Sponsored by BimmerWorld
Old 10-22-2013, 09:56 AM   #1
Pole position
My Ride: E46 330ci
Eibach install problem
So I had a shop install koni fsd and eibach springs. There is no way the front springs were installed correctly as it is sitting very high In the front. I tried explaining this to them but they don't know what they did wrong. Is there anyway I can describe what they did wrong correctly so they can fix it? Will attach pics later. I can fit 4 fingers between the fender and tire...very frustrating
Shut up and drive
Pole position is offline   Reply With Quote
Old 10-22-2013, 10:47 AM   #2
bimmernate
My Ride: 2003 330i ZHP
Tell them it's likely the strut is not fully seated in the bottom clamp. Turn the wheel and take a picture and we can tell you if it's fully seated.
2003 330i ZHP 6MT
Performance: Koni Sport Struts/Shocks, Eibach Pro-Kit, 17x9 Apex ARC-8, TMS F&R Sway bars, M3 RTABs w/ Vorshlag Limiters, M3 Strut Brace
Aesthetics/Functionality: TFX Projector retrofit by lightwerkz, 20% Tint, OEM Aux Input, Clear corners, LED taillights, M3 Steering wheel, Black kidney grills, mobius dash cam
bimmernate is offline   Reply With Quote
Old 10-22-2013, 11:04 AM   #3
Pole position
My Ride: E46 330ci
These have to drop lower...compared to other pics I feel like mine is just too high. Here are some pics. ThanksClick image for larger version
ID:	531778Click image for larger version
ID:	531779Click image for larger version
ID:	531780Click image for larger version
ID:	531781Click image for larger version
Shut up and drive
Old 10-22-2013, 11:04 AM   #4
Pole position
My Ride: E46 330ci
Literally my "worn and sagging" sport springs were lower...
Shut up and drive
Old 10-22-2013, 11:45 AM   #5
breadvanracing
My Ride: E46 328Ci, Z3 MC
Check that the "peg" on the strut housing is correctly oriented in the "crevice" by the pinch bolt. This lets the shock sit down at the proper height. Also looks like the spring is not oriented correctly on the perch, but hard to tell from the photos.
breadvanracing is offline   Reply With Quote
Old 10-22-2013, 12:30 PM   #6
Pole position
My Ride: E46 330ci
Seems to be sitting down in the mount all the way. Is there a diagram I can show them to have the spring seat correctly? The bottom of the spring is like oval so I don't know how it could be off as it kinda fits one way, is the top what could be off? Thanks
Shut up and drive
Old 10-22-2013, 02:05 PM   #7
Max'd out
My Ride: 04 330cic
I just installed new Koni's last week and had the same problem. The struts are not down in the pocket far enough. See the faint line above the to top of the socket? that should down in the pocket. As stated above, be sure to get that nub in the gap behind the pocket. Once you loosen the pinch bolt, put a jack under the control arm and raise the assembly up and the strut should seat. Good luck.
Max'd out is offline   Reply With Quote
Old 10-22-2013, 05:05 PM   #8
Pole position
My Ride: E46 330ci
Is the nub the thing barely visible in the photo below? Looks like the strut went in a little crooked and didn't seat all the way down Click image for larger version
Shut up and drive
Old 10-22-2013, 07:11 PM   #9
lovemy330ci
My Ride: 03 M3, VF570 StgII
looks like the rear springs were used in the front, i have the same set up
lovemy330ci is offline   Reply With Quote
Old 10-22-2013, 07:18 PM   #10
kejobe
My Ride: 2003 325I
That's what I'm thinking.
All Stock...
kejobe is offline   Reply With Quote
Old 10-22-2013, 07:32 PM   #11
Max'd out
My Ride: 04 330cic
Yes, that nub is sitting on top of the pocket and should be rotated to slide down in the slot above the pinch bolt. I'm not sure of the possible spring issues in the post above, I used my original sport springs.
Old 10-22-2013, 07:45 PM   #12
Prez50
My Ride: 03m3
The rear springs are to small to fit over the strut.
Prez50 is offline   Reply With Quote
Old 10-22-2013, 08:21 PM   #13
Pole position
My Ride: E46 330ci
Yeah I'm not sure how you could mount the tears in the struts they are too small. Anyway thanks, hopefully that nub just has to be repositioned. I'll let you all know how the setup is after an autox this weekend
Shut up and drive
Old 10-23-2013, 12:19 AM   #14
bimmernate
that little nub is definitely not positioned right. it should slide down in the slit. You can do that yourself really...Just lift the front of the car and place on jack stands, place a jack under the control arm, loosen the pinch bolt, rotate the strut, raise the jack slightly to push the strut in further, tighten the bolt.
2003 330i ZHP 6MT
Old 10-23-2013, 12:22 AM   #15
bimmernate
those look nothing like rear springs, i dont even know how you can place the rear springs in the front. They literally look nothing alike.
2003 330i ZHP 6MT
Old 10-23-2013, 12:23 AM   #16
bimmernate
the spring looks like it is situated correctly
2003 330i ZHP 6MT
Old 10-23-2013, 01:08 PM   #17
Pole position
My Ride: E46 330ci
Ok great that makes life a lot easier. Will just twist and seat the correctly.
If the front drops lower than expected though, to even the car out a little, is it better to remove the bottom or top rear spring pads first? Thanks
Shut up and drive
Old 10-25-2013, 01:22 PM   #18
Bino5150
My Ride: 99 323i
Correct me if I'm wrong, but looking at the first 2 pics, the spring is NOT seated correctly in the perch. There is a spot where the tail of the spring is supposed to butt up to. Also, the strut is not seated down fully in the pocket.
And here you can see the difference between the front ad rear springs:
http://forum.e46fanatics.com/showthread.php?t=1007801
Bino5150 is offline   Reply With Quote
Old 10-26-2013, 07:50 PM   #19
bimmernate
You posted the same thing in my thread too, I'm pretty sure you are wrong. Did you look at your strut before disassembling it?
2003 330i ZHP 6MT
Old 10-28-2013, 04:21 PM   #20
Pole position
My Ride: E46 330ci
Ok well I got it sorted. Springs were seated correctly, but as was said earlier the nub was not all the way down in the front strut. So far the car looks good, rides very well, and handles fantastic. I couldn't believe how worn out the struts that came off it were, I could compress them with two fingers. The rears didn't even extend back out when compressed too. Went to an autocross, finished 5th out of 32 novices, only cars that beat me were some s2k's on race tires and a raced out z3 or z4. I really recommend this setup. Here's a pic as it sits today. Oh, and new rtabs with limiters(pelican $20) really tied together the package, everything is so much tighter. Click image for larger version
ID:	532542Click image for larger version
Shut up and drive
