Sponsored by BAVSOUND
Old 11-03-2013, 10:58 AM   #1
CokMinusTheS54
My Ride: '01 TiAg 325Ci 5mt
Relocating head unit to glove box
I'm relocating my head unit to my glove box so that I can mount a tablet in its place to use as my media hub and navigation, but still maintain the factory radio. For me this is a cheap alternative to upgrading my head unit since I already have ipod integration for the factory headunit.
Spacially, the business radio just fits in the glove box. So my next obstacle is getting all the wiring to reach it in there. To address this I'm going to buy an antenna extension cable and then use the female wiring harness adapter along with a male harness adapter spliced together to create a nice plug-n-play extention for the harness.
There is another cable that plugs into the back of the radio though that I do not know what it is. At first I thought it might be radio controls but I tested that theory wrong. So now I am unsure if it's required or not, and if so, how can I extended it.
What is this?
It goes here.
Sent from my SM-N900V using BimmerApp mobile app
CokMinusTheS54 is offline   Reply With Quote
Old 11-03-2013, 11:25 AM   #2
pedrobrocas
My Ride: 2002 325i
Re: Relocating head unit to glove box
Antenna
Sent from my C525c using BimmerApp mobile app
pedrobrocas is offline   Reply With Quote
Old 11-03-2013, 11:29 AM   #3
haurelio
My Ride: 2001 bmw 325i
radio amplifier
Contact me if you need to unlock your phone.
Also can code your car
Old 11-03-2013, 10:03 PM   #4
CokMinusTheS54
The antenna is the plug on the bottom left corner in the second picture. Radio amplifier you say, as in power from the factory amp in the trunk?
Old 11-04-2013, 10:13 AM   #5
CokMinusTheS54
Bump. ^
Old 11-04-2013, 11:08 AM   #6
daki_bmw
My Ride: 330Ci
Diversity antenna cable. Basically our cars (prior to 2002) have two antenna cables. Both are needed, unless you change your antenna amp (inside driver's side C-pillar) to a 2002+ type.
http://forum.e46fanatics.com/showthread.php?t=396343
daki_bmw is offline   Reply With Quote
Old 11-04-2013, 12:44 PM   #7
haurelio
radio antenna amplifier, it got nothing to do with factory amps
Old 11-06-2013, 08:16 PM   #8
CokMinusTheS54
I'll have to test how it affects radio reception, but essentially, if I don't use or care about AM/FM radio, it doesn't matter if I have it plugged in. Correct?
Old 11-07-2013, 06:55 AM   #9
StereoInstaller1
My Ride: 4 door demo booth
Correct.
StereoInstaller1 is offline   Reply With Quote
Old 02-20-2014, 06:41 PM   #10
BMWMac
My Ride: 325i
CokMinusTheS54,
This is exactly what I've been thinking of doing to my car - moving the headunit to the glovebox and installing a tablet as a multimedia system. I would love a further write-up to know if you actually ended up doing it, how you did the re-wiring, etc.
Thanks.
BMWMac is offline   Reply With Quote
