Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 340 votes, 5.00 average. Display Modes
Old 12-26-2013, 05:29 AM   #161
nut
My Ride: 04 LSB M3 SMG
Some apps are, but you should be able to use most apps unless they specifically requires more demanding hardware specs of the unit.
All you see at the app store from Avin are compatible since app store recognizes your unit's android version shows only compatible apps to you.
•Dinan CAI+Free Flow Exhaust w/ Stage 3 software+SMG CSL flash
•Sub-frame reinforcement kit
•KW V2
•Brembo GT 355mm 6pods + 345mm 4pods
•VMR VB3 19" + Ventus V12 EVO K110
•Headlamp retrofit: S2k projector + 85122cm + eas AE
•SCSL dual CF trunk
•E90 key retrofit w/ greater remote distance! + Start Engine button mod
•Auto-fold side mirror retrofit
_____________
For Sale:
•ZHP Alcantara steering wheel (Cond. 8.5/10)
nut is offline   Reply With Quote
Old 12-26-2013, 02:48 PM   #162
SKR7
My Ride: E46 MY04.5 SMG M3
Thanks. So not much point choosing apps until it's installed in the car then.
///M
2004 E46 M3
SKR7 is offline   Reply With Quote
Old 12-26-2013, 06:35 PM   #163
matt0
My Ride: 318i n46 e46, e34 M5
Which way have people been running the extension cable to the boot/trunk? Across the glove box side or past the gauge cluster? Also would you run it along the floor behind the trim etc...
First time doing any wiring work on a e46.
matt0 is offline   Reply With Quote
Old 12-26-2013, 08:45 PM   #164
nut
Easier way is routing harness to the following route:
headunit - behind glove box - tuck into/along door sills - under back seat - trunk
Short cut but bit of fishing required(for under carpet):
headunit - gear box thru armrest - under carpet - under & behind back seat - trunk
•KW V2
•SCSL dual CF trunk
_____________
For Sale:
Old 12-26-2013, 08:53 PM   #165
nut
Once you log in to google play store with your unit, you can see which app is compatible for your device from each app page.
•KW V2
•SCSL dual CF trunk
_____________
For Sale:
Old 12-26-2013, 09:07 PM   #166
Bishopgoldy
My Ride: '05 M3 '92 325is
Re: Official: ///AVIN BMW E46 Full Android Multimedia Navigation System - Info and Q&
I missed the DHL guy by like 10 minutes..... I drove around for 40 minutes looking for his ass lol
Sent from my SAMSUNG-SM-N900A using BimmerApp mobile app
Bishopgoldy is offline   Reply With Quote
Old 12-26-2013, 11:01 PM   #167
Dr3wX5
My Ride: X5 3.0i
I was having trouble routing the wires under the door sills. So what I did was shove them more under the carpet, away from the door sills. This allowed me to attach the door sills easier as well as reattaching the B column. There is a channel connecting the back seat to the trunk. I fed the wire through that channel which brought the cable to the right cargo hatch area in the trunk. From there, have the cable follow the existing cable harnesses into where the OEM radio tuner is. Its pretty simple once you get the cables past the back seat.
Dr3wX5 is offline   Reply With Quote
Old 12-26-2013, 11:01 PM   #168
matt0
Thanks man, I'll investigate both
Old 12-26-2013, 11:04 PM   #169
matt0
My unit was set to be delivered last Friday in the late afternoon to my work and as per usual with DHL especially they don't even bother coming and say that there was no one at reception despite us having two people at reception at all times. Luckily the driver updated it on the tracking status as I called up DHL immediately and they sent the driver back.
Our company has found that a lot with our local areas DHL driver, super lazy. If you call up they will normally send him back.
Old 12-26-2013, 11:54 PM   #170
Bishopgoldy
Thanks!!! Well im camping out for his ass tomorrow lol not going for that ****
Old 12-27-2013, 04:31 PM   #171
Dr3wX5
My Ride: X5 3.0i
I have experienced a few problems with the head unit and was wondering if other people have the same problem.
1. Phonebook reloads every time car turns on. This takes too long and when I receive phone calls the name is listed as unknown.
2. If switching from radio to Spotify, Spotify does not automatically play. You have manually shut down the radio app and then go back to Spotify.
3. I have the 3G USB Modem with T-Mobile and it is way too slow. Spotify has to buffer many times during a song and that is with good signal. There is a significant delay in switching tracks. THIS is the BIGGEST CONCERN FOR ME. Hopefully there is a fix for this.
4. What is the button "AS" do on the head unit? When I pressed it, all my FM preset stations reset to 87.5
5. TORQUE only shows boost gauge... Cannot seem to find other info like mpg, rpms, range, etc...
If these problems can get resolved I would rate this head unit a 10.
Old 12-27-2013, 04:56 PM   #172
nut
Mine is not auto syncing phone book everytime but it seems to save my previous sync to the memory. It DOES takes a bit when reload.
