Connecting turntable+amp to existing home theater set-up -- links to relevant pics - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 10-21-2013, 09:27 PM   #1
bimmerCi
My Ride: bmw
I received a turntable and Marantz PM-5004 amplifier as a gift, and I'm a little confused about how to set this up with my current home theater.
Back of Receiver: http://www.outlawaudio.com/images/SR5005_back.jpg
Back of Amp: http://www.nhthifi.com/pm5004_rear-L.jpg
It seems like both devices are designed to be wired directly to the speakers, but there must be a way to connect the two with RCAs right? I also use my blu-ray player for CDs... is it possible to use the integrated amp whenever the system is on stereo, but bypass it whenever on a surround mode?
Thanks for any guidance!
bimmerCi is offline   Reply With Quote
Old 10-22-2013, 10:51 AM   #2
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
connect amp to preouts of receiver
connect speakers to amp
you need a preamp module to connect normal turntable to receiver without phono inputs. its boosts the level from phono to normal baseband line level (rca.)
BTW, that is an integrated amp not an amp. (its a receiver without a tuner.)
I would not bother with it. Use the integrated amp for a stereo music setup not HT.
Buy a cheap CD player and connect it and the turntable to the integrated amp with some floor speakers. It has the phone input you need for the turntable built in.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 10-22-2013, 06:57 PM   #3
bimmerCi
My Ride: bmw
Thx for the reply -- I'm not sure I'm understanding correctly...
This sounds pretty straight-forward... speakers go directly to the IA, then RCAs connect the line-in on the IA (turntable has build-in phono preamp) to the pre-out left/right inputs on the HT receiver.
Here's where you lost me... are you saying you'd ditch the IA altogether and just run the turntable off the existing receiver? If so that would be great -- I'll just return the IA. If there's any sound quality benefit from hooking the IA to the receiver I'd rather do that though.
Old 10-23-2013, 11:02 AM   #4
GlockMan
GlockMan's Avatar
If the turntable has line level (not phono) outputs, just use your HT receiver without the integrated amp. The IA is only two channels and has its own volume control and input selector. It is designed for a stereo music system (it is a receiver without a radio tuner.)
If you had a regular power amp (no input selector, no volume control) then you could use it for your two front channels for better quality (mostly for CDs and music.)
In your case, it is not worth the hassle.
Speakers vary much more dramatically than the difference between a Marantz IA and a Marantz receiver.
JMO.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 10-24-2013, 01:02 PM   #5
WerksM3
My Ride: 2002 M3
If you are not tied to the IA, and your turntable has phono-level output you can buy a simple preamp to bring it up to line level, and just use one of your axillary analog inputs on your HT.
You can test weather the TT is phono level or line level simply by plugging it in, putting on a record and turning up the volume. If it is really quiet you have phono level and will need a preamp.
There are a lot of different phono preamps out there anything from $30-$1000.
WerksM3 is offline   Reply With Quote
Old 10-24-2013, 07:47 PM   #6
bimmerCi
My Ride: bmw
Ok -- just the info I was looking for. Thanks guys.
