Sponsored by BimmerWorld
Old 10-20-2013, 03:46 PM   #1
lovemy330ci
My Ride: 03 M3, VF570 StgII
Koni/ FSD Eibach pro kit, very noticeable Rake
hello all
i installed the koni FSD Eibach Pro kit over the summer
i gave it a few months thinking they would settle but they are not
the front is alot lower than the rear, and its very noticeable
i read somewhere that this tends to happen with this kit but i cannot find the thread about it
anyone have any ideas, should i remove the spring pads?
i just do not know what to do
lovemy330ci is offline   Reply With Quote
Old 10-20-2013, 03:57 PM   #2
lovemy330ci
i would like to make the rear lower to match the front
Old 10-20-2013, 03:57 PM   #3
always-there
My Ride: 2002 BMW 330I
Re: Koni/ FSD Eibach pro kit, very noticeable Rake
I have the same kit and had the same issue--so, I removed the upper/lower springs pads with great results. It'll make you smile. Do it.
Sent from my SM-N900P using BimmerApp mobile app
Old 10-20-2013, 04:20 PM   #4
lovemy330ci
but how about metal on metal contact, wouldnt that be a bad thing.
Old 10-20-2013, 04:28 PM   #5
always-there
The weight settles onto the spring and doesn't allow it to move, unless you raise the car with a jack. The pads are on there to help with any possible rattle and what not. Many have done this with no negative results and great outcomes. I also did it and I love it, absolutely no rattling and it looks awesome.
Old 10-20-2013, 07:16 PM   #6
always-there
Did you do it?
Old 10-21-2013, 06:55 PM   #7
lovemy330ci
not yet i will soon
Old 05-07-2014, 09:23 AM   #8
yardbird
My Ride: 2000 328ci
How thick are the pads when installed? How much more drop is gained by removing the spring pads? Is there any problem with keeping the springs centered in position with the spring pads removed? Would it be possible to cut a piece of 1/16" thick polyurethane sheet, and install it in place of the spring pads? I plan to install the same springs (with Koni Yellows) soon and would love to get an even drop for my 2005 330ci with Sport Suspension. Thoughts anyone??
yardbird is offline   Reply With Quote
Old 05-07-2014, 03:35 PM   #9
always-there
Pm replied.
Old 05-07-2014, 03:36 PM   #10
always-there
Upper/lower pads removed.
Old 05-07-2014, 03:37 PM   #11
always-there
No rake...
Old 05-13-2014, 12:42 AM   #12
lovemy330ci
niceeee, it doesnt clunk?
Old 05-13-2014, 07:24 PM   #13
always-there
Nope.
