Old 10-31-2013, 03:23 AM   #1
jfp2999
My Ride: 325ci
2002 bmw 325ci geniusness
here is my 2002 325ci bmw that I work on every fing day/ it will soon have a brand new used engine. my other engine had two bad valves on number four cylinder and then what cratered it was my dumbass does the ccv oil separator delete and I run a long ass ccv hose to the ground and it is so close to the ground it sucks up water for weeks from puddles it happened to rain a lot that week too when I ran that long hose so finally enough water leaks into cylinder two and kaboom hole in the block. any ways I was happy because seeing how I know nothing about rebuilds or valve replacement I figure drop a used engine in and just waiting on funds and that bitch is going to be a monster. o yeah if you get programmed by active autowerkes they put this sticker on your dme. cool huh
ID:	532891   Click image for larger version
ID:	532892   Click image for larger version
ID:	532893   Click image for larger version
jfp2999 is offline   Reply With Quote
