Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
Old 10-24-2013, 12:49 PM   #21
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by Sweetness View Post
That would be your e-brake, sir
Not if it's only when he takes turns.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 10-24-2013, 01:40 PM   #22
My Ride: Lexus
you probably should stop giving advice
every single post that comes from your account needs correction
Old 10-31-2013, 10:31 AM   #23
TerraPhantm
My Ride: M3 & ZHP
Koyo makes the factory e39 bearings. I wish I could get koyo bearings for my m3, I really wouldn't be surprised if they were superior
Old 10-31-2013, 10:34 AM   #24
Mr.Philadelphia
My Ride: 2002 330i
Originally Posted by LeMansteve View Post
I think you typed F.A.G. without using periods between the letters. Censored!
Yes, shame on me.
Mr.Philadelphia is offline   Reply With Quote
Old 10-31-2013, 01:18 PM   #25
BigDRick323
My Ride: 2000 323i
I got the Koyo's
Old 10-31-2013, 03:57 PM   #26
Mr.Philadelphia
My Ride: 2002 330i
You can use the Koyo assemblies for your front end. The M3 assemblies by F.A.G. have three centering pins on the hub flange that make wheel changes a bit easier, but they're not essential.
Old 10-31-2013, 04:23 PM   #27
WDE46
Just for anyone's future reference, I used a 36 mm socket to press against the inner race and then smacked the bearings on with a 2.5 lb engineer's hammer.
Old 11-01-2013, 06:22 PM   #28
BigDRick323
My Ride: 2000 323i
Re: Timken Front Wheel Bearing/Hub from Autozone
Hmmm, ok, I'm going to YouTube it. So much to do.
Sent from my LG-MS870 using BimmerApp mobile app
Old 11-11-2013, 11:14 PM   #29
ssl-3
My Ride: E36 325i
Talking Works for me.
In shopping for wheel bearings for my E36, I happened upon this thread.
Wow! Timken. About $80, shipped, for two Koyo hub assemblies delivered FedEx from autozone.com. (The local Autozones do not normally stock BMW parts. It is very sad. I had to buy a Fram oil filter to get the price over $100 to save 20%, and I hate Fram, but they don't make these filters themselves either.)
Thank you, Internet!
Regarding the black marks on F.A.G. vs. Koyo: I agree that it looks like induction heating. The Koyo hubs I received (well-packed, I must add) in Timken boxes have much more black visible than that pictured on the first post in this thread. (I'll reply with pictures if requested.)
I'd like to submit that the reason why the F.A.G. hub has so much black, and the Koyo has so little, is as follows:
F.A.G. does their final machining before the hub is heated and the bearing is inserted, and so much of it remains black.
Koyo does their final machining after the hub is heated and the bearing is inserted, and so much of it remains plain: Most of the black has simply been machined off.
6 in one, half-dozen in the other. *shrug*
Which one is better, long-term: F.A.G. or Koyo?
I frankly don't care: These were only $10 more per side than the cheapest Chinese bearings I could find (all of which were very ugly, saving "excess" steel at every step on this critical part, with dimples behind the wheel flange and other nonsense that, while perhaps good for unsprung weight, cannot possibly be good for reliability), and as stated elsewhere, there isn't a single thing wrong with either F.A.G. or Koyo (or Timken in general: whatever they sell is always likely to be quite good, and they did invent the tapered roller bearing...).
So thanks again, Internet! You've earned your monthly fee yet again. Actually, I think you've earned your fee for at least a few months. Good job, Internet!
(Another Autozone secret: Duralast belts are all made by Dayco. And Dayco belts are generally regarded to not suck. Since some/most/all of our cars have two belts, buying generic and getting good name-brand quality makes for twice the beer in savings over most other cars. )
ssl-3 is offline   Reply With Quote
Old 11-11-2013, 11:31 PM   #30
ssl-3
My Ride: E36 325i
Oh, and for folks talking about the ABS sensor ring being cast or machined (it might have been in another thread, maybe even on another forum): On these Timken-branded Koyo bearings, it is a separate part, stamped from sheet metal, and pressed onto the end of the hub. It is therefore neither cast, nor machined.
