Australia
Old 11-04-2013, 05:58 AM   #1
Davew
My Ride: 2004 330ci Msport
Wtb: 3.23 or 3.15 diff, centre or gears Melbourne
As the title suggests , going to the wrecker Wednesday/ Thursday if I can't find one here.
Davew is offline   Reply With Quote
Old 11-04-2013, 06:01 AM   #2
Davew
May consider other ratios.
Old 11-05-2013, 04:20 AM   #3
Alexander13
My Ride: 328ci
What gear ratio are you trying to get out of?
Alexander13 is offline   Reply With Quote
Old 11-05-2013, 04:27 AM   #4
Davew
2.93 currently fitted
Old 11-06-2013, 05:57 AM   #5
Davew
No longer required, purchased
Old 11-24-2013, 05:39 AM   #6
Davew
Required again, preferably 3.15. Do have a 3.38 that I would swap or sell out of a 330ci auto ( paid $350 ), may also consider swap for the 2.93 that's in it now.
Old 11-25-2013, 12:22 AM   #7
helrot330ci
i beleive this is a 3.15 diff and its in melb aswell.
http://www.ebay.com.au/itm/BMW-e39-5...526a57d&_uhb=1
helrot330ci is offline   Reply With Quote
Old 11-25-2013, 12:40 AM   #8
Davew
Thanks helrot330ci, will keep an eye on this
Old 11-25-2013, 02:37 AM   #9
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
E39 is not a direct fit.
E46 Coupe is offline   Reply With Quote
Old 11-25-2013, 02:49 AM   #10
Davew
Yeah, I noticed the difference, was going to check if the crown and pinion are the same (?). Basically that's all I need. May even just get them new or made.
Old 01-07-2014, 12:53 AM   #11
Davew
Details as requested by forum member, .004 inch backlash, or 0.1016mm
Old 01-07-2014, 02:43 AM   #12
E46 Coupe
E46 Coupe's Avatar
You removed your diff and drained it just to measure the backlash for someone???
Aren't you nice!
Old 01-07-2014, 03:03 AM   #13
Davew
I'm nice enough to admit I don't know the k's of this diff, and honest enough that I want to be sure of its condition
Diff was out, only took 10 minutes of my life to measure and photograph, least I could do to assist a fellow fanatic
