///M3 Forum
Old 11-02-2013, 05:01 PM   #1
Dan1983
My Ride: X3 35i, MaxPsi M3
SMG bad starter?
My car wouldn't start this morning. Occasionally over the last couple months it would struggle to turn over like it had a low battery but start quickly anyway, most of the time though it just cranked like normal. The battery and alternator are both new and the voltage is good.
When I went to start it everything primed properly, put my foot on the brake and turned the key, gear went to neutral like normal and no start. No crank or anything. Voltage on battery was still good. I hooked up the laptop and scanned it with PA-soft and no codes indicating why it wouldn't start. I replaced the key a few months ago when I lost the chip out of the other one. So I hooked up a chain to the car, stuck it in first gear and drug it out of the garage with the ignition on and it started right up. Shut the car off and tried to start it with the key again, and no start.
Does this seem like enough to disqualify it from being the anti-theft system or anything else? Can I go ahead and order a new starter?
Maximum Psi M3
http://img19.imageshack.us/img19/2906/newpicy.jpg
Dan1983 is offline   Reply With Quote
Old 11-12-2013, 08:36 AM   #2
Dan1983
The answer is yes. I put in a new starter and it fired right up.
Maximum Psi M3
