Old 01-05-2014, 02:48 PM   #21
GuidoK
My Ride: Z4 3.0i ESS TS2+
What's the purpose of this modified harmonic damper?
Will it be lighter?
Or customisable in size? or a split setup? (like the s54; a separate pulley and a separate damper so an alternative size pulley is easier made)
E85 Z4 3.0i | ESS TS2+ | Quaife ATB LSD | Custom Brembo BBK front/rear | Schrick cams | Schmiedmann headers/cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers | Sachs performance clutch
GuidoK is offline   Reply With Quote
Old 01-20-2014, 12:25 PM   #22
johntrhodes81
My Ride: 2004 325i Wagon
Is this damper based on an early 5 rib ac pulley or the 2003 upgraded damper with 4 rib belt? What about am installation tool?
Sent from my SPH-L720 using BimmerApp mobile app
John
DIY BMW Performance Style Extra Air Intake
http://forum.e46fanatics.com/showthr...6523&highlight
johntrhodes81 is offline   Reply With Quote
Old 01-21-2014, 09:08 PM   #23
da Vinci
My Ride: 2003 BMW 330i ZHP
BMW changed from part number 11231438995 to 11237513862 in 09/2002. I think the only difference is the earlier model used a 5 rib belt for the air conditioning compressor and changed it to a 4 rib belt.
It looks like people can and do run a 4 rib belt on the 5 rib compressor.
We should be able to stir up a couple installation tools and circulate them. I have a machine shop and other people on this list have made the tool. It shouldn't be a problem.
Click here for my Build Thread
"Make everything as simple as possible, but not simpler." Albert Einstein
da Vinci is offline   Reply With Quote
Old 01-21-2014, 11:56 PM   #24
nleksan
My Ride: 328Ci, 325i, M3 ZCP
Send a message via AIM to nleksan
I MAY be in on this, if anyone can explain the benefits of one on a purely Street car...
(Temporary Sig)
- DPE - Volk - BBS - OE CSL - JRZ Race 4Way -
- M-Tech II - RE - AP Radi-CAL -
- Hotchkis - AFE - AKG - KW CS 4way -
- TMS - OS Giken - SS V1 - Vorsteiner - Recaro - Focal - JL - MORE! -
GARAGE:
-00 328Ci Topaz 6MT ZSP/ZPP/HID (Street) ESS TSE2+ 2980lb
-01 325i TiAg 5MT/ZSP/ZCW (Street) Track Susp/Brk/Whl 3102lb
-06 M3 AW/IR 6MT/ZCP/HID (Dual-purpose) NA Fully-Built 2810lb
nleksan is offline   Reply With Quote
Old 02-14-2014, 07:54 AM   #25
jolaine
My Ride: E46 330 cabrio
Anything new on this? I need a new harmonic damper on for my 330. The engine is out for some winter overhauling (its a cabrio) so that it will last for the next 200 000 km and I guess its a good idea to change this dampener. As a Honda enthusiast I've noticed that the M54 is quite rough when run closer to the redline and the redline is quite low. Maybe my dampener is not in good condition anymore after almost 200 000 km??
One of the reasons why I wanted to drop the engine is to check all things out, open the oil pan and check the oil pump nut. But I think that the nut going off is only the result of bad vibration that makes it come loose and the real reason (damper) needs to be fixed first. Then tighten the nut with some loctite and rev happily ever after.
If there is not any better solutions I'll just get a new OEM, but that will not fix the problem I guess.. *sigh* how hard can it be to get a good & working crankshaft wheel??
jolaine is offline   Reply With Quote
Old 02-26-2014, 01:10 AM   #26
jblack03zhp
My Ride: 330i zhp
I too am extremely interested in a upgraded damper. After selling a vehicle and still having a reliable DD I am gearing up to make the BMW more track ready as it sees less main road time and more garage queen status. Would like to get all the little things in order for track season so I can spend my weekends on the track with the boss instead of brown nosing it on the golf course(I suck at golf)
UUC Stage II Aluminum Flywheel/Perfomance Organic__UUC Evo 3 SSK & DSSR__UUC Underdrive Pulleys__Magnaflow__H&R Sport Cupkit__TMS Rear Camber Arms
__And tooo much other stuff
Originally Posted by Penguin Koolaid View Post
The difference being men don't make excuses to rationalize why it's okay. We do as we please. No fucks will be given. You ma'am, give a fuck.
jblack03zhp is offline   Reply With Quote
Old 03-03-2014, 04:16 PM   #27
spig
My Ride: 2003 330i ZHP 6spd
I am interested.
2003 E46 Silver Grey 330i ZHP 6MT
Dr. Vanos, BMW Performance SSK, Meyle HD RSM FCA & FCAB, E9x M3 motor mounts, Black kidney grills, Eagle eye LED tails, K&N drop in filter, E92 ZKW reflector bowl retrofit, Umnitza Orion V2 Opaque 6000k Angel Eyes.
spig is offline   Reply With Quote
Old 03-08-2014, 11:31 AM   #28
MOTRSPRT
My Ride: 2003 M3
Followed this thread over here from M3F. I'm interested in this group buy, but was hoping these balancers were already shipping as I need one NOW. Have money waiting to be spent for this.
Researched pricing for ATI's damper and refuse to spend $859ish for one of these. Hence, my snooping brought me over here for this group buy. Too bad it looks stagnant...
MOTRSPRT
2003 M3 SMG
1998 M3 Dinan SC
2006 Dodge CTD Megacab
1991 Nissan 300ZX TT
1993/95 Honda CBR900RR
2011 Ducati 1198 SB
MOTRSPRT is offline   Reply With Quote
Old 03-09-2014, 11:47 PM   #29
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I think getting a lighter damper is a big mistake. It will just make the harmonic issue worse. Especially if you pair it with a lightweight flywheel.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 04-26-2014, 12:11 AM   #30
mrbrightside
My Ride: 2004 BMW 330i
Hey everyone, new ZHP owner here. I really appreciate some of the information being shared here and I wanted to thank everyone for contributing.
