Sponsored by BAVSOUND
Old 11-02-2013, 07:09 PM   #1
loayo
My Ride: 2001 M3 Coupe
Aux Input 2001 E46 M3 w/ NAV 4:3
Hello,
I have been searching and have been unable to get a good understanding of what my options are. Just for kicks I got a tape with an aux input from the apple store but it sounds mono and not very good.
Any info is much appreciated.
Regards,
Loay
2001///M3/PowerchipGroup/Eisenmann/Race Flow S-Pipes/AFe Stage II/AutoSolutions/ZCPs/NGK Ir/ULF/JL Audio Amp/Sub/Clutch-Stop 12.8" 1/4mi
1990 Honda Civic DX Hatch B18c1(GSR)/CAI/Greddy Exhaust/DC Sport/H&R/Suspension Techniques/Tanabe/KDWs/Pulstar/Apex Blue Pearl from 2008 S2K CR 14" 1/4mi
2002 Odyssey EX - Secret Weapon R/Pulstar/CAI 15" 1/4mi
2011 Camry V6 SE - Uper Optik 14" 1/4mi
2001 330ci Dinan S1 [Sold]
loayo is offline   Reply With Quote
Old 11-02-2013, 08:33 PM   #2
adamdifilippo
My Ride: The M
Re: Aux Input 2001 E46 M3 w/ NAV 4:3
I'm not 100% sure, but I think adding the aux input is for head units 2004 and above. I have an 01 also and I think our only options are the Dice kit, which I've never used but read hit and miss reviews, and aftermarket radios. I went with the latter (and by me, I mean the previous owner of the car...)
adamdifilippo is offline   Reply With Quote
Old 11-02-2013, 08:34 PM   #3
adamdifilippo
My Ride: The M
Or buy a head unit from a 2004+ vehicle. Usually in the for sale section. Again, I'm not 100% sure on the year but I do know 2001 it is not possible to just add the aux input
Old 11-02-2013, 08:41 PM   #4
adamdifilippo
My Ride: The M
http://forum.e46fanatics.com/showthread.php?t=422239
Sorry for spamming but hope this helps
Old 11-08-2013, 12:31 AM   #5
Jeremy Bavsound
My Ride: Bavsound
We offer 3 iPod/Aux/Bluetooth/Satellite radio options, with varying features. The kit that's right for you depends on the features you need! Here are the three available kits, and the features they include:
SoundPlicity ONE - $109.99
http://www.bavariansoundwerks.com/pr...tegration-Kit/
This is the most basic integration kit, and simply provides:
- iPhone Integration
- Track Up / Down from radio and steering wheel
- Charging
Soundplicity Control II - $169.99 (Currently at $89.99 with coupon 30OFFSP2)
This includes all the features of the ONE, but adds:
- Text display of song and artist info on your radio
- Add on optional Sirius Satellite radio
- Optional - 3.5mm Auxiliary input for use with nearly any device
Soundplicity Control III - $269.99
http://www.bavariansoundwerks.com/pr...n-Control-III/
This includes all the features of the ONE and the DUO, but adds:
- Bluetooth Hands-Free calling with any BT capable device
- Bluetooth Wireless Music streaming from any BT capable device
- Play music from a USB stick
- Answer calls or activate Siri from your steering wheel controls
The Control II or Control III both have an Auxilary input should you not want to use and iPod, and you can stream wirelessly via Bluetooth with the Control III!
Jeremy Whittle
jeremyw@bavsound.com
Bavsound | Audio Solutions for YOUR BMW
www.bavsound.com | 404.381.1800
Jeremy Bavsound is offline   Reply With Quote
Old 12-30-2013, 11:11 AM   #6
Busy
Location: Guys, stop spraying your wheels black; it looks awful.
My Ride: 01 330xi
I just want to get direct confirmation as to whether or not your cable works with the 4:3 Navigation system - yes, no?
Busy is offline   Reply With Quote
Old 11-10-2015, 09:47 AM   #7
ff54976
im in the same boat! i have 2001 m3 with the 4:3 nav.
Can you add a aux input to the 4:3 Nav unit???
ff54976 is offline   Reply With Quote
Old 11-12-2015, 02:45 PM   #8
texas_touring
My Ride: 2003 325xiT
The OEM BMW aux input cannot be added to cars with the 4:3 nav unit, but this is a limitation of the radio tuner in the trunk, not necessarily of the headunit. I think with a newer BM53 tuner, you should be able to add AUX, but you might also need to upgrade the nav computer to at least an MKIII, I'm not certain about that last bit though.
