Old 11-03-2013, 08:01 PM   #1
jdjg
My Ride: e39, m52tub30
My Dyno numbers NA today
using DynoDynamics
e39 530i
5 speed manual
NA
SS headers with NO cats
SS 2.5" single pipe, mandrel
Magnaflow Resonator
Remus muffler
Epic Motorsport Tune
E95 Gas (5% Ethanol + 95% normal 95 octane gas)
jdjg is offline   Reply With Quote
Old 11-05-2013, 06:06 AM   #2
SoloII///M
My Ride: Many
Epic tuned your car for E95? What injectors are you running?
The torque curve looks very odd. Something isn't right.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 11-05-2013, 09:02 AM   #3
jdjg
no, Randy do not tune my car to use E95 gas...
Im run the M54B30 injectors...
Why do you say my torque curve are odd?
what do you think its wrong here?
Right now Im talking with Randy, to see whats he can improve in his tune....
Old 11-06-2013, 06:17 AM   #4
SoloII///M
My Ride: Many
If the car isn't tuned for E95 you're running massively lean. Ethanol has only 66% of the energy density of gasoline so you need to run quite a bit more ethanol into the engine. That means bigger injectors, a higher flow fuel pump and a tune to take advantage of it.
Your torque should not be dropping so sharply at 5500 RPM and above.
John V
Old 11-08-2013, 04:03 AM   #5
reggid
My Ride: .
lol...its 5% ethanol not 95%......op should not call it E95. E95 would be 95% ethanol.
reggid is offline   Reply With Quote
Old 11-08-2013, 05:46 AM   #6
SoloII///M
My Ride: Many
Oh, LOL... yeah, that's not E95.
John V
Old 11-08-2013, 06:49 AM   #7
jdjg
ohhhhh, my mistake!!!! E5
