Thread Tools Search this Thread Rating: Thread Rating: 26 votes, 5.00 average. Display Modes
Old 11-03-2013, 08:37 PM   #21
CK325
My Ride: 323Ci, 325xi
trade you my left kidney?..
CK325 is offline   Reply With Quote
Old 11-10-2013, 07:47 PM   #22
peter*g
My Ride: E46M3, E30M3, JCW
Did a bunch more work to the car over the past few days. Flushed the cooling system, safety wired the harness clips, cleaned up some of the wiring and add plastic loom cover, and some other odds and ends. I also wired up the horn to my Momo wheel and did some more rally prep, all detailed below.
Wiring the Horn Button
Wiring the Momo wheel was fairly straightforward (FYI: this specific wheel is the Momo MOD 80 Evo). I had originally removed the SRS reel, but re-installed it and found the contacts for the horn. Thankfully it was pretty straightforward; bridging the first two contacts in the middle of the reel sounds the horn. I found some small speaker connectors that slipped over the pins easily and ran wiring to the horn buttons.
Carbon Fiber Storage Plate
I also fabricated a plate to hold the required warning triangles and tow rope -- one that could be easily removed when I want to switch the car to a road race spec. I used the spot opposite the battery as my mounting location:
I then cut a piece of carbon fiber plate to fill the spot. I used a cardboard template to check the size and placement, before cutting the carbon and adding slots to slip straps through.
With it bolted into place, the triangles and tow rope are now easily strapped down and in reach.
Two triangles can be mounted anywhere in the car, but at least one needs to be within reach of the co-driver. I used the sub belt hole in the seat to run a strap through to hold the triangle.
Door Pull Straps
One last little "nice to have" that I added is a simple strap between the door and the cage. This make it easier to close the door when you're strapped in. Having already forgot to get the door within reach once while strapping in at the test weekend, I figured it would be worth the effort.
Next up are the door panels, rally computer, and a very special rear view mirror set-up. More to come.
peter*g is offline   Reply With Quote
Old 11-20-2013, 09:54 PM   #23
Alexander13
My Ride: 328ci
Very very interesting! Can you still run the factory door cards with that cage?
Alexander13 is offline   Reply With Quote
Old 11-21-2013, 07:52 AM   #24
peter*g
Unfortunately, no. Even my CSL door panels stuck out too far. I'll be covering the openings in the door with sheets of carbon fiber.
Old 11-26-2013, 03:09 PM   #25
peter*g
Finally got around to making door panels over the weekend. The rulebooks I'm adhering to all require some sort of covering of the "sharp metal edges" in the door opening that is typically left when you remove the factory door panels. I was able to find some inexpensive sheets of carbon fiber on eBay, so I decided to make my own door panels.
I started by making my own template out of cardboard. I used that to refine the dimensions, shape, and how/where I would mount it. Once I had the cardboard shape right, I transferred it on to the carbon fiber using painter's tape to mark where I would have to cut.
I then used a Dremel and a small cut-off wheel to trim the carbon fiber. The small tool let me go slow and be precise in my cuts. And here is the result:
Putting it on the car was a simple matter of pop-riveting it into place. I first duct-taped the panel on to the door where I wanted it, and then drilled through the carbon and the metal of the door to install rivets. Easy.
I know the photos are crap, but this is what you get for taking pictures with your iPhone late at night. I'll take some nice pics of the work with a better camera in sunlight before it goes into storage for the winter.
Old 11-27-2013, 01:52 AM   #26
YYCZHP
My Ride: 2005 330ci zhp
Man this is definately an interesting project but sweet none the less! Good job man!
YYCZHP is offline   Reply With Quote
Old 11-27-2013, 02:24 AM   #27
SC98MaximaSE
My Ride: is still a NISSAN
are these oem e92's?
