Old 10-18-2013, 01:37 PM   #1
DonaldE
My Ride: 2002 330i
Interior LED's
After installing my LED kit from Khoalty, nothing works of course (except the switch operated lights)
So I installed the resistor, and still nothing works
I then went to my local Autozone to get some new bulbs for the footwells because the old ones had blown, still nothing
Is there a fuse that could have popped or something? A bulb in each footwell should be enough draw to to turn trip the switch, right?
Or should I just chalk it up to needing to have the module coded?
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
Old 10-18-2013, 02:12 PM   #2
christiandflores
My Ride: BMW M3 E46
Interior LED's
I have the same ones. The pix on the website are ones i took of my car.No resistors needed. I found that if you bend the metal part slightly outwards, it helps improve the contact.
- Christian
BMW M3 E46 | Carbon Black Metallic | Gray Nappa | ZCP | SMG | 40% Tint | LED Interior/Exterior
Join Us at the San Diego North County Monthly BMW Meet
christiandflores is offline   Reply With Quote
Old 10-18-2013, 03:25 PM   #3
DonaldE
My Ride: 2002 330i
I appreciate your response, but that literally has nothing to do with what I asked. Many cars have issues with needing resistors due to the module code tripping because of the low power LED's require. I'm saying that I have tried to remedy that problem by having normal bulbs in the footwells, but I'm still not getting any power to auxiliary lighting.
Swapped M3 Interior
OEM Style 71s
Locked/Loaded/Loud
DonaldE
