///M3 Forum
Old 10-16-2013, 04:23 PM   #1
1alfanatic
My Ride: 2003 M3
M3 spare tire, or lack of
I am a M3 Newbie, (03 E46 Convertible). I have never had a car without spare tire? It apparently should have RF or "run flat" tires but it doesn't. Wheels are 19". Can I just pick-up a 4"x ? Compact Spare Wheel and tire and cram it in there? There is one on Evil Bay from a 5 series, (E90) for $100. Is this the best way to go? Bob Lesher
1alfanatic is offline   Reply With Quote
Old 10-16-2013, 04:25 PM   #2
Alan
Alan's Avatar
My Ride: 2006 M3
You should have the Mobility Kit under the trunk floor. The E46 M3 does not use run flats.
You can buy a spare if you feel you need one. LeatherZ and others sell them.
Alan is offline   Reply With Quote
Old 10-18-2013, 01:41 PM   #3
dillard
My Ride: 2004 M3 Cabrio
If my memory is good, you need a 17" spare doughnut tire and a jack. The smaller sizes have issues with the brake calipers. You will loose an inch or two of trunk space.
Proud owner of '04 M3 Convertible:
dillard is offline   Reply With Quote
Old 10-18-2013, 02:01 PM   #4
cityjohn
My Ride: 2001 M3
You can try this: http://forum.e46fanatics.com/showthread.php?t=937479
cityjohn is offline   Reply With Quote
Old 10-18-2013, 02:05 PM   #5
audiquattrot
My Ride: 2005 M3, 1990 325iX
i have a donut spare that i carry in the trunk. I'm not sure if it fits, but i have it there for moral support in the event i have a blow out. My guess it might not clear the front brakes, so if i happen to blow out a front, i plan on moving one of the rear tires to the front and putting the donut in the rear. I also carry a jack and wrench.
audiquattrot is offline   Reply With Quote
Old 10-19-2013, 11:14 PM   #6
ddaniel1
CWO4 (Ret)
ddaniel1's Avatar
My Ride: 328i, M3, 525iT
I am looking into a spare solution also, I picked up this cool little jack kit:
http://www.ecstuning.com/Search/ES2530819/ES2530819/
ddaniel1 is offline   Reply With Quote
Old 10-20-2013, 11:55 PM   #7
FooFighter94
My Ride: 2001 325Cic
I am considering this just to replace that nightmare of a jack they originally put in the E46! No plastic business in that scissor jack you got.
WVU Mountaineer
-2001 325Ci Convertible Slushie
-Orient Blue Metallic
-Koni Yellows, Otherwise hella stock
FooFighter94 is offline   Reply With Quote
