Old 11-01-2013, 12:43 PM   #1
jahnaboi
My Ride: BMW
2000 323i (9/99 build date) INPA Codes, Need Help
Hello,
I'm trying to help a coworker solve his DSC light constantly on. I read his car with my INPA program through the ads port and got these three codes.
Prematurely we replaced the ASC/DSC button because of the frequency that I assumed was the issue.
Has anyone ran into a similar problem? I've done research and spent perhaps 4 hours searching but each thread I read had different scenarios. (obviously no two events are exactly the same)
If anyone has any insight what it could be, a point in the right direction would help a lot. Thank you.
Summary:
INPA used with ADS interface
Pulled INPA codes:
152 ASC Push Button (frequency 20
177 Preload Pump electrical Failure (frequency 2)
166 Pressure sensor 2 electrical Failure (frequency 1)
Thanks in advance.
-Jasper
jahnaboi is offline   Reply With Quote
Old 11-13-2013, 02:27 PM   #2
///Mpower3357
My Ride: 00' 323i
Re: 2000 323i (9/99 build date) INPA Codes, Need Help
Steering angle sensor. Are the abs lights on also?
Sent using my cellular tele
///Mpower3357 is offline   Reply With Quote
Old 11-17-2013, 09:58 AM   #3
tuby
My Ride: 2000 328ci silver
I have the same problem
Sent from my SCH-R760 using BimmerApp mobile app
tuby is offline   Reply With Quote
Old 12-15-2013, 04:03 AM   #4
jahnaboi
My Ride: BMW
No. The abs lights are not on. Only the dsc light.
Old 04-23-2014, 09:51 PM   #5
Guram1993
My Ride: 325ci
same issue, has anyone found solution, it started today, when i turn the car off and turn it back on the dsc light goes away and only way it comes back is when i go over speed of 20mph exactly.
Guram1993 is offline   Reply With Quote
