny. Did about 120 miles today just cruising the back roads and enjoying the countryside of southeastern NY. Here are a couple of pics of my "show car". I'm so neurotic that I put special brake pads on last week that don't make black dust and dirty the wheels. I also painted the rotor hubs to freshen it up...
Name:	Oct 14 2013 001.jpg
ID:	530815   Click image for larger version
Name:	Oct 14 2013 003.jpg
mwt330i is offline   Reply With Quote
Old 10-14-2013, 04:25 PM   #2
hitbyastick
My Ride: 2002 325i
Nice Z4, but you do know that braking will wear one thing or another. Those low-dust pads might not soil the wheels as fast, but they are wearing the rotors out faster than OE. Just saying.
Maybe your obsession with clean supercedes your concern for wearing parts out prematurely. I always found the OE brake pads stopped better.
hitbyastick is offline   Reply With Quote
Old 10-14-2013, 04:34 PM   #3
My Ride: Lexus
^ not sure if that first sentence is true. even if it is though, rotors are to be changed with every pad change anyway. so moot point.
Old 10-14-2013, 04:38 PM   #4
tachi1247
My Ride: '04 330i
Re: Glamor pics of my Z4 Roadster
Is this another "mango maintenance schedule" item or is this actually in print from BMW somewhere?
tachi1247 is offline   Reply With Quote
Old 10-14-2013, 04:51 PM   #5
ian02
My Ride: 05 325ci
Common knowledge throughout the BMW community. Techs/parts guys/aftermarket/dealership service depts, etc all say the same thing. If you look on the side of the hat of the rotor you will see a minimum thickness measurement in millimeters, when you wear through a set of pads you should be at or very near this measurement.
This is also why those same people will tell you not to turn rotors for BMW's. They are meant to be replaced with each pad change.
ian02 is offline   Reply With Quote
Old 10-14-2013, 04:55 PM   #6
tachi1247
My Ride: '04 330i
Yes, if your rotors are below the minimum thickness etched onto the rotor then they need to be replaced, but if they aren't, they should be good until the next pad change. That is true with every car. It may be the case that the rotors and pads both need replacing, but it isn't automatic or always necessary.
Old 10-14-2013, 04:57 PM   #7
My Ride: Lexus
when dealing with brakes, i don't muck around. just replace it together. it's safest and provides the best performance
Old 10-14-2013, 04:58 PM   #8
hitbyastick
My Ride: 2002 325i
It's true though.
Changing rotors with pads is good practice I suppose, no doubt recommended by BMW and probably better warranted when using low-dust pads since they chew the rotors faster as they are usually of a semi-metallic composition vs OE organic. But there are new alternatives that might address both dust & rotor wear, so your point about the moot point might be a valid point.
For me, I generally mic the rotors until the minimum is reached then I wear that set of pads out & change everything the next time around. Never really had a problem with fade or pulsation with the way i drive. I have absolutely nothing but respect for people who change parts out preventively and used to do it myself. I have MB experience mostly though, and MB parts are really much more expensive than BMW. Like OE waterpumps are $350, and this would be for a '95 E320 for example. Not being a fan of aftermarket generally had me spending a lot of money on proper repairs. I've gotten to the point where I'm just sick and tired of the constant monetary hemorrhaging so I have begun to tighten the purse strings and be a lot more critical of the repairs I now perform.
Old 10-15-2013, 08:49 AM   #9
mwt330i
I actually did replace the rotors.....ECS Tuning had brembos for the same price as you'd pay for regular auto parts store brands.....The brake pads in question are Wearever Gold which I have used on cars for years and they don't seem to cause additional wear on the rotors. They are a semi metallic pad, but don't seem to throw brake dust like some OEM's do...
Old 10-15-2013, 11:51 AM   #10
wdeerfield
wdeerfield's Avatar
My Ride: 2009 E90, 2011 F10
i think you may be the first forum member to put "wearevers" on a bmw. i like the z4 and the RVW bridge is a great area and drive.
2013 EB 335i xdrive | Msport | Coral | DHP | ZPP | ZCW | ZTP | 400M | Coded | MPerformance Bits | M3 Grills | Painted Reflectors | BMS Exhaust Tips | LED Turn Signals
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
wdeerfield is offline   Reply With Quote
Old 10-15-2013, 05:55 PM   #11
dubsesd
My Ride: dub
Very nice. Beautiful car!
2006 ///M Coupe TiAg / IR -- H&R coilovers/RPI exhaust/ZHP knob/19" Morr vs8.2 hand brushed/Stoptech 355mm 6/4 BBK/Michelin PSS/gloss black kidneys/painted gloss black roof/mstache 2 front lip/AFE dry intake/colormatch corners/black chrome //M badges/rear diffuser/aeroskirts/rogue mounts/DKF adjustable hangers/22%tint/euromode lighting/LED interior & plate lighting/BMW black pedals
dubsesd is offline   Reply With Quote
Old 10-15-2013, 11:45 PM   #12
saxual328ci
My Ride: 2004 325ci
Nice Z4. I love those rims
saxual328ci is offline   Reply With Quote
Old 10-16-2013, 10:03 PM   #13
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
It's true though.
This is the way to do it.
Chris
dreamdrivedrift is online now   Reply With Quote
Old 10-16-2013, 10:10 PM   #14
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
This.
Nice Z, OP!
Bimmer4Lyfe is offline   Reply With Quote
