E46 Convertible
Old 10-22-2013, 05:08 PM   #1
rogschumac
My Ride: 2002 330CI convertib
E46 Convertible general questions
Just bought car (2002 330CI convert) for a "fun car". Had 2 previous 5 series sedans, so somewhat familiar with Bimmers. But have 2 questions:
1) when closing doors, get a tinny clank instead of the solid "thunk" normally expected. Is this because of the frameless windows or the auto up-down action of the windows? Or to I have a problem?
2) car has Climate control. Every time I start up, rear widow defogger comes on. Any way to disable auto-on and make it manual? Dont want defogger coming on when top is down.
rogschumac is offline   Reply With Quote
Old 10-22-2013, 05:47 PM   #2
taylor192
My Ride: 2003.5 M3
1. The window could be loose. Search, easy fix.
1. The window could be out of adjustment. Search, more complicated fix.
1. The door lock could have fallen apart internally. Search, easy fix.
2. Why do you care? I don't.
2. Do you think German engineers would have thought to disable the rear defroster when the top is not closed? Try it.
Old 10-22-2013, 06:13 PM   #3
cityjohn
My Ride: 2001 M3
My doors don't feel as substantial as a closed car, they never have. I think it's because there's a lot less weatherstripping to absorb the impact of closing.
And i think my defroster can be switched on even if the top is down.
cityjohn is offline   Reply With Quote
Old 10-22-2013, 07:16 PM   #4
johnrando
My Ride: '06 330 CIC ZHP
You should be able to just hit the defrost button and turn it off. Also, push the fan speed button down until off.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 11-04-2013, 07:12 PM   #5
JTM745i
My Ride: 540i
I could use help please, replaced both Main Cylinders and lines 23 & 24
Works like a charm, besides not going back down all the way, Note the sensor with the sliding arm floppeds freely on the
slider, thus it does not stay in position, is the arm on the sensor geared, as on this one the arm moves very freely,
what puches the system to the end for in the up position or down position, and on top of it all why is the nut a locking nut
to the plastic arm?
Thank you for any help
JTM745i is offline   Reply With Quote
Old 11-05-2013, 04:54 AM   #6
E46DrEaMeR
My Ride: 2004 330ci
vert doors don't sound like tin top doors on most cars, ive had 5 different verts from different marks and none of the doors have had that nice expensive sound when closing the door, on the rear demister problem could it be that its coded to the key like the seats and mirrors are........just a thought
Its a ragtop thing! you wouldn't understand
E46DrEaMeR is offline   Reply With Quote
Old 11-05-2013, 11:35 AM   #7
taylor192
My Ride: 2003.5 M3
to the plastic arm?
If you start a new thread and take photos of the problem I'll help you out. Lets no clutter this thread, and I don't understand your issue... sounds like you reassembled something incorrectly.
Old 11-05-2013, 04:33 PM   #8
cityjohn
My Ride: 2001 M3
The doors on my 1989 Volkswagen Cabriolet snapped shut like fine Karmann cabinetry, even with the top down! What a little German gem that car was....
Old 11-05-2013, 10:02 PM   #9
JTM745i
My Ride: 540i
Thank you for the kind reply
http://www.realoem.com/bmw/showparts...75&hg=54&fg=10
13 Sensor 1 04/2001 54347059587
Can any one tell me please if this sensor has tension on it and or is geared?
Thank you kindly
Jens
Old 11-06-2013, 07:06 AM   #10
dknightd
My Ride: 2002 330 cic
I have this. Only notice it when windows and top are down.
I can get rid of it by holding the top of the door together (near the back) with my hand as I close door. I think maybe slightly loose window, or, perhaps inner door liner a little loose. One day I'll dig further into it
dknightd is offline   Reply With Quote
Old 11-06-2013, 11:22 AM   #11
taylor192
My Ride: 2003.5 M3
Thank you kindly
Jens
Externally the sensors (the same sensor is used near the bow and main cylinders) are driven by a "latch", internally they are magnets from what I've read and rarely fail.
There is a repair kit for the bow tension sensor, with a different mounting procedure... so maybe it fails. Sorry you're probably on your own from here.
Old 11-13-2013, 07:32 PM   #12
xdmikey
My Ride: e46 cabrio
"tinny sound" was what my e90 doors sounded like; my e46 sounds like when I shut the tailgate on my 200K p/u!
DINAN CAI, 3.46 DIFF, CDV DELETE,DINAN S2 & EXHAUST,HARDTOP,f/14 wheels(gone, back to 68s and quickness!)
xdmikey is offline   Reply With Quote
Old 01-04-2014, 07:43 PM   #13
h2knet
My Ride: lacetti
hi,
happy new year everyone!!
im thinking of buying an E46 320ci 2002 convertible,
i have two questions though,
- all of e46 convertibles (320,323,325,330) wear the "M" uniform?
if not which models do ?between what years ?
also,between the 318ci m sport convertible 2003 and the 320ci m sport convertible 2003 which one should i choose ?
my mechanic told me that the 318 4 cyllinder series has oil problems in a big ratio , is that true ? what do you think ?
what about fuel consumption ? is there a big difference ?
this is my first post,
thank you guys,
h2knet is offline   Reply With Quote
Old 01-04-2014, 07:47 PM   #14
cityjohn
My Ride: 2001 M3
Hello h2knet
There was an M3 E46 convertible from 2001 to 2006. Other models could be ordered with "M-Sport" equipment, but not all of them.
I don't know about oil issues, but the straight-six is usually preferred over a four-cylinder BMW.
Old 01-04-2014, 09:11 PM   #15
h2knet
My Ride: lacetti
hi !!
thanks for your reply ,
are there any changes in the engine between a 2002 320ci conv. and a 2003 one ?
the car im trying to buy is listed as 2002 - it has around 70000 miles,its in a very good condition outside inside but my main concern is that after 11 years
fuel consumption is not at the best ,
thanks,
Old 01-05-2014, 01:25 AM   #16
cityjohn
My Ride: 2001 M3
^ a 2002 vs a 2003 should be pretty much the same
Old 01-05-2014, 08:55 AM   #17
h2knet
My Ride: lacetti
thanks cityjohn,
all of the info are taken care of,
its been more than 4 years i want to buy this car,
i really hope to choose a problem free car ( as much as possible)
also thinkin of spending an additional 1000 euro by the end of summer,
happy new year 2014
Old 01-07-2014, 01:57 AM   #18
Antti
My Ride: German car
2. You can decode this feature off with proper hardware.
Find some BMW-specialist in your area.
Antti is offline   Reply With Quote
Old 01-16-2014, 11:50 AM   #19
hisport
My Ride: 01 M3 Vert
Door rattle: Check Your Mirrors
This is an old thread, but posting in the hope of helping someone just now studying it (as I have been doing...)
Check that your door mirrors are tight. They were both loose on my car, and that was the noise. Can be tightened without disassembling door (search). Use blue loctite.
Slowly going through my '01 M3 vert project car, fixing things as I go. Doors sound like they're full of tin cans. Looked up this thread before pulling door cards. Found floppy mirrors.
BTW, when I do get inside the doors (prob to check muddy sounding HK speakers), I will tighten and adjust everything, and then install "dynamat" material on inner door skin. I have found that this stuff really helps door noise on several other german cars. Lowes roofing starter strip is basically same stuff (as dynamat et al) and cheap.
Hope this helps
stripeverything
hisport is offline   Reply With Quote
