Sponsored by BimmerWorld
Old 10-14-2013, 10:06 PM   #1
hermunn123
My Ride: '04 330i ZHP
Brake bleeding question
I'm in the process of bleeding my brakes. I haven't done it in the three years I've had it and I couldn't tell you when it was last bled.
I sucked out as much old brake fluid I could get from the brake fluid reservoir, then went to the right rear caliper. The fluid came out very dark, almost maroon. Nasty stuff. The fluid I'm putting in looks to be clear (I'll confirm in the day when I can see it better) and I've filled to 80% capacity TWO different 17oz water bottles and it still is coming out a light gold - much better from the dark maroon but it's not clear yet. I am topping off the reservoir as needed. I check it every few rounds.
How much fluid should I expect for it to take to flush the right rear line? I've got almost 32oz of expelled brake fluid... wouldn't think it would be that much.
Any help would be appreciated.
hermunn123 is offline   Reply With Quote
Old 10-14-2013, 10:12 PM   #2
cvx5832
My Ride: 325Ci, 325Cic, C300
Clarification - Did you suck out fluid from the reservoir then proceeded to bleed, without refilling the fluid in between?
cvx5832 is offline   Reply With Quote
Old 10-14-2013, 10:24 PM   #3
hermunn123
Re: Brake bleeding question
I did refill the reservoir after sucking out the old fluid, sorry for the confusion.
Old 10-14-2013, 11:19 PM   #4
Simon P.
My Ride: 330i
If you passed 32oz of new brake fluid then trust me, you've replaced it 5X already. You should be good now...
Question; why only the right rear? Why not do all 4 corners?
Simon P. is offline   Reply With Quote
Old 10-14-2013, 11:26 PM   #5
Mflara20
My Ride: 04 330i
What would my brake pedal feel if I ran out if brake fluid? Right now it feels very soft and spongy.
Mflara20 is offline   Reply With Quote
Old 10-14-2013, 11:26 PM   #6
Tangent_
My Ride: '01 330i, '11 Z435i
If you're concerned about the fluid being light gold instead of clear, do a full round of bleeding until you get that light gold and no bubbles at all wheels then go again. If you want to be really thorough don't forget the clutch slave if applicable. The slave is kind of a pain in the ass to do right though... You might be getting tiny amounts of old fluid contamination from the other wheel channels that'll take forever to clear until you flush them out as well.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 10-14-2013, 11:28 PM   #7
stevenluczynski
My Ride: Is Steel Blue
what do you mean exactly?
stevenluczynski is offline   Reply With Quote
Old 10-14-2013, 11:34 PM   #8
Mflara20
My Ride: 04 330i
I did a brake fluid flush with racing blue brake fluid from bavauto. My brake pedal feels very soft and spongy when brakes applied, the pedal goes almost half way down so the car can stop. I'm not sure when flushing if I ran out of fluid on the receivor, if I did can I just flush again to get my brake pedal to feel hard again?
Old 10-14-2013, 11:37 PM   #9
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Sounds like you didn't bleed it enough. Still air in the system
Old 10-14-2013, 11:40 PM   #10
Mflara20
My Ride: 04 330i
I was afraid I've blowed the master cylinder seal.
Old 10-14-2013, 11:51 PM   #11
stevenluczynski
hopefully you didn't get air in the abs system
Old 10-14-2013, 11:57 PM   #12
Mflara20
My Ride: 04 330i
That was I was fearing, to check it do I have to take it to the dealer and let them fix it or Can I use a software?
Old 10-14-2013, 11:58 PM   #13
peytonracer4
:D
My Ride: '00 328i
I think it goes like this:
With car running press on brakes. Hold brakes. If the pedal sinks, it's the master cylinder.
With car off pump brakes. Then press brakes and hold. If the pedal sinks, it's the brake booster.
If neither happen, you have air in your system and it just needs bled.
Old 10-15-2013, 03:44 AM   #14
Mflara20
My Ride: 04 330i
It sinks a little bit not all the way an I can hear like it's sucking/releasing air from the brake pedal area.
Old 10-15-2013, 04:48 AM   #15
Imanewbie
My Ride: is my crack.
You should only press the pedal a little more than half way if bleeding the vintage way, helps to not damage master. If air is stuck in the abs then you can pull off in gravel and lock up your brakes to engage abs a few times, the bleed again. that's the only way I know of besides the dealer. It sounds like air to me an just keep bleeding and bleeding, took me five rounds one time to get it out. Power bleeders are much better to use also.
iOS BimmerApp
Imanewbie is offline   Reply With Quote
Old 10-15-2013, 05:10 AM   #16
Mr Podman
My Ride: E46 Coupe
If you're going to bleed your brakes badly, there's no need to buy the more expensive racing performance brake fluid.
There is an established approach for bleeding that involves bleeding the caliper closest to the reservoir and then moving progressively to the one furthest away. The reason is simple. Just think it through.
Never let the reservoir run out of fluid. Let me say that again. Never let the reservoir run out of fluid.
If you put brand new clean gold colored brake fluid in the reservoir and you bleed it through the system, it will still be gold colored when it comes out the caliper bleed screw.
If you have half a bottle of brake fluid left over from your last bleed job, throw it away.
If you don't like the paint job on your car and want to remove it, pour brake fluid on it.
Mr Podman is offline   Reply With Quote
Old 10-15-2013, 06:11 AM   #17
Mflara20
My Ride: 04 330i
Thanks and I though you should start with the farthest caliper away from the receivor.
Old 10-15-2013, 06:12 AM   #18
Mflara20
My Ride: 04 330i
iOS BimmerApp
Thanks I'll do that.
Old 10-15-2013, 07:52 AM   #19
hermunn123
That's what I thought, I just wanted to make sure. I just started with the right rear and didn't want to switch to the next until I was positive I had flushed it enough. After I realized I had nearly gone through an entire container of fluid, I stopped because I thought that would have been plenty. I will flush the other three corners today.
I completely understand why the ATE Super Blue is so popular now. No confusion.
Thanks for the help all.
Old 10-15-2013, 09:34 AM   #20
Imanewbie
It's sad they are going to stop making super blue.
