Sponsored by BimmerWorld
Old 10-24-2013, 06:36 AM   #1
cpetrice
My Ride: 2003 M3
Dreaded 4 yellow dash lights on, assistance needed!
I came back from a long weekend, started 2003 M3 after 4 days of it sitting in the driveway. Instantly it beeped, the DSC, Low tire pressure, hand brake and SMG light came on.
Before I get flamed, I've searched the forums on 3-4 different sites, and it seems to be a p*ssing contest on what to change fix, or just a blog of "I have that problem, mine does this..." I need real help, someone who has had this issue, and what they did to fix it please!
Resetting the tire pressure does nothing, DSC button won't turn on or off, traction control is disabled. Lights come on at startup, never go off. Nothing I am doing is turning the lights off.
Suggested fixes are
battery
alternator
steering wheel sensor
speed sensor
salmon colored relay
top off brake fluid.
Things I have done
Changed the salmon colored relay a month ago (reverse lights won't light up, read it could be the relay)
Took it to Autozone (I know, I know!) to have the code read, said no codes present.
Battery was checked 2 months ago by Advance auto, said it was fine. It is the original battery I believe. Also to note, it was 40 degrees when I started it when I got back. IF it is the battery, I know batteries show weakness in cold weather.
Brake fluid is less than 1/4 inch from max, will top it off to see tonight.
Any help is appreciated.
cpetrice is offline   Reply With Quote
Old 10-24-2013, 05:42 PM   #2
Brissyjohn
My Ride: 2007 MX-5
I don't have an M3 (unfortunately I'm too poor) and cannot give you a definitive fix, but those warning lights seem unrelated and spurious.
I'd be suspicious of the battery. I know they last a long time but 10 years..... If the temp was 40 degrees (= F?) then a temp that cold could cave the battery enough on start to cause crazy electrical issues. Also, there were no codes stored, so either the code reader (person or device) is no good or there actually are no codes or actual faults.
If you replace the battery, it won't be money wasted. A quality one will last another 10 years.
Brissyjohn is offline   Reply With Quote
Old 10-24-2013, 07:31 PM   #3
cpetrice
My Ride: 2003 M3
Good advice, thank you!
Old 10-25-2013, 08:55 PM   #4
cpetrice
My Ride: 2003 M3
Went into diagnostics, battery looks good, on and started, so alt is good too. Put in new battery anyways, no change, all the lights stay on. I checked all the fuses in the glovebox, all good. Notice the smg light stays on for like 5 seconds after car shuts off.
Old 10-27-2013, 02:37 AM   #5
Brissyjohn
My Ride: 2007 MX-5
So are any fault codes stored now?
Old 10-27-2013, 08:04 PM   #6
cpetrice
My Ride: 2003 M3
Not sure, would a CEL show up after a battery swap? And if so, I hope Autozone can read the code, I found it odd that they said nothing showed when I had 4 lights on!
Old 10-27-2013, 08:35 PM   #7
Brissyjohn
My Ride: 2007 MX-5
I cannot see why a battery change would cause a CEL. You probably need to get the codes read by someone who has the correct equipment and knowledge to check all the car's systems.
Old 10-28-2013, 04:07 AM   #8
cpetrice
My Ride: 2003 M3
Yeah, didn't sound right to me either. I will see if there is a local shop who won't charge me a fortune to get it looked at. Thanks John
