Sponsored by The Tire Rack
Old 10-20-2013, 01:53 PM   #1
azatabbasov
My Ride: 2001 BMW 330i
Need help with choosing tires!
I currently have 18" rims on my car with 225/40/18, my questions is can i put 225/50/18 on it with out rubbing or anything?
azatabbasov is offline   Reply With Quote
Old 10-20-2013, 03:47 PM   #2
2003 325i
My Ride: '03 Orient Blue 325i
Probably not and your speedo will be off significantly. Go 235/40 to gain a small amount of sidewall if that's your goal, otherwise smaller rims is your only choice.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 10-20-2013, 03:57 PM   #3
azatabbasov
Well i was looking for a smoother ride with the same rims. Whats the biggest i can go?
Old 10-20-2013, 10:38 PM   #4
2003 325i
What I said. 235/40. Assuming rims are 8-9" wide
Old 10-21-2013, 11:17 AM   #5
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
+1 on the 235/40R18 recommendation.
You can also find a large difference in ride quality among different tires in the same size. If you're looking for the softest riding tires in 235/40R18, check out the Continental Pro Contact and Bridgestone Turanza Serenity Plus.
Tires http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 10-21-2013, 03:52 PM   #6
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
+1
Do not try 225/50/18, that's just way too tall.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