SC98MaximaSE is offline   Reply With Quote
Old 11-27-2013, 02:52 AM   #28
Feuerbach
My Ride: E46 M3
Loving that CF door panel
Feuerbach is offline   Reply With Quote
Old 11-27-2013, 07:26 AM   #29
peter*g
The 19" wheels are OEM replicas.
Old 11-27-2013, 08:57 AM   #30
BlazingWildBill
My Ride: Ferg 328Ci
Re: and now for something completely different... E46 M3 rally car
Subscribed, this is really cool
Sent from my SAMSUNG-SGH-I337 using BimmerApp mobile app
Post Count:666Sig thanks to Big Rick
BlazingWildBill is offline   Reply With Quote
Old 11-27-2013, 09:05 AM   #31
MiamiVice ZHP
My Ride: 330Ci ZHP Vert
Talk about race car feel
MiamiVice ZHP is offline   Reply With Quote
Old 11-27-2013, 09:23 AM   #32
tks
My Ride: slower than yours
these are my favorite kinda threads!!
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 11-27-2013, 09:39 AM   #33
unevolved
My Ride: 2003 325i
Subscribed.
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 11-30-2013, 06:14 PM   #34
peter*g
My last big project before I put the car into storage is installing the rally computer. I use a TimeWise that was custom built for us to run in Targa. It's a hybrid of their 547b that added a couple of extra TSD functions.
It took me quite a while to find the correct wire to pull a vehicle speed signal from in the car. The best signal I found is from one of the outputs from the ABS sensors. It's a yellow wire with a green stripe that can be found at the back of the instrument cluster (in addition to the ECU and ABS computer). I tapped into that wire and ran the signal to the TimeWise and it worked like a charm.
As for mounting, I was able to use a pair of Joe's Racing mirror brackets bolted to a dash bar that we installed when we put in the cage.
I fabricated a simple aluminum bracket that I could bolt between the brackets and secure the rally computer to. It isn't pretty, but it's functional.
This will be my last post on the build for a few months, as the really cold weather has finally settled in here in New England, and I don't have a heated garage. I have a long list of to-do's, but they'll have to wait until I get closer to my first event next year.
Old 11-30-2013, 06:19 PM   #35
unevolved
My Ride: 2003 325i
Stop me if you've heard this one before, but there's a really easy way to anneal aluminum back to T0 temper in the shop. Draw a line with a sharpie along your bend line, then heat it up with a torch. When the sharpie line disappears, you've hit the right temperature. It's helped me get some nice, sharp bends out of scrap aluminum with just a vise and a hammer before.
I like that computer mount, that's very slick.
Old 11-30-2013, 06:22 PM   #36
peter*g
That's a new one for me. Thanks for the tip!
Old 11-30-2013, 06:52 PM   #37
pgiliver
My Ride: 323ci
This is awesome! When the car's ready, leave some details about the events you'll be running it in. This is probably my favorite thread on this entire site.
pgiliver is offline   Reply With Quote
Old 11-30-2013, 07:19 PM   #38
peter*g
My plan at this point is to compete in the following events:
I'll also try to do a GTS Challenge race or two. I'm actively seeking sponsorship right now for the main events above, so that will somewhat dictate how much I can get out and do.
Old 12-01-2013, 08:27 PM   #39
Rayn325
My Ride: 325i, 325ci
Impressive build. I hope I see this car at least twice when its done - Once in competitive race and again in 20 years in a vintage event.
I'm wondering what the plans are for the underside and front? With all those easily damaged plastics are you going to do metal plates and a push bar?
Rayn325 is offline   Reply With Quote
Old 12-01-2013, 09:11 PM   #40
peter*g
Since I won't be running on gravel, underbody protection is less urgent. I'll stick with the factory plastics for the most part, but I'll likely add a skid plate in place of the stock belly pan and will do something to protect the fuel and brake lines. The oil pan on the M3 is pretty nicely protected with the stock metal plate, so I'll really just focus on protecting the oil cooler and radiator with the belly pan.