I realize the Group Buy ended a long time ago and it sounds like ATI may no longer be making the harmonic damper any longer. Why then is the Super ATI Damper still listed on VAC's website:
http://store.vacmotorsports.com/harm...2-us-p756.aspx
Also, ~$1000 for essentially a tuned piece of rubber and pieces of aluminum seem extreme. I understand economies of scale, but at the same time, I can't seem to find any data to back up the claim that the ATI unit really does improve the durability of these motors at high RPMS. Can anyone lend some evidence now that some time has passed to accumulate more miles?_nr_
mrbrightside is offline   Reply With Quote
Old 04-28-2014, 01:02 PM   #31
da Vinci
Actually nothing has happened yet. I have been so busy with other projects, this one has sat dormant. I asked for permission, in case it is needed, to run this like a group buy and received no reply, either time. So I guess the next step is to send BHJ $200 and a sample to do the design work.
Are all of you still interested? If I there is enough interest I will pony up the $200 in hopes to recoup it by the time everyone has their new harmonic damper.
Old 05-28-2014, 04:18 PM   #32
da Vinci
I updated the link on my first post to their white paper which explains how and why... Click here
Other stuff from the BHJ Dynamics web site:
BHJ Dynamics offers specialty harmonic damper solutions for the performance automotive and marine aftermarket.
State of the art development technology and unexcelled craftsmanship make BHJ the ultimate choice for high performance, American made crankshaft harmonic dampers.
Engineering Services:
Custom Component Development Programs for specialized racing applications, vintage restoration and crate engine programs are also available in nearly unlimited configurations, whether S.F.I. certification is necessary or otherwise. Programs are available for a wide variety of budgets and production quantities. BHJ's state of the art damper design technology assures precise tuning for outstanding performance and long engine life in any operating environment. Contact us for more information on custom component development.
BHJ provides the ultimate performance harmonic damper solution for automotive, marine, aerospace and other specialty applications — all designed and crafted in the United States, from the finest materials available. Click here for an introduction to BHJ's crankshaft harmonic damper lineup, or click here to find out more about custom development services.
Old 05-30-2014, 12:59 PM   #33
ArmyBimmer
My Ride: 2003 M3
Im interested in this. Curious as to why ATI is so much more if this is a comparable product...
2003 ///M3: Daily
2001 330Ci: Totaled, part out!
1994 325is: S50 Turbo track rat, for sale
1987 325is: Sold!
ArmyBimmer is offline   Reply With Quote
Old 10-21-2015, 11:13 PM   #34
rkneeshaw
My Ride: 330i ZHP
Thread revival.
I just checked, and the rubber on my stock balancer is out of whack, so I am in need of a replacement.
I refuse to spend $1000 for the ATI piece.
So its either a new OEM balancer, or a reasonably priced aftermarket balancer.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 10-21-2015, 11:40 PM   #35
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by rkneeshaw View Post
Thread revival.
If you're not interested in spending ~$900 with VAC for an ATI Damper, I believe your two choices are:
1) BMW OE Damper #11231438995, ~$449 Shipped
http://www.turnermotorsport.com/p-12...q4gaAgBT8P8HAQ
2) Dayco PowerBond Damper #PB1565N, $327 Shipped
PowerBond by DAYCO / Premium OE Replacement Harmonic Balancers:
"PowerBond balancers use both inserted and pressure-bonded rubber that produces rubber strength that is stronger than competitive balancers."
http://www.summitracing.com/parts/pb...D04aAsOw8P8HAQ
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 10-22-2015, 02:38 AM   #36
GuidoK
According to realoem the current number for the balancer on his car is 11237513862 as far as I can see.
If he wants to go aftermarket he can do a lot better by for example this Febi branded one:
https://www.ecstuning.com/BMW-E46-33....0L/ES2697669/
Here in europe we can also get brands like Gates for similar money.
I don't know who the OEM supplier is for this piece.
Old 10-22-2015, 02:59 AM   #37
Rob43
Rob43's Avatar
What you euro guys don't know is that PowerBond Dampers are actually a major player in the world of high performance dampers, if I didn't already own an ATI Super Damper; I install a Dayco PowerBond over a BMW OE damper.
As far as BMW OE part numbers go, the #11231438995 still looks correct.
Rob43
Old 10-22-2015, 03:16 AM   #38
GuidoK
We get the dayco stuff too in europe.
11231438995 is a discontinued partnumber.
11 23 7 513 862 is the current registred number in the official BMW ETK.
Old 10-22-2015, 03:36 AM   #39
Rob43
Rob43's Avatar
I'm glad to hear that you do....
Rob43
Name:	Screenshot 2015-10-22 at 3.33.41 AM.jpg
Old 10-22-2015, 04:06 AM   #40
GuidoK
This is a screenshot from the webETK, which is the official partsportal from BMW AG.
I've translated the dutch as the portal recognizes the country from my IP and sets the language settings accordingly, but it clearly states that 11231438995 is superseded by 11237513862
So this is official info from how BMW AG numbers their parts.
Your screenshot also displays 'up to 9/2002'...
It is a part that was produced from Jan '00 to sept '02, so if you buy a part with that particular number on the label, you get a part that has been sitting in a warehouse for a really really long time. (but I doubt that anyone will/can deliver that specific part, you'll probably get the new one anyway).
Before jan '00 the part had the number 11231432471 (from '97 to '00)
I don't know if or what the physical differences are though between these 3 parts, could be material related or so.
