Sponsored by BimmerWorld
Old 10-15-2013, 04:57 PM   #1
dragoncoach
My Ride: '03 325it/Jetta TDI
Need opinions on lower control bushings
Got the wagon 4weeks ago. The front end "clunk" from the bushings is present but not pronounced. I don't beat on it or drive it very hard but need opinions as to whether or not they should be changed soon or if there really isn't any rush. It's only noticeable if I step on the brakes hard and release and repeat, not during regular driving. When they need replacing, I will change not only the bushings but the whole assembly as the car has 100k miles. Advice?
dragoncoach is offline   Reply With Quote
Old 10-15-2013, 05:02 PM   #2
My Ride: Lexus
not an absolute emergency but i would get to it sooner than later to save tire wear and unnecessary wear/tear on other components
Old 10-15-2013, 05:06 PM   #3
Gus330vrum
My Ride: 330ci
Its better you wait then Change the whole assembly and inner ball joints and look if tie rod rubber leaking .. If so replace it...
Thats of course if you want a tight steering.
but before you replace all that, make sure your shocks are not blown or they will cause steering parts like i mention to fail faster.
Gus330vrum is offline   Reply With Quote
Old 10-15-2013, 05:07 PM   #4
dragoncoach
Do lower arm control bushings in good condition, have no play at all? Or do all of them have a little play? Will probably go with OEM when I replace as I don't want the steering to be overly stiff for the wife with urathane bushings.
Old 10-15-2013, 08:11 PM   #5
vandyboy
My Ride: 2001 325i
Go ahead and replace the bushings. There is no need to wait until the whole control arm needs replacing. They are bolt on parts and you can still use the replacements if you have to put on a new control arm.
I used the Meyle HDs in my car, but the OEM are great, too. You should have vibration that will be eliminated with new bushings.
vandyboy is offline   Reply With Quote