Cannot comment about spotify since I don't use this. Pandora works good, but there's background crashing issue, in my case.
It might not be related to your 3g modem issue but my wireless connection via tetheing works fine for me. I'm using Tmo $50 plan and enabled Tether with LTE from my nexus4 and have rarely had speed/connection problems. I think wireless part is hard to tell since it gives very different results depending on user's device. At least, it works fine for me...
Regarding to Torque, mine reads quite more info than yours, maybe it's OBD bluetooth device specific?
•KW V2
•SCSL dual CF trunk
_____________
For Sale:
Old 12-27-2013, 08:02 PM   #173
matt0
For torque you have to add the gauges and graphs you want manually. Press the menu button in torque.
Sent from my GT-I9505 using BimmerApp mobile app
Old 12-27-2013, 08:06 PM   #174
Dr3wX5
My Ride: X5 3.0i
I think my problem is connecting via Bluetooth. Can you connect while having your phone connected? When my phone is connected and I go into Bluetooth I don't see an option for search for obd2 devices. But I did see you can add gauges so I will play with that.
Thank you
Old 12-27-2013, 08:07 PM   #175
matt0
Just installed my unit yesterday but my main two issues are;
IPod takes about 20 minutes to index every time the unit is turned on. Has someone found a better iPod player/manager? Or can you make the iPod app stay open when the unit goes in stand by so we don't have to index every time?
Also my button lights do not seem to be illuminated.
Apart from those two the unit is great.
Old 12-28-2013, 08:04 AM   #176
tommy@avinusa.com
AKA: M3Evolution
My Ride: 2003 M3 SMG
1. For privacy and security purpose the Bluetooth phonebook contacts, call logs, etc does not save on the unit. Many cars are driven by more then one person eg.. BMW Service Center, Valet, Wife, Kids, and your recent call logs and contacts might not want to be shared.
2. The radio app is meant to be kept running in the background and does not auto close when other apps such as Navigation apps are open.
3. The 3G Modem is capable of download speeds up to 7.2mbps. That is faster then some home DSL internet connections. The actual speed you might be getting will vary depending on many different variables, such as carrier, your data plan, signal strength, your location etc.
4. AS = Auto Scan
5. The free version of Torque that is included with the unit has less features then that of full Pro version. You can add different gauges within the app.
tommy@avinusa.com is offline   Reply With Quote
Old 12-28-2013, 10:01 AM   #177
Dr3wX5
My Ride: X5 3.0i
4. AS = Auto Scan
Thanks Tommy. It looks like I will cancel my Tmobile account since its only month-to-month, and I will get a mobile hotspot device from AT&T and share my family data plan. The newer devices have 4G LTE and that will hopefully solve my internet problem. Can you confirm if such a device would work? I believe it just creates a wi-fi network and from there the head unit should be able to automatically connect. The only downside is I would have to take it out every few days to charge -- but i can live with that.
Is there anyway to get an update for the head unit to remember the contact list? I can understand why it was designed that way for privacy, but it does not affect me personally. Please let me know.
Thanks,
Andrew
Old 12-28-2013, 10:19 AM   #178
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
I have an lte wifi hotspot from att that I use here at the office, on trips, etc...works great and was relatively cheap to add to our family plan. I think its the "Sierra wireless elevate" if I recall.
It will charge from a USB so If you are just going to use it in the car you could use a simple USB cig lighter charger, or hardwire a charger any number of other ways, so it charges anytime the car is running
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 12-28-2013, 10:27 AM   #179
Dr3wX5
My Ride: X5 3.0i
Sounds good. Could I charge it from the USB from the head unit that I was using for the 3G Modem?
Old 12-28-2013, 09:12 PM   #180
Dr3wX5
My Ride: X5 3.0i
OBC Functions still work! (Somewhat)
Hello all,
So I noticed that I am still able to access some OBC functions with the new head unit installed! If you press the BC button on your steering wheel stick thing, you are able to cycle through the parameters on your cluster. However, this is limited to what you chose to be visible from the Onboard Computer under the OEM Head unit.
For example, I disabled a bunch of metrics such as Speed Limiter, Distance, Arrival, etc.. but I chose to display Range, Fuel Consumption 1, Fuel Consumption 2, Date, and Time. These changes were made on the original OEM Head unit. The ones that you chose to appear on your cluster WILL REMAIN AVAILABLE after you install the AVIN Head unit. So I am still able to access my range, consumption, time and date. So if you still have your old OEM Head unit, you can connect that and customize what you want to show on the cluster, then reconnect the new head unit. Easy fix. I am not sure if this applies to e46s, but it works for my e53.
All this is still accessible from torque, but its nice to also have this easily accessible from your cluster.
Hope this helps,
Andrew
P.S. Where do i go to change the steering wheel controls?
android, avant, avin, dynavin, eonon, m3evolution
