Sponsored by BimmerWorld
Old 10-23-2013, 10:33 AM   #1
c0wb0ychris
My Ride: 2000 323i
What to look for? Front suspension damage
I was involved in a wreck with my 2000 323i and it has only front right end damage. So far I see that the front right control arm is bent and the right tie rod popped out of the ball and joint that connects to the steering gear.
I'm going to replace both the front right tie rod and control arm. My question is when replacing these 2 parts, should I replace the left side too? And what other area of the suspension should I take precautions with; stabilizer, reinforcement bar, etc.?
The read circle indicates where the ball/joint broke
c0wb0ychris is offline   Reply With Quote
Old 10-23-2013, 10:40 AM   #2
c0wb0ychris
My Ride: 2000 323i
Before
After
Old 10-23-2013, 10:41 AM   #3
c0wb0ychris
My Ride: 2000 323i
Old 11-16-2013, 02:36 AM   #4
nicoled985
My Ride: BMW 325i 2003
Re: What to look for? Front suspension damage
Hey my car just got hit but on the left hand side :-( I hope it's repairable. I love my car
Sent from my SAMSUNG-SGH-I317 using BimmerApp mobile app
nicoled985 is offline   Reply With Quote
Old 11-19-2013, 01:16 PM   #5
Bobobo-bo Bo-bobo
My Ride: 2000 bmw 323i
so sad seeing a crashed e46 suspension wise, what you do to one side should be done to the other.
Bobobo-bo Bo-bobo is offline   Reply With Quote
Old 11-19-2013, 01:38 PM   #6
bee-em-dougle-u
My Ride: 2002 BMW 325i
^Good advice, especially if the suspension needs a refresh anyway. New FCABs, control arms, and eyeball the ARB to make sure it's the same side to side. Check to make sure your right side strut isn't bent too. If it doesn't align within spec, you'll know that the strut tower and/or subframe got tweaked. That hit looks hard enough to have possibly bent the unit body.
2002 BMW 325i sedan
Manual gearbox, but of course!
Tasteful mods
128K miles and counting
bee-em-dougle-u is offline   Reply With Quote
Old 11-19-2013, 03:48 PM   #7
mr ilia
My Ride: 2004 BMW 325i 5spd
To check for bend strut tower the cheap way, you can borrow someones strut bar of their non-m e46 and see if it fits easily to your car.
If it does fit with out issues... holes line up and you do not need to twist it to fit, then you can move on and start relapsing suspension parts. I'd change strut towers and control arms with tie rods and anything else that might have been remotely affected.
Also check frame rails for the damage in the FCAB area for stretching and bending. If my memory serve right, these bolts are designed to snap in case of light accident to prevent frame damage.
---- My Beemer history ----
2004 BMW 325i sedan - Schwarz II
1998 BMW 323i coupe - Lazurblau
2004 BMW 325ci - Sapphire Black
1991 BMW 318i sedan - Lazurblau
2001 BMW 330i sedan (Auto) - Japanrot
http://forum.e46fanatics.com/signaturepics/sigpic288773_1.gif
mr ilia is offline   Reply With Quote
Old 11-19-2013, 05:06 PM   #8
nicoled985
Should they do all this at the BMW authorized collision repair shop?
Old 11-20-2013, 08:46 AM   #9
mr ilia
If you're going through insurance to fix the damage, then I'd find the best body shop available to have it fixed.
Old 11-20-2013, 09:11 AM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
this
Do everything as a pair. Check your sway bar links, those are probably done.
Old 11-20-2013, 10:38 AM   #11
My Ride: Lexus
Something like that is always repairable. The only question is cost.
The best thing to do is get under the car and visually inspect. Compare parts to the other side to help see if they are bent.
