E46 Convertible
Old 10-16-2013, 10:34 AM   #1
Vic Harder
My Ride: 2002 M3 Vert
foreign object stuck in mechanism
I think I have a problem not seen here before. The top is in excellent working condition. I was installing a child seat. The tether goes under the headrest and latches behind it. Unfortunately, unlike the previous times I did this, the plastic and metal part of the tether got in between the soft top storage compartment lid as I was closing the to and the top was unable to close all the way.
It will keep trying if you push the (now flashing red) close button, but because of the obstruction, it won't finish the cycle. The storage compartment lid is about 1 cm from being all the way closed.
The top will not open using the button. The emergency release button does nothing because the front latches are not latched yet. The small hand crank can't move the top storage lid because it appears to have so much torque on the gears that it is jammed.
Dealer can't is so busy they can't see the car for two weeks.
Any ideas?
Name:	IMG_5787 - Copy.JPG
ID:	531043   Click image for larger version
Name:	IMG_5789 - Copy.JPG
Vic Harder is offline   Reply With Quote
Old 10-16-2013, 11:16 AM   #2
taylor192
My Ride: 2003.5 M3
I'm confused what you're trying to do. If you want to open the storage lid to remove the obstruction then push the release button under the rear seat and turn the motor. If it is tough to turn in one direction, turn the other way.
I'm willing to bet the front latches have engaged a bit and are forcing the top down onto the storage lid. Can you bend the top nearest the windshield? If no, then get out the allen key and turn the front until this latch disengages:
Old 10-16-2013, 11:47 AM   #3
Vic Harder
thanks for the quick reply. No, the header is not latched. I tried to get to latch by assisting it with some hand pressure, no go. I can lift the header end as well as the back end up a good distance (I can get the back end with the rear window to go about vertical) by hand. The deck lid is pressing very firmly on the baby seat tether and won't budge. I've tried moving the deck lid using the crank... with a lot of pressure, both ways. I have an allen key socket that size, so I could attach it to a breaker bar, but that seems like it might bust something else.
Somehow I need to tell the top mechanism that it is fully closed so that it will try to open it again.
Old 10-16-2013, 11:51 AM   #4
taylor192
My Ride: 2003.5 M3
Originally Posted by Vic Harder View Post
not sure how much force to put on that?
As much as needed. Remove your rear seat bottom, open this cover and check the position of the cables. If they are NOT like this the motor has latched the lid and you need to disengage it to get the cables into this position.
Old 10-16-2013, 11:53 AM   #5
cityjohn
My Ride: 2001 M3
The crank under the rear seat turns one way (I think clockwise) to move it both up and down. If you keep turning, eventually the latches will release.
Once it's open, replace the popout gear and the auto function should resume.
cityjohn is offline   Reply With Quote
Old 10-16-2013, 12:01 PM   #6
Vic Harder
They were not in that position. Once I had the seat out and the cover off to look at the cables I could see that the button incorporates a ball bearing in the release mechanism. I pushed on the button REALLY HARD, and it let go. The tether mechanism has been removed so now the obstruction is gone. Yeah!
Is there a special procedure to get the top working again now that the mechanism has been released?
Or do I just push the button and it magically closes?
Old 10-16-2013, 12:11 PM   #7
taylor192
My Ride: 2003.5 M3
No special procedure, the top should recognize what position it is in and start from there. I would manually move the top to the closed position, then push the close button until it latches to the windshield.
Old 10-16-2013, 12:26 PM   #8
Vic Harder
yep... just cranked the mechanism to ensure the button had popped up again, positioned the top to mostly closed, and pressed the close button until in latched. Then cycled it all the way open to be sure it was happy.
Yeah!
Thanks, this forum rocks!
Old 10-16-2013, 01:23 PM   #9
taylor192
My Ride: 2003.5 M3
Glad you got it solved.
Old 10-17-2013, 08:07 PM   #10
kerriwarwick
My Ride: 04 330ci
Send a message via Yahoo to kerriwarwick
Hi chaps , my top got stuck halfway up ! and after reading your answers to a million other top stuck Queries , it turned out to be the green and white wire in the header rail a nice solder job and I am topless once again ..thank you thank you !!! kerri
kerriwarwick is offline   Reply With Quote
Old 10-17-2013, 09:41 PM   #11
fmzip
My Ride: '08 328xi / '01 530i
careful with the topless comments
fmzip is offline   Reply With Quote
