Sponsored by BimmerWorld
Old 10-16-2013, 01:45 AM   #1
Ryan87LX
My Ride: 03 325i
Time to replace Meyle HD Outer Ball Joint
Looks like I got a bum part - the Meyle HD control arms that I installed two years ago have failed. Rather, the passenger side outer ball joint has failed.
Everything else is nice and tight, so I'd like to attempt the ball joint replacement only.
I'm sure someone else has done this. Can it be done on the car with one of the "C" clamp ball joint presses?
Any tips?
I did search, but didn't find anything.
Thanks!
Ryan87LX is offline   Reply With Quote
Old 10-20-2013, 12:34 PM   #2
curca
My Ride: 2002 325i
I am intrested replacing failed meyle balljoint, has anybody done it? how hard was it, thanks
curca is offline   Reply With Quote
Old 10-22-2013, 09:22 AM   #3
teamdfl
Slow in, slower out
My Ride: 325it
Any tips?
Thanks!
I'm sure it can be done on the car with the right tools. I have seen E36 outer ball joints replaced this way. The problem is you need the E46 specific tooling. Good luck finding it.
I have pressed in new ball joints with the control arm out of the car. It was a minor PITA because I had to make several mandrels for removal and installation. Also, whacking the inner ball joint with a pickle fork to pull the control arm can tear the boot requiring replacement of that ball joint as well. Of course, the tooling to remove/install the inner ball joint is not the same size as the tooling for the outer joint.
I have ZHP control arms in the garage waiting to be installed in my E46 because I'm tired of crappy, rubber potted E46 ball joints.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 10-22-2013, 10:09 AM   #4
curca
My Ride: 2002 325i
thats sucks! some website sell both balljoints for little over $60, am better of buy optimum CA for $20 more and i dont have to worry about getting right tool
Old 10-22-2013, 10:12 AM   #5
My Ride: Lexus
uhh
