Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 11-04-2013, 06:56 AM   #1
djbradle
My Ride: 2002 325 xit
'02 325xit
179k
Steel gray metallic on black leather
Auto
Xenon AL headlamps
Premium and cold weather
$3900
Extensive maintenance performed within the last year.
Suspension and steering :Bilstein front struts, front strut mounts, with Bilstein M3 rear shocks. Oem Front control arms with Powerflex polyurethane bushings. Oem tie rod assemblies. Steering lower joint assembly and double universal joint.
Engine and transmission: oil pan gasket. transmission filter, fluid, and gasket. All knock sensors, crankcase, exhaust camshaft, and intake camshaft. Cleaned intake control valve, new lower throttle intake boot, upper intake boot, cold weather ccv (crankcase ventilator valve), headlight washer pump, and headlight washer telescoping nozzle. And a new oem windshield
Much more maintenance was done over the 4 years I've owned it.
A few more things need to be done: an idler pulley makes a little screeching on colder days. Probably like $40-$50 and easy to do yourself. A small selector rod shaft seal on the transmission is weeping a little bit but usually most e46 owners leave it alone as it is such a small and slow leak. I have the repair kit for it. Being at almost 180k miles it consumes about 1.5 qts of oil per 1000 miles. I've monitored it for a few months. All four lower door trim seals have some rust showing on the bottom inside. Only one door has it showing through slightly outside when you look close. This rust is the only reason I'm selling it for the KBB fair price as the wagon is in such good shape. Doesn't come with X1 rims/tires or cross-members. The price of 3900 is firm and non-negotiable cash or bank check.
I have other e46 items for sale as well:
Bumpstops and dust shields for front struts - $40
Waterpump holder and fan clutch wrench - $40 for both or $20 each(never used)
2 charcoal cabin air filters - $ 10 each
4 almost brand new oem '13 Bmw X1 style 319 rims and Eagle runflat tires - $750
ID:	533324Click image for larger version
ID:	533325Click image for larger version
ID:	533326Click image for larger version
ID:	533327Click image for larger version
ID:	533328Click image for larger version
ID:	533329Click image for larger version
ID:	533330Click image for larger version
ID:	533331Click image for larger version
ID:	533332Click image for larger version
djbradle is offline   Reply With Quote
Old 11-16-2013, 05:38 PM   #2
djbradle
Sold
