Sponsored by BimmerWorld
Old 10-16-2013, 04:30 PM   #1
Dirty-330
My Ride: 330ci,325xi,m3c
See VIDEO...What is up with this strut mount
Makes that sound while turning the wheel, notice the twisting movements the strt rod/nut also moves up and down a bit.
THANKS
Dirty-330 is offline   Reply With Quote
Old 10-16-2013, 04:57 PM   #2
///M Protocol
Banned User
My Ride: i3
maybe you have a loose bolt securing the strut. I believed there are two bolts securing the front strut to the car by the wheel well
///M Protocol is offline   Reply With Quote
Old 10-16-2013, 06:02 PM   #3
Dirty-330
Meaning the pinch bolt and the end link?
Old 10-16-2013, 06:53 PM   #4
motorhead55
My Ride: 01 325it 5spd sport
Were you continually turning the steering wheel one direction while it was "Popping"? If so, It seems like the main shaft in the strut has come loose internally.
motorhead55 is offline   Reply With Quote
Old 10-16-2013, 07:48 PM   #5
Dirty-330
That was while turning back and forth.
Old 10-16-2013, 07:59 PM   #6
Japanrot_325i
My Ride: 03 325i
Strut top hats the bearings went bad and aren't allowing it to turn so the spring is binding. New top mounts or lithium grease sometimes does the trick.
Japanrot_325i is offline   Reply With Quote
Old 10-16-2013, 08:31 PM   #7
lszlszx
My Ride: 1.8T, XC70
The bearings must be shot in the strut mount.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 10-16-2013, 08:42 PM   #8
WDE46
My Ride: '13 128i, '04 330Ci
Yep, replace the mount along with the spring pads.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 10-16-2013, 08:42 PM   #9
Dirty-330
The top hat less than 5,000 miles on it, its a Febi brand, thats prolly why.
Old 10-16-2013, 08:46 PM   #10
WDE46
Maybe it was installed incorrectly. Don't dismiss that possibility.
Old 10-16-2013, 09:08 PM   #11
Dirty-330
In what way, its over tightened onto the strut, or is there hardware that could be missing or in the wrong place(washers and such)?
Old 10-16-2013, 09:21 PM   #12
WDE46
Either one is possible.
Old 10-16-2013, 09:40 PM   #13
Japanrot_325i
My Ride: 03 325i
Probably over tightened that's most likely you could try loosing the nut a little also.
Old 10-17-2013, 02:12 AM   #14
YOnpds
My Ride: E46
Mine was doing something similar because I did not properly torque the upper strut nut (used an impact wrench).
http://forum.e46fanatics.com/showthread.php?t=993857
YOnpds is offline   Reply With Quote
Old 10-17-2013, 10:42 AM   #15
Dirty-330
Ok, thx a lot for that thread. Ill have to find those specialty sockets, I think thats exactly whats been done.
