gauges not working - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-18-2013, 04:12 AM   #1
lhemrick
My Ride: 323I
gauges not working
My daughter purchased a 2000 BMW 323I. The gauges were working when arriving at home. Found where someone had had an amp in the trunk and the power and ground wire were just laying there in the trunk floor. I disconnected the power wire from the battery and while it was off my wife started the car. I replaced the wire after removing the amp wire and we took it for another drive around the block and noticed the gauges were not working. All the fuses are good. Carried it to a local shop and had a diagnostic test run and several codes came up 83 and 84 deal with "No signal CAN to instrument cluster 2 & 3." I was then told it could be fixed but he didn't have time to deal with it. I've never been told that before! So I guess I'm left to figure out what happened and how to fix it.
I have done some tests and I have power through the fuse box all the way to the plugs at the cluster connections and have a good ground.
Can anyone help with this problem?
Thanks!
lhemrick is offline   Reply With Quote
Old 10-29-2013, 04:07 AM   #2
jfp2999
My Ride: 325ci
used unit
maybe instead of fixing look into buying a used one
jfp2999 is offline   Reply With Quote
