///M3 Forum
Old 11-11-2013, 04:13 PM   #1
Alroy
My Ride: 2003 M3 SMG CWPkg.
WTF is up with the differential backlash?
Seriously, my car has become completely uncomfortable to drive around the city. Is it normal for the car to buck back the very moment you let off of the throttle? It's presumably alot more intense in 1st and 2nd gear. I replaced the center support bearing two summers ago. Never checked the guibo but I still feel like this is a differential issue, not driveshaft.
Maybe I'm just being too picky and this phenomenon is a normal thing for our cars.
Alroy is offline   Reply With Quote
Old 11-11-2013, 04:18 PM   #2
choxor
My Ride: JDM
I have no backlash.
choxor is online now   Reply With Quote
Old 11-11-2013, 04:24 PM   #3
Alroy
Originally Posted by choxor View Post
I have no backlash.
Any assumptions as to what can cause it then? This only occurs when load is cut off. Subframe? Bushings? Mounts?
Old 11-11-2013, 07:22 PM   #4
taylor192
My Ride: 2003.5 M3
Re: WTF is up with the differential backlash?
It could be your gas pedal. I have the same problem and noticed it's only bad when I abruptly let off the gas. If I roll off the pedal it's fine.
There is a thread about how to measure if your gas pedal is still good, yet I could never measure mine properly. I'd just replace it if it wasn't so expensive.
Old 11-11-2013, 07:33 PM   #5
M3Froi
My Ride: 2005 M3 ZCP
I have this as well, I think it's referred to in some threads as the dreaded M3 "shudder." I get that "buck" when I left off the gas pedal abruptly rather than easing off gradually. So far I haven't found a clear solution to this so I'm curious where this one will go. Keep me updated!
M3Froi is offline   Reply With Quote
Old 11-11-2013, 08:02 PM   #6
cityjohn
My Ride: 2001 M3
Mine does this when I'm in 1st coasting down a ramp (inside a parking structure) but that's pretty much it. Always thought it was because it was cold.
cityjohn is offline   Reply With Quote
Old 11-11-2013, 09:43 PM   #7
Grinchxvx
My Ride: 2001 M3, 1998 M3
I get this too, I feel like it's normal and you just can't let off the gas so suddenly.
Grinchxvx is offline   Reply With Quote
Old 11-11-2013, 09:55 PM   #8
JohnBlaze
My Ride: Black Sunshine
you might want to get that checked out, bucking sounds terrible
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 11-15-2013, 08:56 PM   #9
Kyemaul
My Ride: 2006 E46 M3 Vert
Can you explain the "buck back" a little more in detail? Is it a vibration or a kick back or do you hear it out the exhaust pipe?
Kyemaul is offline   Reply With Quote
Old 11-16-2013, 07:40 PM   #10
Drewsuph
My Ride: E46 M3 - E36 320i
A quick check is your Diff mounts. One of mine had come loose and was doing the same thing (in reverse also).
Drewsuph is offline   Reply With Quote
Old 11-18-2013, 03:28 PM   #11
alirz
My Ride: E46 M3 Coupe.2003
yup. Im starting to hate the backlash also.
Its the same thing that causes the "M3 clunk" also. Most noticeable when shifting from 1st-2nd.
I wish the diff was more "tight" so everything felt well connected.
alirz is offline   Reply With Quote
Old 11-18-2013, 04:43 PM   #12
aidan530
My Ride: e46 m3
So is there a consensus on what the fix is? Does replacing the just the ring and pinion and tightening the lash solve this? Is there anyone that has swapped differentials to a diffsonline or something similar and it has solved it? Even better would a drive line shop be able to adjust backlash/rebuild? I have learned to live with it, but I would love to eliminate it. I've only got 60k miles and its not clunking, but the slack from acceleration to deceleration and back is rather annoying. It also can't be good for the drive line or the subframe mounts.
aidan530 is offline   Reply With Quote
Old 11-18-2013, 05:09 PM   #13
cyberkaa
My Ride: E46 332i,M3;E30 325i
Before you replace or rebuild the diff, have a look at the rest of the components.
Besides the bushings mentioned above, the drive shaft rear CV joint and output shaft inner and outer CV joints will develop a ton of slack over time. It'll feel like backlash in the differential from the cockpit, but the root cause becomes apparent from underneath the car when rotating the drive shaft back and forth. I replaced two M3 drive shafts with 100k+ miles within the last few weeks because of worn CV joints. The output shaft joints on both cars were also loose, but the differential itself had almost unnoticeable backlash.
There is a good amount of backlash in the transmission itself, but that's not worth chasing.
-Kalim
(klx photo studio)
Old 11-18-2013, 10:55 PM   #14
XIinSC
My Ride: 2004 M3 98 M3
Radial play at the tail shaft? I've been chasing a clunk from the front/center of the car lately. I did notice a good bit of play here. So that's normal as well?
XIinSC is offline   Reply With Quote
Old 11-19-2013, 02:46 AM   #15
cyberkaa
There should be hardly any radial play at the output shaft thanks to some pretty beefy bearings and manageable loads of that nature. I'm referring to backlash in the gearset. This causes a high pitched metal on metal clunk even in neutral using just finger torque, which contributes to clutch chatter with lightweight flywheels. I've observed similar lash in transmissions ranging from 8k miles to 100k+ miles. There's one in my garage at the moment with 60k miles on it and sure enough, it does the same thing.
A loud clunk you can hear through the frame, e.g. when shifting between 1st and reverse is usually not from the transmission itself. It can be hard to pinpoint since sound travels through the frame pretty well, but assuming it is from the front, the transmission mounts and flex disc are the first things to inspect.
-Kalim
(klx photo studio)
Old 11-19-2013, 12:40 PM   #16
///3ME
My Ride: Z/71
Don't forget about the dual mass flywheel (if you are running one.) They can wear to a point that allows too much radial play, which can give the driveline a distinct thumping upon unloading.
///3ME is offline   Reply With Quote
Old 11-19-2013, 11:46 PM   #17
XIinSC
Gonna do the flex joint and CSB next week if we are slow at work. Did the trans mounts already but seemed like I had quite a bit of radial (rotating) play at the tailshaft. Could twist it and get a metallic clink.
Once I pull the shaft I'll look closer, so thanks for the input.
