Old 10-17-2013, 02:49 PM   #21
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Btw, these are the CBI bulbs on my car
Old 10-17-2013, 02:51 PM   #22
choxor
My Ride: JDM
^ Those look great. Noticed last night one of my headlights has developed a purple tint. Probably going to pick up a pair of those.
Old 10-17-2013, 02:56 PM   #23
Solidjake
Zero. Leaks.
Solidjake's Avatar
IMO worth the money
http://www.theretrofitsource.com/pro...ducts_id=10591
Use the coupon code in the first post of projector retrofit in my sig for free shipping
Old 10-17-2013, 03:07 PM   #24
jfoj
My Ride: 330CiC, M5, X5
Originally Posted by Mango View Post
I prefer 65 watt HIDs personally.
35 Watt ballast or 55 Watt ballast (actually a correction to the 50 Watt comment earlier), it has nothing to do with the bulbs as the bulbs are actually the same, assume most people have figured this out if they have spent any time looking over HID kits. The color temp is reduced a bit with the higher Wattage ballast, so this is why you can easily go to 6k in 55 Watt ballast and the color temp is more along the lines of 5k.
The main reason I originally went with the DDM Tuning HID kit is the high end halogen bulbs were only lasting about 6-9 months in my trunk. I figured 1 set of HID for my projectors in my trunk were about the same cost as the high end halogens, so if the DDM junk did not last more than 6 months, no loss, well I have had the system in my truck for almost 4 years without a problem.
So the one time investment with DDM has paid off well for me.
Also for anyone keep in mind that even OE HID bulbs degrade with age, if you still have your original bulbs, an upgrade/replacement would help with light output.
Old 10-17-2013, 06:54 PM   #25
seattle330
My Ride: '05 330i ZHP
Originally Posted by JDez View Post
I used to have a maxipad with FX-R projectors and 6000k bulbs. The light output was craptastic so I went with some Philips 4300k bulbs. The difference was incredible, especially in the rain. I'm gonna buy some Osram 5000k bulbs to drop into my E46 here soon.
I second the Osram CBI. I got a set when my Philips 85122 went out, and the Osrams are much better.
seattle330 is offline   Reply With Quote
Old 10-18-2013, 12:43 AM   #26
Solidjake
Zero. Leaks.
Solidjake's Avatar
Yes but at a MUCH slower rate than crap aftermarket bulbs which you have.
It's in my lighting guide
Old 10-18-2013, 01:20 AM   #27
E46Enthusiast20
My Ride: 2016 F80 M3 Sedan
Re: hid blue lights question
I've got depo projector headlights and ddm 4500k bulbs with 55w ballasts. No issues to report.
E46Enthusiast20 is offline   Reply With Quote
Old 10-18-2013, 01:44 PM   #28
My Ride: 2016 Lexus
investment and ddm do not belong in the same sentence
