E46 Xi Forum
Old 11-01-2013, 04:31 PM   #1
eshtak12
My Ride: 2003 325XI
Headlight and Rear bumper from pre facelift to newer model
I just found a rear bumper that came from an 01 325 and a pair of xenon headlights that came off the same car. I have an 03 325xi and was wondering if those two parts will fit on my car.
P.S It's just the headlamp, no corner lights.
eshtak12 is offline   Reply With Quote
Old 11-01-2013, 11:23 PM   #2
SicStang03
My Ride: e46 325xiT/6 & 325ci
Headlights won't. I think they changed in late 01 and again in 03. Not sure about rear bumper.
SicStang03 is offline   Reply With Quote
Old 11-02-2013, 01:45 AM   #3
eshtak12
My Ride: 2003 325XI
Is there a way I can retrofit any of those?
Old 11-02-2013, 02:03 AM   #4
bloodredbimmer
My Ride: 01 330Ci 5MT
Its a different front end. you would have to change your front clip. You're car is considered a "facelift" model while the headlights from the other are from a "prefacelift". Rear bumper should fit perfectly fine. I would say sell the headlights and get some to fit your car.
01 P-FL 330Ci 5MT
1st time owner
bloodredbimmer is offline   Reply With Quote
Old 11-02-2013, 12:45 PM   #5
drumbum624
My Ride: 325xi
Send a message via AIM to drumbum624
You can epoxy facelifted corner lights to the preface headlamp assembly. Do a good job and it may even fit well.
People on this forum don't always like to consider the cheap fixes. The fact of the matter is, do whatever you want to your own car.
Though I'm not positive about the rear bumper, I'm pretty sure if anything, the only thing you will need to fit it to your car is the brackets that go right behind the rear fenders or so that the sides of the bumper slide into. I believe they are either called bumper guide brackets or bumper support brackets. Honestly you may not even need to swap those, but if it looks like the bumper wont slide in properly, that is likely why.
drumbum624 is offline   Reply With Quote
Old 11-02-2013, 12:51 PM   #6
eshtak12
My Ride: 2003 325XI
The bumper that's on the car now has a part near the end of both bumper for the bolts. The preface bumper doesn't. I'll post some pictures up to show you.
Old 11-02-2013, 01:27 PM   #7
drumbum624
My Ride: 325xi
Does the prepface bumper have something in place of those bolt holes? Like plastic molded on that could slide into the guides mounted on the car?
I've only swapped fronts and thats why I'm making guesses. But I do remember hearing that an early model rear bumper cover can fit a late model fairly easily
Old 11-02-2013, 04:07 PM   #8
eshtak12
My Ride: 2003 325XI
The preface bumper has no bolt holes in the same area as the current bumper. Instead there are clips that looks like it should be slided to the guide mounted on the car.
Old 11-02-2013, 06:27 PM   #9
drumbum624
My Ride: 325xi
So then try and slide it onto the guide mounted on the car. And if not, find the proper guide from a prefacelifted car on realoem and replace your existing ones.
Am I missing something?
Old 11-03-2013, 01:22 AM   #10
eshtak12
My Ride: 2003 325XI
I'm gonna try it out tomorrow, I'll let you know how that goes. Thanks!
