Old 11-02-2013, 05:47 PM   #1
TuckerLM
My Ride: 2000 323i
e46 Clutch - Foreign object found near Flywheel? Any Ideas?
I have a 2000 323i that has a new(er) Clutch that was replaced about 15k miles ago. That isn't the problem: the problem is that I discovered the mechanic who was supposed to have changed out the slave cylinder on the clutch control (as a preventative maintenance when the clutch was out), did not do so.
The slave cylinder recently failed, and I learned the hard way that replacing with a sub-par non-bmw part from a local parts retailer (store name unmentioned) is not a good idea, after installing and starting to bleed, the piston blew out and had brake fluid all over the place. I made sure to remove the piston from behind the fork, cleaned up all the brake fluid, and sprayed brake cleaner as much as I could inside the clutch behind the fork and drained out all of the brake fluid from the bell housing. I, then, ordered a new slave cylinder from AutohausAZ.com, and everything went great.
The next day, I start hearing this pinging noise (like a loose bolt on metal), and could feel it co-insiding by feeling the vibration with the noise on the clutch pedal. I immediately stopped driving the car, and just took out the transmission last night (standard 5-speed BMW Getrag). Here is where I am concerned after I removed the transmission (see pics)
1. I found this "piece" of something metal, with rubber notches in it, and I am wondering if it is from the failed after-market POS slave cylinder I tried to install at first. any ideas?
2. Look at the arrows I placed on the transmission housing... It appears the input shaft is undamaged, but there is clear damage to the input housing. Will I be okay if I reinstall in this condition?
3. Look at the arrows on the pressure plate - The metal is marred in many places, but not dented, and the flywheel looks good and there are no bends in the forks or anything. Again, am I safe to reinstall in this condition?
I am planning on replacing the input and output shaft seals, installing new pilot bearing, fork, etc, as shown on Bavauto.com's step-by step. I just want to be sure that these 'cosmetic' damages aren't going to bite me down the road.
I am fairly new to working on manual gearboxes, and any input / advice would be greatly appreciated.
Thanks, and be well!
ID:	533146   Click image for larger version
ID:	533147   Click image for larger version
ID:	533148   Click image for larger version
TuckerLM is offline   Reply With Quote
Old 11-02-2013, 09:30 PM   #2
HakenTT
My Ride: 323i with S54
That is the piston from slave cylinder. It is impossible for the piston to blow in unless the slave is installed improperly. What you did is put a slave at an angle so the rod missed the fork, then you tightened the two nuts, then when you try to bleed it the rod and the piston blew in. what you removed was the rod with the seal and not the piston. This is all your fault. The after market slave cylinder is not POS, you are POS mechanic.
HakenTT is offline   Reply With Quote
Old 11-02-2013, 09:39 PM   #3
zander271
My Ride: 6spd ZHP/5sp XI
Wtf is up with you being a total dick to everyone?
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 11-02-2013, 10:06 PM   #4
TopasE46
My Ride: 2001 325Ci
Re: e46 Clutch - Foreign object found near Flywheel? Any Ideas?
Not sure what that is, it very well may be the slave piston. You'll be fine reinstalling the trans, the damage to fluting on the bell housing isn't going to affect anything drastically.
TopasE46 is offline   Reply With Quote
Old 11-02-2013, 11:07 PM   #5
pbotz2000
My Ride: 2002 330ci
if it was the piston to the slave cyl you would have brake fluid all over as it would have spilled out or blown out once you pressed the clutch and it failed.
Did that happen or do you see brake fluid. In the pictures it looks dry
pbotz2000 is offline   Reply With Quote
Old 11-04-2013, 12:20 PM   #6
TuckerLM
My Ride: 2000 323i
Yes. There was a big puddle of brake fluid on the ground after I did 'carefully' (to appease the moody nitpicker that earlier responded) install the 1st replacement O'reilly brand slave cylinder, and the shaft that hits the fork would not retract.
Upon further inspection, it also appears the throw-out bearing and clip that hold the fork in place is toast. Also, after I got the new slave from Autohausaz, you can easily see the build quality difference between OEM and aftermarket O'Reiley's. Last I have never had luck with mechanics in Arizona, as they all seem to be about cutting corners. The mecahnic that replaced the clutch, did just that: replaced the clutch. on a car with 155,000 miles on it, one would think that an ethical and honest mechanic would have actuall replaced the slave cylinder as I had aske, and also suggested replacing the throw-out bearing, seals, etc while it was apart.
I chalk it all up to learning, and thank you all for your feedback.
As for HakenTT? you were so honed in on saying something negative that you never even answered my question. Go to a doc and get some Prozac or something.
Old 11-04-2013, 04:44 PM   #7
pbotz2000
My Ride: 2002 330ci
Don't stress someone else's bashing you. It was a mistake and you learned.
Its not usually common either to replace the slave cyl on a clutch job.
Normally the hydraulic system does not get opened or touched.
Old 11-05-2013, 12:03 PM   #8
TuckerLM
My Ride: 2000 323i
I agree, however when I bought the car with 155,000 miles on it, I wanted it done and asked to have it done.
Old 11-14-2013, 09:52 PM   #9
Bobobo-bo Bo-bobo
My Ride: 2000 bmw 323i
how did you get the housing apart? did you use a car lift?
Bobobo-bo Bo-bobo is offline   Reply With Quote
Old 11-14-2013, 10:48 PM   #10
TuckerLM
My Ride: 2000 323i
I didnt have to seperate the housing. I was able to relace all that i wanted, including the 545 short shift kit. Car drives like new!
