Sponsored by BAVSOUND
Old 11-01-2013, 07:08 PM   #1
albarran9
My Ride: E46, E53, E90
Dynavin + AudioControl Overdrive
Anyone have this setup? I'm trying to clean up the sound as much as possible after my Dynavin install. It sounds better than sock, but I feel the RCA outs are under powered. I'm wanting to run some active crossovers for my front components and would like to boost and or cleanup the RCA signal a bit. That way I can get as much out of my amps and have cleaner signal feeding them. I cant turn the gain up on my Alpine amps that much, otherwise I get noise interference. I also have an AudioControl LC2i LOC, but feel that the RCA signal is more "full" on the midbass.
Dynavin
Morel Tempo 5's
Alpine MRP-F250 (Fronts)
Alpine MRP-M500 (Subs)
Old MTX 12' subs
albarran9 is offline   Reply With Quote
Old 11-01-2013, 08:53 PM   #2
Jarrettm3
My Ride: m3
I dont know about amping the highs and mids but I do have a dynavin right now and I am running two 12 kickers. To get the power and clean sound out of my subs, I installed the audio control overdrive plus to bring up the rca volts, which on the dyanvin are real low voltage output, and also audio control crossover set at 90hz. That worked out great for me.
Jarrettm3 is offline   Reply With Quote
Old 11-02-2013, 08:06 PM   #3
albarran9
Jarrettm3, good to hear that worked out for you. I think I'm going to give it a try. Where did you place it? I've heard people say that you need to plug it in as close to the source as possible. I've also read on here that some people put it behind the sunglass holder above the shifter under the trim. Did you get the 2 or 6 channel version?
Old 11-02-2013, 11:47 PM   #4
Jarrettm3
My Ride: m3
I have everything placed in the trunk, speakers,amp,overdrive,crossover. That would be techanally correct to place closer to source so that way you dont loose voltage through the resistance of length of wire. Then from the overdrive and out all the way to the amp which is prolly 16ft rca cable. Your trying to keep that voltage signal up through all that wire. I didnt do that and I dont think it is absoluty nessary to do it that way. My amp is kicker zx1000 turned up half way which is approx 2v setting and I have no problems. Overdrive plus is a two channel since Im running one mono amp
