E46 Xi Forum
Old 11-03-2013, 01:38 PM   #1
Corey_325xi
My Ride: 2001 BMW 325xi
Send a message via ICQ to Corey_325xi
330xi motor into 325xi
Hey guys I was just wondering if the 330 motor would fix/go into my stock 325xi without other mods ie transmission and what not...
Corey_325xi is offline   Reply With Quote
Old 11-04-2013, 10:25 AM   #2
SamDoe1
My Ride: 4cyl of fury
Sell 325xi and buy 330xi. Thank me later.
If you're interested, I'll likely be selling my car in the spring sometime. Perfectly maintained, complete records, 6spd manual 330xi.
Old 11-07-2013, 03:57 PM   #3
mvance30
My Ride: 2002 325xi
To actually answer your question I found a thread somewhere that spoke about the same thing. Some kid posted that he actually had it done. I think when it was all said and done it was about 3k for the swap I believe he used all the electrical parts from his motor and swapped out the fuel injectors then reprogramed the ecu for the new injectors. If I can find the thread I'll link it but if you google your question it should be on the front page somewhere on one of the bmw forums.
I'd imagine its not actually all that hard but it wouldn't be THAT much more work to get an m3 motor in it. and when all is said and done you have a 325 with a slight power bump that might or might not handle the extra 40ish hp (trans, clutch, axles, diffs etc etc) all of those might wear or need to be replace rather quickly. So you end up spending more or close to the same amount than just buying a 330.
since motor swaps are so extensive you're better off getting the most out of the labor by swapping the best engine you can get. No point to upgrade half your car and pay 1k-3k for the swap for 40hp.
but all in all yes you should be able to with little to no other mods needed. but don't expect those other parts to last too long.
mvance30 is offline   Reply With Quote
Old 11-07-2013, 04:49 PM   #4
Corey_325xi
Ok that's the answer I was looking for... But the M3 is RWD so the motor wouldn't work in AWD would it ?
Old 11-07-2013, 05:25 PM   #5
SamDoe1
Come on man, I've been on this forum for more than three years and have almost a thousand times as many posts as the other guy who answered and that's the answer you were looking for?
My answer was not as much a smart as$ response as it was a serious one. You cannot swap an M3 motor into an Xi without a budget of $20k at least. One guy who did it on here spent well over $100k to make an AWD M3. If it were that easy, don't you think people would be doing it left and right?
For starters, the S54 engine has a different oil pan entirely which makes it quite hard to mount a front diff or axles to it. Second, the fuel system is different, the ECU is different, the rear axle is different, the rear diff is different and doesn't come in a ratio that matches any available front diff, the transmission is different which makes it hard to mount a transfer case to it let alone mate a non-M transmission to the engine, the electrical system is different, the gauge cluster is different...shall I go on? It's not as simple as "swapping the best engine you can" in order to save on labor.
On top of all of this, adding 140hp to a car requires new brakes and suspension to handle the power increase.
If you wanted to swap a 330 engine into a 325XiT then it would be a different story since that car doesn't exist from the factory. Even though that swap is possible, it's not nearly as simple as just swapping injectors and an ECU. You have to dismantle and remove the ENTIRE front end, engine bay, and drive train to swap the engine out and then proceed to reinstall everything in such a way that it actually works when you get done. No offense but judging by your previous posts, you are nowhere close to being able to do this on your own or with friends. Hell, I personally wouldn't even consider this.
I would guess that by the time you're done with this project you'd be into the car at least $5k in parts and labor (if you got good deals on everything). If you put $5k on top of whatever you can sell your car for, I bet you can get a 330xi that's both newer and has less miles than your 325xi and also reap the other benefits that come with the 330xi (brakes, interior flair, etc).
So I say again, sell your 325xi and buy a 330xi or an M3. If that's not the answer you are (and should be) looking for then I wish you, your car, your time spent in a pointless swap, and your wallet the best of luck in your endeavors.
/rant
Old 11-07-2013, 05:44 PM   #6
Corey_325xi
The answer as in it isn't worth it. That's what I was curious about
Old 11-08-2013, 01:30 PM   #7
mvance30
My Ride: 2002 325xi
/rant
and I've been on bfc since 2007 with double the posts you have. Doesn't mean im twice as smart so thats pointless.
Either way power costs money. I've been there and spent a ton of money to get some decent speed. You'll always want more and there will always be someone faster. If you want speed for cheap get a foxbody mustang and be done with it.
Euro cars are never cheap.
Old 11-08-2013, 04:51 PM   #8
SamDoe1
Re: 330xi motor into 325xi
With that much experience and that high of a post count I would expect you to give better advice than to swap an S54 into an E46 Xi just because it is the best engine offered on the platform.