Looks fine to me, though, and perfectly adequate to modulate the Hall Effect sensor that is the ABS wheel-speed dongle for many years to come. (Esp. with the two dust shields, and the tight-fitting wheel-speed sensor: Not much can happen to it in there, especially with frequent bouts of heat to drive out any water that might occur.)
Again, pics upon request. (I don't like taking photos that nobody ever looks at.)
(Oh, and dust shields. I ordered one of each for each side, and a new "castle nut" (that isn't a castle nut at all, because it does not resemble a rook). Also ordered a new brake dust shield for the one that I butchered after it got deformed once when removing a wheel and noisily rubbed the rotor. Do the rest of you tend to replace these parts, or keep them? Mine are 18 years old, so I thought it best to replace them.)
Old 11-14-2013, 06:01 PM   #31
cvx5832
My Ride: 325Ci, 325Cic, C300
I first heard of the Timkens as a viable option back in 2010 with this thread, but back then they were about a hundred bucks a piece. They were a good deal then, but they're a ridiculous deal now. When did it go down btw? I wanted to go OE but I figure there was nothing wrong with F.A.G. (which is what I got in this bearing lottery) and an extra 300 bucks in my pocket.
Thanks again to the board for the tip.
Untitled
And got me some extra gloves with the change. Nothing wrong with my old ones.
Untitled
cvx5832 is online now   Reply With Quote
Old 11-14-2013, 08:37 PM   #32
WDE46
The ABS sensor target strip is a stamped piece on the OE F.A.G. Hubs. These were never machined. That would be absurdly expensive. I found that the F.A.G. I got matched EXACTLY with the parts I removed from my car.
Old 12-18-2013, 11:02 AM   #33
SoCaLe39
My Ride: 06 M5 & 03 325i
So this is what you guys are buying right?
http://www.autozone.com/autozone/par...ntifier=386476
SoCaLe39 is offline   Reply With Quote
Old 12-18-2013, 11:31 AM   #34
WDE46
yes
Old 02-20-2014, 12:43 PM   #35
rcsummers
My Ride: M3
AutoZone??? These aren't hondas people.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 02-20-2014, 01:31 PM   #36
Cayne23
My Ride: 2002 m3 convertible
I got those same bearings for my m. Yes they were koyo bearings in a timken box. Only have 2 tabs on them, as opposed to 3 on the f a g bearings. The koyos r for e46 non m's. I had some wheel shake after about 2k miles. Took off the tire and noticed that the hub wasnt centered anymore. Almost as if that third tab was needed to keep things centered on the m. I returned them and bought some skf's from pepboys. Opened the box, f a g bearungs inside. Dont cheap out on your wheel bearings. Go with skf or f a g if u have an m.
Oh and btw, autozone has remanufactured m front brake calipers for 65 bucks each. If u look at the pics on their website, u can see the ///m on them
Cayne23 is offline   Reply With Quote
Old 02-20-2014, 01:33 PM   #37
Cayne23
Oops, not " the hub wasnt centered anymore" the brake disc wasnt centered anymore on the hub
Old 02-20-2014, 02:13 PM   #38
WDE46
What tabs are you talking about?
I have over 10,000 miles on my F.A.G. and Koyo bearings. Both are fine.
Old 02-20-2014, 05:15 PM   #39
Cayne23
The 3 tabs on the outside of the hub that the rotor sits against. Non m's have 2, m's have 3
Old 11-14-2014, 10:57 AM   #40
rsyed07
My Ride: E92 335is, E46 330i
Sorry to bring up an old thread but does the Timken box come with the bearing dust cap and collar? Is it okay to re-use the old ones if its not included?
rsyed07 is offline   Reply With Quote
