Old 10-30-2013, 10:04 AM   #1
Rathbone
My Ride: Space Shuttle
Key won't turn in the ignition
Sometimes my ignition key won't turn. There doesn't seem to be anything I can do to make it work - pushing it, jiggling it, inserting it slowly, etc. The key cylinder must be bad.
I've been searching this site but you can't combine terms using the search box. For example you can't type "ignition switch" and get results pertaining to an 'ignition switch' because the site searches for 'ignition' and 'switch' and you get unrelated threads.
I have read many posts saying how easy it is to do, but none actually showing how it is done. What am I overlooking?
Rathbone is offline   Reply With Quote
Old 10-30-2013, 04:06 PM   #2
andrewmr
My Ride: Acura RL
Is it because the steering wheel is locked and applying pressure on the lock mechanism?
Try turning the steering wheel to take the tension off of the lock and see if that doesn't help.
andrewmr is offline   Reply With Quote
Old 10-30-2013, 07:49 PM   #3
Rathbone
Yes, dammit - that's exactly what it was! Do you know how many local 'experts' didn't know that? Is this something that happens with all E46's or is it just a select few?
Old 10-30-2013, 07:52 PM   #4
unevolved
My Ride: 2003 325i
That happens on every car that has a lock cylinder on the steering shaft. So pretty much all of them.
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 10-30-2013, 08:06 PM   #5
Rathbone
Ha ha, I guess I've been lucky. I've never seen or heard of this ailment before. Thanks for the tip, though!
Old 10-30-2013, 08:27 PM   #6
unevolved
My Ride: 2003 325i
It's definitely not a well-known thing, I wouldn't feel bad. It's something I've had to "fix" a few times in the past.