If you are so inclined, an Intravee II would work with your system, and is a good foundation for adding functionality to the Nav-equipped cars.
texas_touring is offline   Reply With Quote
Old 11-16-2015, 12:03 PM   #9
ff54976
so since i cant add an aux to the 4:3 nav what if i get the 16:9 nav, is it plug and plug or do i need tuners etc... and with the 16:9 nav i can add an aux input correct???
Old 11-16-2015, 03:20 PM   #10
texas_touring
The 16:9 nav will slot right in to the dash and replace the 4:3 no problem, but that part is really just a monitor. The entire radio tuner, navigation computer, and video interface, are located in the trunk. So you will get the newer monitor, but nothing else will change.
To get aux input, you will need to update the tuner at the very least to a BM53 (or BM54 for Europe) that is capable of handling an aux input. Different part numbers have different capabilities according to their production date. There is a list of all the BM53 part numbers and their features (Aux capable, Sirius capable, MP3 CD changer capable, etc) on another website, I'm not sure if I'm allowed to post the link!
Now, cars that have factory nav with a production date after 9/02 will have a little connector behind the monitor where the OEM aux input cable can be attached and then run to the glovebox (or wherever you want). Since your wiring harness is pre-9/02, you will not have this connector, and you will need to find a way to directly connect an aux input to the connector on the BM53 in the trunk (a wiring diagram would help for this) and then run the audio cable to wherever you like in the car.
Keep in mind, because you have a 4:3 nav right now, you likely have the MKII (second generation, CD based) navigation system in the trunk which might not be capable of displaying an Aux in source, in which case you would need to replace the MKII computer with an MKIII (third generation, CD based) or MKIV (fourth gen, DVD based) computer. All of these can be purchased on eBay, but the cost will definitely add up.
Check out this thread for a similar case: http://forum.e46fanatics.com/showthread.php?p=4168766
Aux capable BM53 tuners go for about $200 to $300 on eBay, an MKIV navigation computer will cost about the same.
The tape aux cord might be the most economical solution.
Old 11-16-2015, 04:40 PM   #11
ff54976
You rock texas touring!!
I went on to ebay and looked, The tuner $300, mk3 or 4 $300 plus the 16:9 monitor is going to be around 900-1200. So..... how hard is it to go to a 02+ business cd player or Aftermarket nav?? which aftermarket nav has the least glitch's/ weird things/ freezes etc etc....
Old 11-17-2015, 02:35 AM   #12
texas_touring
Yeah those prices sound about right. It's quite a sum, but the old hardware still works I guess!
Going from factory nav to a business CD would not be worthwhile. You would need to change the entire audio wiring harness, as all of the components that are in the trunk of your car are in the front of a car with the business CD. Many have asked about this on the forums, but I haven't seen anyone actually attempt it.
For aftermarket nav, it seems like the Dynavin models are the most well featured and well supported here. If you are into Android gear, you could go with the Avin Avant 2, which looks nice and is well supported but requires more constant tweaking and attention than the Dynavin it looks like. Granted, this is just my observations as a forum member. By all means, avoid the glitch-ridden Eonon models, they look truly dreadful.
For cars with factory nav, you will need to run an extension harness from the radio tuner wiring in the trunk to the dash cavity for the new radio. Since you have a 4:3 nav system, you should have a tuner module called the C43, which has a different style wiring connector than the newer BM53 tuner module. Just something to keep in mind when looking into the installation of the aftermarket systems.
Old 11-22-2015, 09:19 PM   #13
ff54976
once again thank you texas touring!!!
Old 11-26-2015, 10:27 AM   #14
Christian@Enfig
My Ride: 2003 24V VR6 GLI
This will give you an aux at the CD changer connection in the trunk. For $40 more we can also make it with a USB for apple and for $150 total there is a wireless bluetooth option that not on the site yet.
http://enfigcarstereo.com/ENFIG_BMW_K1200_IPDC_AUX.html
Ipod, AUX & Bluetooth add on's for your factory E46 radio.
http://forum.e46fanatics.com/showthread.php?t=1014793
Christian@Enfig is offline   Reply With Quote
Old 11-13-2016, 12:42 PM   #15
bradleyhenry94
My Ride: 2001 BMW E46 M3 6MT
*Note: I didn't bother reading past the first two posts*
the 2001 doesnt have aux and cannot have aux without a module from an aftermarket company or a newer model radio system. Dice is discontinued and has mixed reviews. I'd recommend grom audios products. Has many options and you could always add on features. It also has better reviews than dice based on my memory. Its cheaper than anything besides blitzsafe (bad quality based off my research) and the aux-only module is only $70. easy to install, just remeber to buy 10ft long female to male aux cables because the ones provided generally aren't long enought if you install from the trunk.
bradleyhenry94 is offline   Reply With Quote
