Sponsored by The Tire Rack
Old 10-14-2013, 04:46 PM   #1
MrSlacker
My Ride: E46 330xi, E30 318iS
Is it OK to run 205/50 on Style 44 for winter?
I have a set of winter tires in 205/50/17 that came with my car. I know ideal wheel size would be 17x7. However, a friend of mine has Style 44s which are 17x8 that he is willing to sell for dirt cheap. Will I be OK stretching 205/50 onto 8" wheel or is it a bad idea? This will be for winter tires only.
Thanks in advance!
MrSlacker is offline   Reply With Quote
Old 10-15-2013, 11:25 AM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Use 225/45R17 for 17X8 wheels. 205/50R17 lists the maximum recommended rim width as 17X7.5.
Tires http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 10-15-2013, 11:29 AM   #3
MrSlacker
Gary, I appreciate the reply, but you clearly did not read my post. I already own 205/50 tires so I am looking for options of making my current tires work.
Old 10-15-2013, 06:40 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Gary answered your question perfectly. Your existing tires will be stretched, as the maximum approved rim width for that tire is 17x7.5.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 10-16-2013, 08:11 AM   #5
Rudy@Tirerack
Moderator
I read your post clearly and answered your question precisely. To expand further on it, the complete rim width range of 205/50R17 tires is 5.5"-7.5".
If you buy those 17X8 wheels, you'll need to use tires that are 225/45R17.
Old 11-10-2013, 08:40 PM   #6
conan32117
My Ride: 2003 330i
is there a chart that shows minimum/maximum rim sizes for different size tires?
conan32117 is offline   Reply With Quote
Old 11-11-2013, 08:48 AM   #7
Rudy@Tirerack
Moderator
There probably is online somewhere, but they way I do it is to check whatever tire size is in question. IE: 225/45R17 lists 7.00" to 8.50" .
Old 11-11-2013, 01:43 PM   #8
VMRWheels
VMRWheels's Avatar
Tirerack specifies all that information right on each tire in a specific size. Just click on the specs tab.
Old 11-17-2013, 04:31 PM   #9
BRYGUY1086
My Ride: 2001 330ci
Gary, I found when selecting my 330ci w/ sport package on Tirerack.com, it defaults to 205/50 R17. Can you please correct this? The factory specs for the rear are 17x8.5, therefore, the tires would not fit
BRYGUY1086 is offline   Reply With Quote
