Old 10-14-2013, 09:14 PM   #1
GRK///M3
My Ride: LSB M3
Hooking up the VSS on an HPF
Does anyone know where the VSS wire from the HPF wire harness gets hooked up in or around the ECU? Its a 6 speed manual.
ID:	530870Click image for larger version
Any help would be appreciated!
GRK///M3 is online now   Reply With Quote
Old 10-17-2013, 12:12 AM   #2
E46 4m3
My Ride: 2003 M3
I would like to do as well. I was originally going to tap into sensor by tranny. But maybe someone with hpf traction control can give us pin out. So we know which wires are VSS
E46 4m3 is offline   Reply With Quote
Old 10-17-2013, 12:35 AM   #3
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Attachment 530870Attachment 530871
FYI: AEM Gen 2 VSS pin A23
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 10-17-2013, 12:36 AM   #4
being3
Modded ///Member
being3's Avatar
AEM Gen 2 TC = A7 Gnd, A8 Pwr, A9 signal . U will need the TC switch module. Not sure what's kind of circuit is involved inside of it.
Old 10-17-2013, 12:54 AM   #5
being3
Modded ///Member
being3's Avatar
I have in my notes that pin 22 on the 40pin black connector on the ECM is VSS. I don't know how I figured this out as I did it a while back and it has not been verified.
Old 10-17-2013, 10:46 AM   #6
GRK///M3
My Ride: LSB M3
Re: Hooking up the VSS on an HPF
Originally Posted by being3 View Post
I have in my notes that pin 17 on the 40pin black connector on the ECM is VSS. I don't know how I figured this out as I did it a while back and it has not been verified.
Thank you.
Old 10-20-2013, 03:16 AM   #7
being3
Modded ///Member
being3's Avatar
Thank you.
Your welcome. Here is the exact info for the DME also found EGT info
DME connector layout
VSS pin 17 on 40 pin black connector and wheel speed sensor pin 22 same connector.
24 pin black connector pin 10 is EGT ... For possible wiring into AEM... Still need to identify AEM PIN number and I have a plan to find it if it exists in the HPF hardware version.
Old 10-20-2013, 07:54 AM   #8
Cipri
My Ride: E46 M3 2002
Anthony for Version 1 did you manage to find out the PINs?
Cipri is offline   Reply With Quote
Old 10-20-2013, 09:13 AM   #9
being3
Modded ///Member
being3's Avatar
As far as I can see VSS is pin B33 on AEM Gen 1. I traced it out from the AEM to the connector on the harness.
Old 04-03-2014, 11:10 AM   #10
Simo17
My Ride: M3
Hi guys, I recently buyed a used HPF Turbo Kit for M3 E46 with HPF Traction control, but I have a problem because I don't understand where install the connector vss, I have two cable, one black (ground) and one green, this where I must to install.....because if not my car don't run over 4000 rpm.....
Simo17 is offline   Reply With Quote
Old 04-03-2014, 01:02 PM   #11
being3
Modded ///Member
being3's Avatar
U can get around the rpm limiter if u set the 2 step rpm limit to 8k until u wire up VSS...on pin22 DME to b33 Aem gen 1
Old 04-03-2014, 01:14 PM   #12
Simo17
My Ride: M3
Excuse me my incompetent, but I don't want make error, I can ask you a favour, you can draw the connection for this cable or if have a electrical diagram for 6 speed manual of 2001...thanks
Old 04-04-2014, 04:05 PM   #13
mike@maximumpsi
My Ride: 02M3T
I sent him over the info. He is up and running.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 04-04-2014, 04:43 PM   #14
being3
Modded ///Member
being3's Avatar
Ur the man....
Old 04-05-2014, 11:54 AM   #15
Simo17
My Ride: M3
Thanks Mike...!!.you are my hero...!!
Old 04-05-2014, 08:13 PM   #16
GRK///M3
My Ride: LSB M3
Can you send it to me as well I never figured this out.
Old 07-31-2014, 12:49 PM   #17
being3
Modded ///Member
being3's Avatar
Wire with white and green strip is VSS... I have heatshrink on it joining to sold green wire in pic that goes to 2 pn connector with one pin to chaises GND BLK and the GRN going to EMS VSS input pin
