Sponsored by BimmerWorld
Old 10-15-2013, 10:34 AM   #21
Imanewbie
My Ride: is my crack.
Brake bleeding question
Originally Posted by Mr Podman View Post
If you're going to bleed your brakes badly, there's no need to buy the more expensive racing performance brake fluid.
There is an established approach for bleeding that involves bleeding the caliper closest to the reservoir and then moving progressively to the one furthest away. The reason is simple. Just think it through.
Never let the reservoir run out of fluid. Let me say that again. Never let the reservoir run out of fluid.
If you put brand new clean gold colored brake fluid in the reservoir and you bleed it through the system, it will still be gold colored when it comes out the caliper bleed screw.
If you have half a bottle of brake fluid left over from your last bleed job, throw it away.
If you don't like the paint job on your car and want to remove it, pour brake fluid on it.
+1
Imanewbie is offline   Reply With Quote
Old 10-15-2013, 01:13 PM   #22
havnfun328
My Ride: '99 328i, '03 M5
Originally Posted by Mflara20 View Post
Thanks and I though you should start with the farthest caliper away from the reservoir.
That's what I always do: RR, LR, RF, LF, Clutch
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 10-15-2013, 01:51 PM   #23
Mr Podman
My Ride: E46 Coupe
There is a reason why you should start with the shortest one. Think about it in terms of contamination.
Mr Podman is offline   Reply With Quote
Old 10-15-2013, 09:01 PM   #24
havnfun328
Just saying that all the info out there says to start with the one farthest away.
Honestly, once you get past the proportioning valve, I doubt there's much difference.
Or I'm not seeing it.
Old 10-15-2013, 10:28 PM   #25
Imanewbie
Motive euro power bleeder is the only way I do it, and the only way I did it without any issues.
