Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 10-27-2013, 10:50 AM   #1
Hejop
My Ride: 320d Xdrive manual
First oil change 320d Xdrive Manual
Hi everyone,
First post I own a 1 Month old Xdrive 320d F30 Manual, just run in and would like to change oil and filter. Can somebody indicate where the sump plug can be found. I thought there should be panel that can be open on the front under tray but there is not one to be found.
Instead I can see what appears to be a drain plug just behind the front plastic under tray contained within a metal oval frame part of the front sub frame I suspect.
Any images of location would be appreciated.
Regards
Hejob
Hejop is offline   Reply With Quote
Old 10-29-2013, 05:01 PM   #2
kib
My Ride: bmw 04 e46 330 vert
why are you doing this your self if one month old you could lose warrenty and book
will not be stampd.
kib is offline   Reply With Quote
