Sponsored by The Tire Rack
Old 10-21-2013, 10:50 AM   #1
pepsikon
My Ride: 2004 BMW 325 ci
Fitting tires on oem set of 18" m3 wheels
Hey guys so I bought a set of wrecked up oem m3 wheels and sanblasted them and powder coated I provided before and after pictures and I need help with tire sizes:
They are 18" oem m3 wheels
Have et47 offset
All 4 wheels have a 8.5 width
Missing info is ?/40/18
I was thinking somthing either 215, 225, or 235 but no more which will give me stretch!?!?!
What im looking for:
Stretch less than a flat sidewall bot nothing more and nothing crazy stretch just somthing so I dont see the lip of the wheel but still has a stretch.
Thanks in advance!!!
Before is silver after powdercoat is anthracite.
ID:	531613   Click image for larger version
pepsikon is offline   Reply With Quote
Old 10-21-2013, 11:04 AM   #2
Sanny910
My Ride: Ford Gt
First, those wheels are not OEM 18's they are the 19' premiums.
Sanny910 is offline   Reply With Quote
Old 10-21-2013, 11:25 AM   #3
pepsikon
Re: Fitting tires on oem set of 18" m3 wheels
It says they ar 8.5 wide 18" wheel
ID:	531618   Click image for larger version
Old 10-21-2013, 11:30 AM   #4
MacFady
My Ride: 330i ZHP
Second, Sanny is wrong, those are four fronts you have there if they are all ET47. I'm thinking 225/35 or 225/40 on an 8.5 is what you are describing as far as the look you want. You're going to want to run spacers and extended lugs or else you are going to be pretty tucked in there, regardless of how much "stretch" you have on the wheel. With an offset of 47mm, you're probably looking for 12mm spacers in the rear. You can search for what you want up front
MacFady is offline   Reply With Quote
Old 10-21-2013, 11:34 AM   #5
ian02
My Ride: 05 325ci
Those aren't OE wheels, they are replicas it looks like.
First red flag is 18" size and second red flag is nowhere for the M emblem....
ian02 is offline   Reply With Quote
Old 10-21-2013, 11:45 AM   #6
dardarwin01
My Ride: 330ci
You got right
dardarwin01 is offline   Reply With Quote
Old 10-21-2013, 11:45 AM   #7
pepsikon
Thanks MacFady and yes they are 4 fronts because I couldnt fit a rear m3 on the car and they are oem they were purchased from a dealer and everything but already ordered a set of 12mm and extended lugs
Old 10-21-2013, 12:14 PM   #8
pepsikon
The m3 logo was sanded out since its not a m didnt wanna be rice
Old 10-21-2013, 02:51 PM   #9
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
If all four are 18x8.5 ET47, I'd recommend 12mm spacers all around. Should fit pretty easily with 235/40/18 tires.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 10-21-2013, 02:58 PM   #10
pepsikon
When you guys mention spacers you guys are trying to get the style aspect so it looks better correct? Because when I put the rims on the car they fit pretty well
Old 10-21-2013, 03:37 PM   #11
MacFady
My Ride: 330i ZHP
Yes, the spacers will just move the wheel 12mm closer to the fender. I only said 225's above because you mentioned they were 8.5 and you said you wanted a little stretch but no lip poking out. Post pics when all is said and done.
Here is a picture of what I thought you were describing. 225/40 on a 8.5.
Also, if you are serious than props to you on going all out to avoid the rice situation with the M logos
Old 10-21-2013, 04:23 PM   #12
pepsikon
Thats exactly what I wanted in your picture of the bbs wheels! I will go with the 225 then and I will order spacers as soon as my check comes in! And yes me and my buddys sat around for about 4 hours and sanded out that part didnt look too good when done but after sanblasting and powdercoating it looks brand new
Old 10-21-2013, 08:51 PM   #13
pepsikon
Finished product
Deff needs to be lowered though
sorry for the dark images
ID:	531718   Click image for larger version
Old 10-22-2013, 06:46 AM   #14
MacFady
My Ride: 330i ZHP
I thought you had a coupe?
Old 10-23-2013, 02:06 PM   #15
pepsikon
It is a coupe
Old 10-25-2013, 11:53 AM   #16
MacFady
My Ride: 330i ZHP
OK, because the two pictures you posted above of them on the car are clearly on a sedan...
Old 10-25-2013, 01:46 PM   #17
pepsikon
Yah the above two photots its on a 2001 325xi
Old 10-29-2013, 02:55 PM   #18
sparkmags
My Ride: 2003 BMW M3
definitely ///mreps... the real 18's have the lips on them, the 19s are concave..
They never made 18's that were concave that style
sparkmags is offline   Reply With Quote
