E46 Convertible
Old 10-24-2013, 08:42 PM   #1
Dave
Moderator
Dave's Avatar
My Ride: 323,330,M3,M3,M3
Hmmm... suddenly now nothing works except the first step
So I changed out my alternator earlier and after a few hours I got gremlins. The exact same ones another guy got when he did the same job... except in addition, now the top doesn't work at all.
It's down, and I went to move the tonneau just to replace the little plastic spring loaded piece, and the solenoid fired and released it and that was it.
Pushing it up myself got it part way, and it stayed, and then when hitting open again it went about 2 inches at a time.
The pump never attempted to fire. This feels like a fuse thing to me. And since my gremlins blew fuse 30 (oil temp gauge) I went looking for others.
But all the ones listed on the card for the power soft top (6,12?,35,42,46) were fine.
Are there others?
I'm annoyed. For two weeks now this car has been a Murphy's law car.
Perhaps you think multi-million dollar ad campaigns make a beer taste better. Perhaps you're mouthing your words as you read this.
Dave is offline   Reply With Quote
Old 10-25-2013, 11:56 AM   #2
taylor192
My Ride: 2003.5 M3
If its going "2 inches at a time" then everything is working, just not well. This tells me you are low on fluid and the pump is having to re-pressurize the system constantly, leading to the slow jerky movement.
You've posted you had a leak before, did you ever resolve this?
Old 10-25-2013, 02:15 PM   #3
Dave
Moderator
Dave's Avatar
That's on the way down; the pump doesn't really operate on the step that's closing the tonneau cover. (I said open, but that's open the top, thus when closing the tonneau.)
The slow leak remains because I'm content - for now (I have other more important maintenance items ahead of it in line) - to just top off the reservoir every few weeks. I did this recently so the pump is full.
In this case, the pump isn't turning on or trying to run. At all. And given that this was 100% fine until I did electrical work, and I somehow blew other fuses on re-start too (oil temp sensor, fuse #30... btw, it's fine), to me it seems pretty clear that this is a fuse/relay issue.
I learned from a nearby shop that there's a relay behind the fuse box for convertibles. I don't really know how to test a relay, but that's going to be my next step.
Right now the top is down and if I tell it to close, the tonneau unlatches. Then that's it. No noises, no clicking, no attempts. And the last time I used the pump (putting the top down), it didn't groan or complain at all. Went down as quickly and quietly as the day it was installed.
Old 10-25-2013, 05:11 PM   #4
taylor192
My Ride: 2003.5 M3
Use a multimeter to measure voltage at the pump. If its getting power then the pump has gone bad. If its not, then its s fuse or relay or module.
Old 10-26-2013, 11:20 AM   #5
Dave
Moderator
Dave's Avatar
This morning I pushed the button and it went up.
Then I completely killed the alternator. It's like the car has to have something wrong with it at all times, and the problems rotate.
